Old September 2nd, 2006, 02:42 AM
RUQWKNF27's Avatar
???? about EGT an A/F ratio..
EGT is its high means what?? I presume rich.
A/F ratio?? same thing??
I know all combo's are different. But is there a general sweet spot as far as A/F ratio without putting th ecar on Dyno to findout??
I think i may have Alzheimer cause one day I can remember theses simple things an the next I am a damn retard ...............................
http://www.cardomain.com/memberpage/637073/2
Current pics:http://www.turbobuick.com/forums/sho...d.php?t=168306
87T-Te-45a/V1/72"s/DP/Girdle/Je's/70TB&DH/3400 911/CenturyTrans/PortedIrons/TAFrontCover/4"SingleShot/4"CAI/Ari.GN Rad/Hrparts.upsanlows+ more...10:82@124 @23LBS With 1.73 60ft more http://videos.streetfire.net/video/A...BA3DA9822F.htm New Exhaust>>
http://www.turbobuick.com/forums/sho...d.php?t=194282[url]
BURNOUT http://www.turbobuick.com/forums/turbo-videos-picture-library/201365-small-burnout-other-night-lowes.html Razors Dual Nozel Alky via 26 lbs!
Old September 2nd, 2006, 07:18 AM
Boostaholic
To high of an EGT means a couple things to me.
1. Your running to lean
2. your knocking real bad, pulling timing. That can cause high EGT's as well since timing is firing much later in the cycle.
-Dennis
03 Apex Evo GSR
87 Grand National
Old September 2nd, 2006, 07:30 AM
turbo2nr's Avatar
loading...
You can be pig rich and have high EGTs because the combustion is still going on thru the exhaust. Or you could also have high EGTs because of a super lean condition. The o2 sensor (wide band) should point you in the right direction. Use both! An EGT by itself is not much good. Just My opinion.
87GN
Old September 2nd, 2006, 08:02 AM
Razor's Avatar
Forum tech Advisor
EGT=Exhuast gas TEMPERATURE.
The Higher the temp.. the leaner the car is.
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old September 2nd, 2006, 08:31 AM
turbo2nr's Avatar
loading...
That's not always true. You can run rich with not enough timing and still have crazy high EGTs/
87GN
Old September 2nd, 2006, 08:36 AM
Razor's Avatar
Forum tech Advisor
On a properly tuned car it is.
On an improperly tuned car.. anything is possible.
Just like if you set your WOT timing to 15 degree's.. you'll hit 2000 degree's.
PLUS.. the higher the timing, the lower the EGT.
As above stated it is used to see where your tuneup is not to see air fuel ratio. As knock, timing, cylinder pressure, intake temp, etc all play a role on EGT.
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old September 2nd, 2006, 09:55 AM
turbo2nr's Avatar
loading...
Well, somebody give this guy a A/F number to shoot for.
I'll say 11.5:1-12.5:1 at WOT. Depends on how hard you are running, and fuel.
Do you have a wide band 02, or are you just looking at the Micky-Mouse stock narrow band sensor? I think you should be aiming for mid .700s with that, but it's not very accurate.
87GN
Old September 2nd, 2006, 10:08 AM
Razor's Avatar
Forum tech Advisor
Not true hehe.. 11.0-11.2:1 at WOT as a starting point. 12.5 will break some parts.
On a low timing high boost app.. low 700's on race gas. On pump gas high 700's. Pump gas alcohol 770-780's top of third using a 22 degree chip
EGT= 1500-1700 depending on timing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old September 2nd, 2006, 10:21 AM
The problem with A/F ratio is that you have to have the leanest cylinders in a SAFE condition. So, that means that the overall A/F ration will much lower than if you could have all cylinders at the exact same conditions. 11 to 1, even 12 to 1 is richer than you would want for max power. There was an interview with Jim Bell a few years ago when he recommended 13.5 to 1 for max power. (Jim Bell of Kenne-Bell, for those who don't know) Jim cited tests on Bill Middaugh's GN, when it got to 501 hp, with stock ignition timing, a stock MAF, 113 octane fuel, and 27 lbs boost- and running at 13-to-1. The advantage to the richer A/F ratio is that it's more tolerant of fuel that's too low in octane, and it protects the lean cylinders.
