Old February 2nd, 2007, 04:03 PM
Best Surface for RTV ?
what's the best surface for RTV . a mirror like machined surface or something a little more rough like a sandblasted surface ? can not find any real info on the topic . thanks .
87 TR - PT6776S BB Turbo , 250 cu/in Stroker , Weber Racing CNC 109 Block , Champion Ported Intake , 75 lb/hr Injectors , ME-R , 62mm TB , DLS 218/218 Roller Cam ,T&D 1.65 Roller Rockers , PAC Alky Kit , Heads Race Ported & Polished by FrankG , 4" inlet pipe , TH DP , 3" TT Cat Back Exhaust , CAS V4 , Poston Headers , Walbro 340 Pump (Hot Wired) , Fully Prepped Transbraked TH400 w/ West Coast Racing Converter . BEST TIME TO DATE : 10.97et @ 128.34 mph/1.74 60 ft on pump gas & alky.
http://rides.webshots.com/album/105791401mgmznK http://www.youtube.com/watch?v=ZKochubXMl0 , http://gnttype.org/carofthemonth/arc...mdetails1.html
My TR's "Day At The Track" : http://www.youtube.com/watch?v=8JwUThcEKcA
Old February 2nd, 2007, 08:32 PM
onefastcar's Avatar
mono e mono
I would say the machined surface because you can clean it well the sandlasted finish may have dirt or grease in it.
87 gn bored 20 over hyper pistons,ported and polished heads,chinese ss exhaust headers, hv oil pump, stock turbo (TE-61 soon) with adjustable waste gate actuator with rjc boost controller, hot wired 340 warlboro pmp. with accufab regulator running 42.5 lb inj., dual fan set-up, kenne bell cold air kit, pinion snubber, smc alky kit with 2800 lock-up torque converter,poly body bushings,kyb shocks, lt1 maf with trans+, extender chip and scanmaster and ngk wideband, not yet track tested.
Old February 3rd, 2007, 12:41 AM
2QUIK6's Avatar
Turbo Milk Jug displacmnt
RTV will bond to either surface as long as its oil and grit free. Use Ultra-Black or Right Stuff for best results. I've never had a leak with either one of them.
Rob
Rob's HP & PARTY page!
'87 Grand National Owned 17 years. 65#inj,HW 307, THDP,V4 IC, GT6131E, alky, no cat, Cold Air kit, Del-alum fronts, Gen2 T+ w/LS1 & LM1/LMA3 WBO2, JJ TB mod, 3000 PTS 9x11conv, Direct Scan, best 1/8th 7.23@96, best 1/4 11.61@119, 1.66 60'
'79 10th Anniv. T/A 6.6 all original 4-spd
'89 20th Anniv. TTA #426 stock, 15k miles.
'99 30th Anniv TA #707 Conv 1 of 535 conv..rarer than a GNX.
'95 Trans Am Conv LT1 w/LPE 211/219, LE2 ported heads/intake, and LTs/true duals
'94 Silverado LT4 w/LPE 211/219.
Old February 3rd, 2007, 07:48 AM
thanks guys will do .
best way to prep deck surface? TType84 General Turbo Buick Tech 9 July 4th, 2004 02:52 PM
Manifold surface eddc87 General Turbo Buick Tech 2 December 31st, 2002 08:22 AM
Surface finish on steels monte_383 Transmission Talk 2 August 22nd, 2002 09:18 PM
Thrust Surface Worn Again Why? BobbyBuick General Turbo Buick Tech 11 July 7th, 2002 10:53 AM
I know how to fix cam thrust surface on block Boost231 General Turbo Buick Tech 2 June 25th, 2002 06:19 PM
