if it has spark, then your cam and crank sensors are working.
next step would be to check fuel. Do you have a fuel pressure gauge?
87T - stock block, TA-61, Precision FMIC, Comp 218/218, Janis transmission, 57# injectors, and lots of ghetto-rigging |
do you hear your fuel pump prime? check your fuses!
85 GN, converted to 87 IC'ed stuff. TE-44, 60lb Mototrons, Ron Anderson ported big valve heads, DIY ported stock intake, modded upper plenum, 204/214 cam, 3" THDP, test pipe w/dump, 3.5" to 3" single shot with bullet, HUH? Neal Chance 3,000 converter, wired 340, DIY turbo saver, DIY stock boxed uppers and lowers, poly bushings EVERYWHERE, TLink 4.0, Tach, boost, knock, oil PSI, H20 temp gauges, F body rad, Intrepid dual fans, Turbo Tweak chips!!! DAILY DRIVER: made it from Kansas to Florida, back to Kansas, then to San Diego, CA.
So if it has spark then both sensors are good? I was under the assumption that there could be spark with bad sensors? I don't have a fuel pressure gauge but I can get my hands on one. I checked the under dash fuses and they are OK. I have a walbro fuel pump and I hear it priming when i turn the key so I have to assume that's not the prob.
check all the basics for fuel. The pressure, noid lights to see if the injectors are getting a signal. Make sure the TPS voltage isn't too low, etc
OK, guess I'll just have to sit on my hands until my noid lights arrive. Thanks for the help thus far. |
put the crank sensor in the right slot ????
Dan don't run your mouth if you cant run your car 86/87 GN and 89 TTA .. tons of parts !! Time to get out! Stuff has to go !!! Otherwise I am cutting it up and throwing it away email ttastage2@yahoo.com
I swapped slots on my crank sensor after bugering up the front slot and mine runs fine. Is it not supposed to be that way?
What led up to this problem? Were you going down the road and engine shut off? Did it just not start one morning? Any repair work just prior to problem?
Conrad
Turbonetic 66-S-BB-.63exh w/EVO WG (35mm) #10780, KB 70mm TB/Plenum, Champion port Intake/CI head/Fuel Rail/EGR B/O, Comp Hyd Roller #212/212 w/beehive, Scorpion 1.5 RR, ATR 3-bolt header/dual 3" Cat-Bk/DP301, 72# inj, RJC Pl, PTE TurboSaver, 12" B-Car frt/11" Baer rr disk, Hotchkis tubular up frt ctrl arms/frt sway bar, Metco rear ctrl arms & HNR sway bar, Eaton posi w/Moser 30 axle, GTA wheels, CAS V-1/St. Al. radiator, 4" cold air, XFI, GNX Dash, Autometer Dual Channel In. Air Temp, Billet Optima Battery Mnt, 9.5" ArtCarr LU 3k stall, DRW C. Al Tran. Pan w/700R filter. 11.6 @ 118 mph. Antifreeze in the Oil! Metal fines in Oil Filter. LOL. Jack & Brian Cotton (www.cottonsperformance.com) (413-789-0531) The Greatest! |
When you first turn key on do you hear fuel pump run?
87 gn bored 20 over hyper pistons,ported and polished heads,chinese ss exhaust headers, hv oil pump, stock turbo (TE-61 soon) with adjustable waste gate actuator with rjc boost controller, hot wired 340 warlboro pmp. with accufab regulator running 42.5 lb inj., dual fan set-up, kenne bell cold air kit, pinion snubber, smc alky kit with 2800 lock-up torque converter,poly body bushings,kyb shocks, lt1 maf with trans+, extender chip and scanmaster and ngk wideband, not yet track tested. |
| Replaced my cam sensor. | VadersV6 | General Turbo Buick Tech | 0 | February 6th, 2006 04:56 PM |
| Hood shocks, PLX R-500, Cam Sensor, Crank Sensor, ATS | Intercooler | Parts for sale | 0 | July 10th, 2005 09:04 PM |
| Cam Position Sensor, Crank Sensor, Balancer | DAVID C | Junkyard Dogs | 6 | February 3rd, 2004 06:35 PM |
| Replaced o2 sensor and car runs like @#!* | juicdstang | General Turbo Buick Tech | 13 | July 21st, 2003 06:28 AM |
| New crank sensor doesn't fit into old sensor bracket??? | 87LtdT | General Turbo Buick Tech | 7 | November 12th, 2002 05:46 PM |
