Old September 16th, 2006, 05:23 PM
Brer Rabbit's Avatar
Pursuit Specialist
Knock Knock driving me crazy.
Well I put straight 114 octane into the tank after draining the 93 out and took the car for a blast. The car is still indicating knock on the ANS detector. Ive checked and double checked for anything that could be hitting the block or the downpipe and still cant find the cause. The knock seems to come on when I get into it pretty hard and since the car spools up real fast the knock comes on right away. Just changed the knock sensor for the hell of it and torque it to 14 ft. lbs but the same thing is going on. So now I need to know if a noisy valve train(roller rockers and lifters) and or a slight exhaust leak would cause my knock detector to light up at me. Im about to lose my mind here ....please help. By the way the most recent test pass was only 13 pounds of boost on that 114.
The Widely Accepted and Riegning "Peoples Champ" in the state of Illinois, as stated by Dr. Boosts Girlfriend! Man was he mad when he heard that!
Old September 16th, 2006, 05:37 PM
QUIP'6''s Avatar
lpaulabbott
13 psi with 114 would run way to rich
1987 Buick Grand National.BoostJunkie 30 over 109, Forged Pistons, 204/214 cam, BB.TE-60, 50# MSD Inj., Razors Alky kit, 24 Row Stretched Intercooler, THDP. LS-1 Maf ,Translator, Ultraflows, Hotwired Walbro 340, Billit Regulator, Rjc valve and plate, BoostJunkie 200r4, Pats 3200 10" lock up, 93 Alky Tweak Chip. Vacuum Brakes with S-10n's, Alum. Brake Drums. Poly Body Mounts. Front/Rear Braces. New Front Suspension, Red UMI Tubular Rears. Street Stars. Mickey Drags 275 60's. Rear Air Bags. POSTONS TRUNK KIT best ET ON TA-49 IS 11.62@114.00. 1.609 60' 25# of boost 27/24. 93 octane and alky 9# launch. Brian Roman
Old September 16th, 2006, 06:08 PM
As I am experiencing the same problem, would someone please explain to me how you can get knock from running too rich, and/or using too high of an octane or too much alky?
I would guess that running too rich would make a car bog and smoke, or would cause a loss of power and fouled plugs - but why would it cause detonation?
Unless it is false, higher octane and/or alky is the cure or preventative for knock - right? How can it be the cause?
I'm with you, lpaulabbott, in that I'm losing a part of my mind on this.
But I didn't have much to begin with.
Old September 16th, 2006, 09:02 PM
DCVING 6's Avatar
The octane level should have nothing to do with how rich the car is.
Glen
1986 GN- Garage Art.
Old September 16th, 2006, 11:09 PM
QUIP'6''s Avatar
lpaulabbott
running rich will cause detonation because its like trying to compress a liquid because your not burning all the fuel also you need to run high boost and timing for race gas because of the fuel properties BELIEVE ME I HEARD IT A MILLION TIMES BEFORE
Old September 16th, 2006, 11:14 PM
QUIP'6''s Avatar
lpaulabbott
LOW BOOST WILL CAUSE HIGH EGT'S 1700 TO 1800 RUN HIGHER BOOST OR TIMING THEY WILL GET DOWN TO 1550 TO 1600
Old September 17th, 2006, 12:06 AM
DCVING 6's Avatar
OK, but what does the 114 octane have to do with being rich?
Why would low boost cause higher EGT's? I run 110 in my car all the time. Whether I run 14psi, or 24, my afr is a consistant 11.4-11.5, no knock either way.
Glen
Old September 17th, 2006, 12:34 AM
Alaskabuick's Avatar
knock
If I hammer my car from a roll say 20 mph and it down shifts I will always get knock and more knock when the car gets up in the rpm range and then on the shift. Winding out in 3rd the knock goes away. This is all due to valve train and the jolt of the down shift, tires breaking loose etc. It used to freak me out at 1st but now have learned to ignore it. Roller rockers and differnt valve train from stock will set off you knock sensor from what I have been told.
My test for true knock now is to roll on in 3rd past the point where it can down shift to 2nd. I hammer it for a long hard pull all the way up to 25 pounds. I watch for knock, if I have knock I turn up my alky. If I am not running the alky I will adjust my boost or easier yet lower my timming on my FAST.
