Old March 5th, 2007, 06:27 PM
noahzark's Avatar
Do i have to install roller rockers for roller cam kits or whats the alternative?
HI...i bought a roller cam kit from full throttle 210/215...im trying to find a way to save a bit and im wondering if i could just buy some heavy duty rocker shafts and new buttons bolts etc for around 150 or do i have to buy a 500 dollars roller rocker set up from t and d or harland sharp...i started with a 5k budget and that sits at 10k as it is...im sure most of you know how it is...so im trying to find some ways with the rest of this build to save a little ...thanks for all help...noah.
Old March 5th, 2007, 06:39 PM
the one and only
I run stock rockers with solid shafts with no problems.
85 T-Type TE63E, CAS V4, Vig TC, 60 mototrons, 215/220 roller, ported irons, 3.5"DP, UMI lowers, ATR bar, Brian Hoffer 200 4R with brake 10.97@121 with a 1.47 60'@ 21psi, 10.87@124 with a 1.55 60'@25psi
79 Cutlass Supreme stock GN drivetrain with Powerstroke intercooler 11.72@113
95 Roadmaster LT1, 72000 miles, custom intake, 100hp shot, headers, Edge racing 3000 stall, Impala SS 17's, 3.42 posi, ZZ4 cam, tan with tan leather 13.69@99 motor, 12.38@111 on the bottle
87 T Limited 245" Weber stroker, 224 roller, GN1's, Janis trans, Precision 5 disc, 3.5" THDP, 95lbs injectors, still deciding on turbo, intercooler
2001 GMC dually Duramax tow rig soon to be bombed
Old March 5th, 2007, 06:43 PM
SouthernCal GN's Avatar
I come in peace....AK AK
I use stock rockers and shafts- no problems as of yet.
1 thing I learned- don't get caught up in the fear of the engine breaking- just build it right and go have fun with it.
Proud owner of a teeny lil' ol' v-6 that has a nasty tendency to STOMP on V-8s!!
But, DAMN, is it fun!!!!!!!!
project frankenstein under way.....
"A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, pitch manure, solve equations, analyze a new problem, program a computer, cook a tasty meal, fight efficiently, and die gallantly. Specialization is for insects"
Old March 6th, 2007, 02:28 AM
The stock rockers on a HD shaft will work fine IF you have the correct length push rods. Lifter pre-load is VERY, VERY important on these engines. If you have more than .060" lifter pre-load you are leaving HP on the table. With roller rockers you have adjustability. With stock rockers you are stuck with what you have. If you have over .060" then you can shim the WHOLE rocker assembly up with .032" thick 5/16 aluminum washers. Place them between the rocker-shaft and the cylinder head pedistals. They will raise the rockers up about .035"-.037". DO NOT INSTALL ANY ROCKER ARMS WITH OUT CHECKING PRE-LOAD!!!! Rocker geometry is nothing to take for granted. Check EVERYTHING when assembling an engine. I installed a .032" washers on a 100% stock engine and the car picked up 3 mph at the track with NO other modifications. The lifter pre-load from the factory is WRONG on most Turbo Buicks. If the washers are not solving your pre-load issued then you can order adjustable push-rods from these guys: http://www.pushrods.net/images/adjustable.jpg Or you can step up to roller rockers, but they require grinding of the sides of the pedistals to clear. Here's what you need to do:
Ken B.
Old March 6th, 2007, 03:15 AM
noahzark's Avatar
thanks for the info...im using the pushrods that come in the cam kit full throttle sells...believe they are the 8.225" ones they are not adjustable...what im hearing most is that that will be fine... as long as preload etc. are ok as well...thanks again...noah.
F/S: ported stock heads, new roller cam, roller rockers KevinB Parts for sale 19 January 7th, 2007 11:31 PM
Roller cam kits... hosspala General Turbo Buick Tech 5 December 12th, 2006 05:04 PM
885 Roller Lifters, K-Motion Springs, Scorpion Stud mounted Roller rockers V6 Beast Parts for sale 4 November 6th, 2006 10:00 AM
hYDRAULIC ROLLER WITHOUT ROLLER ROCKERS BOOSTAHOLIC General Turbo Buick Tech 6 August 20th, 2002 12:44 AM
Roller Cam and Roller Rockers Blwn87 General Turbo Buick Tech 3 May 8th, 2002 04:43 PM
