I have been using it for the last month or so and love it. It's easy to use, has a fast data update rate and has additional inputs for other sensors that you may want to add. It works on the later operating systems so you can use newer laptops. It's kind of like Direct Scan on steroids.
1987 GN, 1986 T, 1984 Hurst Oldsmobile with 1987 GN drivetrain |
You can go here and get most of the answers you probably need.
Buick PowerLogger & Scanmaster Support - Full Throttle Speed Tech Support
TurboDave EWCS(SW) USN (Ret.) My Photo Gallery Email Us Sevierville, TN TranslatorPro MAFless fuel, spark and boost management 86 GN(TranslatorPro/ExtenderPro on speed density w/boost & fuel pump control,PLX-WB) (original owner) 87 GN (second owner) 84 L69 Z28 (original owner) 01 Excursion LTD 7.3L PSD(Power Stroke Diesel), Turbo, 4X2 08 Honda Accord EX-L, 270HP 3.5V6, AT |
It is great.
Jim: 87 GN with: TE-61/PTE .63 housing - ported stock heads - Erson 208 cam - Speed Pro forged pistons - PTS trans. & 9/11 converter - MSD 60# - CAS V-4 - 3" DP - ATR 2.5" exhaust - 62 JJ TB/stock plenum - RJC power plate - Gen II w/LS-1 MAF/PL - SMC progressive alcohol - Walbro 340 - and Extender G chip with 26*/22* timing. Best 1/8 mile run: 6.904 @ 100.04 with 1.535 60'. |
Jbenn911 did you use the stock MAP sensor to monitor the boost or use a 3rd party MAP sensor. Can you discribe your install thanks
Pullin' like a freight train, Flyin' like an airplane, Been drinkin' gasoline, And honey you can make my motor hum... |
I already had a 3bar MAP(GM, thinks it was for the TTA) in there for the Alky kit..simply tapped off the green wire and attached it to the loggers aux. input. Install was very straightforward.. If you previously had DirectScan, its just a matter of making sure contacts on the ECM are clean and hook it up. From there its a small bit of cutting to the bottom of the kick panel for the wiring(USB cable and a PS2 cable for the Aux Input of the PL). I have the USB cable running along the sill plate up to the seat for my laptop. The Aux Input cable is run inside the kick panel and up behind the dash where I mounted the Aux Input.. WBO2 was used with the analog outputs of my LM-1, EGT was with FT's EGT amp and a probe kit from Caspers, Fuel Pressure was tapped off the purple wire of my Autometer electric FP setup
87 GN, FAST COMPANY POWERED! 11.59@116.33 |
Not to mention they are not even done with all the updates yet. They are going to have an upgrade for the scanmaster so you can retrieve data much quicker and more parameters without a laptop in the car. It just keeps getting better.
1986 Grand National 212/206 hydraulic cam, pro-tru pistons, .030 over port, ported and polished stock heads, and too much other crap to list. 3" THDP, Precision GT6152E Turbo, 50 lb. injectors, Janice Transmission with 3200 Vigilante converter, Walbro fuel pump with hotwire, RJC Race Plate, Hydroboost Brakes that hold!, TurboTweak Chip, Dequick SLIC and the best for last.........AlkyControl Methanol injection kit! www.ALKYcontrol.com www.TurboTweak.com |
Yep! Definitely a trick piece....Best part is, doesnt need much of a laptop to make it run well... Anyone who's wondering what the deal is, should check out full throttle's forum.. Plenty of posts in the power logger section..
Will it work with the new Windows 'Vista' operating system?
87 GN- Astroroof,stock motor w/144k ,GNX Style Dash,Razor's Alky Injection,TE 44, 60# Mototron's, Mease 24 Row Stretch IC, 3"THDP, TurboTweak Chip, PTS Xtreme Billet 9x11 3200 lockup, 11.85et@115.47mph 1.66 60ft 25# boost w/MT drag radials with old ta49/42.5 D5 combo, NEW MOTOR/COMBO COMING as soon as the boostjunkie (aka Shawn) decides to finish it!!!! |
Dunno yet...Someone did post on FT's site, asking TurboBob the very same question... I'd think the only issue would be the USB driver for the unit.....
Got one on order this thing should make tuning a little easier with some real data.
87 GN not so stock 10.33 @ 133 pe63 ptrim, cottons fmic, ported irons and intake, 214/214 roller, ME-R, 72lb inj. other stuff to go with it. 02 SS not so stock either 11.17 @ 123 |
| PowerLogger Questions.. | wordy1 | Scan Tool Tech | 15 | November 3rd, 2007 09:35 AM |
| PowerLogger now shipping | Mike Licht | Advertiser Specials | 8 | February 12th, 2007 03:05 PM |
| PowerLogger :) | DonnieShort | Turbo Lounge | 2 | January 15th, 2007 10:52 PM |
| Powerlogger and alky-Razor | Quiky One | Alcohol, Nitrous and Propane Tech | 4 | January 15th, 2007 09:38 PM |
| PowerLogger installed, first impressions | DonnieShort | General Turbo Buick Tech | 23 | December 25th, 2006 07:18 PM |