Not sure all what you have in your car. But this has worked for me.
Look at it this way, you have 114 octane, I dont think their is any way you would knock with that fuel at about any timming or boost that is within reason? Just my 2 cents, no expert.
Dennis
87 GN, PT70GTQ DBB, 75 Lbs INJ, FAST, PTE F/M, Alky, Champ Alum heads
87 Turbo T Stock
70 GSX Stage 1 Saturn Yellow
71 GS Stage 1 Convertible 4 speed
70 Stage 2 sportwagon 12.3 @ 107 4600 pounds
1970 Chevelle SS 454 LS5 Convertible
68 GS 400 Convertible
1971 GS Stage 1 Convert 4 speed
2007 Cadillac Escalade ESV
2007 Lincoln Mark LT Crew Cab 4x4 pickup
Old September 17th, 2006, 12:37 AM
Wink
Hi,
I am also having a hard time comprehending how a rich mixture can cause detonation. I guess extended operation with this problem would cause a lot of combustion chamber deposits, but aside from that, I don't get it.Any other explanations?
***83 Buick Regal TType***
'87 drivetrain and all associated stuff.
Fresh rebuild with Stock block,ARP studs installed with stock caps,align bored to ensure proper fit.Sealed Power forged pistons,stock rods,resized for ARP bolts,stock heads with low cost stainless valves,206/206 Comp flat tappet cam, TA49 turbo,009 injectors,hotwired Walbro 340, Hooker cat back exhaust,K&N filter in stock airbox,Spearco water injection, pretty stock otherwise.
***89 Pontiac Turbo TA***
Walbro 340, Flowmaster muffler, otherwise stock.
***96 Buick Riviera***
3.6" blower pulley,otherwise stock.Runs 15s on a hot day at 4000 plus pounds weight, with the A/C on.
***84 Jeep Cherokee 2door 4x4***
87 Turbo Regal motor,thm700R4,rusty wild child,definitely a restoration awaiting progress.
Old September 17th, 2006, 12:42 AM
DCVING 6's Avatar
Originally Posted by 83ttypecooled
Hi,
Common misconception is that knock is all the same. The following link has some good reading on the subject.
http://www.streetrodstuff.com/Articl...tion/index.php
Glen
Old September 17th, 2006, 02:23 AM
Aspiring Guru
Brier Rabbit,
I really think we all need more information to answer your question.
Do you have a torque strap on the car? These are aftermarket and pass through the bolt hole in the alternator and rachet down to keep things in place. They make a difference, and before I installed mine on a past buick, I noticed the same symptoms that you have. Also, what is your turbo? I doubt 14psi would cause knock with 114 even with a T76 sized turbo, which leads me to believe you may be running excessively rich or lean(as previously stated), or that your sensor is picking up false signals(see torque-strap above). I know some guys with "noisy drivetrains" have had to relocate their knock sensors with success, however aftermarket solutions would be your best route for longevity, and protectino of your investment. What are your EGTs under WOT/during knock?
-D
Old September 17th, 2006, 08:45 AM
Pursuit Specialist
Info
Originally Posted by Sinful6
Brier Rabbit,
-D
Im running a drivers side H and R mount, a stock pass. side mount, poly trans mount, nothing else. the achy has not even been out of the box at this point. Im gonna check the travel of the block today under load when a buddy comes by. Guys thanx for the insight so far, Its strange how I tend to overlook the simple things just because I used certain parts.
Old September 17th, 2006, 09:18 AM
Lee_Burough's Avatar
..Never Forget..
Thumbs up You could have carbon build up in your combustion chambers....
If you have some carbon build up, it glows red hot and predetonates your air/fuel charge....Ergo, you have knock.
You might want to treat the car for carbon build up. The treatment won't hurt anything. I use chevron Techron fuel system cleaner periodically. For the first treatment, you should try some GM Top Engine Cleaner.
Good Luck.
Lee Burough
Lburou@aol.com
Old September 17th, 2006, 12:10 PM
QUIP'6''s Avatar
lpaulabbott
Too Much?
Old September 17th, 2006, 01:29 PM
Razor's Avatar
Forum tech Advisor
Chasing knock problems
this may help
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
http://stores.ebay.com/ALKYCONTROL_W...eNameZl2QQtZkm