Flame temp is max at 14.7 to 1 (stoichiometric) and goes down with richer or leaner mixtures. EGT will be different, depending on timing and mixture, since the gasses in the exhaust may at some temp other than the flame temp.
George W
Old September 2nd, 2006, 09:53 PM
Also not entirely true
11.3 is safe at 30# of boost on these motors. 11.5 still safe but I'd rather run a little richer.
12.5 is safe at 15# of boost
Chris, 13.5 is lean....10.5 is rich
Like was said. EGT could read 1800 and be lean or way rich. If you're too rich the unburned fuel ignites in the header and runs EGT's up. On a well tuned car an EGT of 1600 is richer than a reading of 1700. After I started using an a/f reading I wish I would have done it years ago, it's the best way to go.
PTC Converter Distributor
Twisted 6 Racing
Fastest of the fastest
Freeman, Fiscus, Kereny...who's next
85 Regal w/ turbo SBC
5.05 @ 147 on radials at 3550#
94mm and 325's
Best 1/4 pass
7.77 @ 181
Old September 2nd, 2006, 09:56 PM
Razor's Avatar
Forum tech Advisor
What do you mean.. I thought everyone ran 30#
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old September 2nd, 2006, 10:06 PM
I remember making a pass on 30# and thinking...Damn I lost 3# of boost somewhere
Twisted 6 Racing
94mm and 325's
Best 1/4 pass
7.77 @ 181
Old September 2nd, 2006, 10:13 PM
Razor's Avatar
Forum tech Advisor
On that Autometer 30 PSI guage you have 1st screw and 2nd screw. That 2nd screw is a doozy
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old September 2nd, 2006, 10:27 PM
Ha, we're too much alike. I brought mine into work and checked it against a calibration instrument. I marked the gauge with white out at 30, 33, and 35#. 35 was around that second screw but my car slowed down there. I lost mph there so went back to 33#
I was suprised how far off the reading was at 30# on my gauge. 30# was really 27. We also have a VDO in a friend's car. 30# was really 24 No wonder it wasn't running like it should.
Twisted 6 Racing
94mm and 325's
Best 1/4 pass
7.77 @ 181
Old September 3rd, 2006, 12:36 AM
Is my car tune tuned ok?
23 LBS BOOST WITH TURBO TWEAK CHIP WITH 23 DEGREE TIMING 1ST AND 2ND AND 21 THIRD AND FOURTH.
O KR
A/F=11.7-11.5 AT 5300 RPM
EGT=1690
O2=770-780
LAMBDA=.80
94 OCTANE AND ALKY (95% ETHANOL)
Thanks, Marco.
86 Grand National t-top (60300km)
stock long block,stock suspension, red stripe convertor, te44, smc alk injection, 24lbs boost, 94 octane, hooker cat back with dyno max ultra flow muffers, tomco 30lbs injectors, dynotech stage 4 street chip, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3800lbs race weight with driver. (Torque convertor not locked)
.New set up: 42 ½ 009 injectors, turbotweak alky chip, rjc power plate, rjc boost controller, and will lock the torque convertor, zeitronix wideband, HR motor mounts, comp cam 980 valve springs, the rest is the same, will be going to the track this fall with new set up.
BEST E/T
60FT=1.52
1/8= 7.38
I/4= 11.74
MPH=113
BEST MPH= 114
Old September 3rd, 2006, 02:59 AM
evil666 I'd say yes.
Twisted 6 Racing
94mm and 325's
Best 1/4 pass
7.77 @ 181
Old September 3rd, 2006, 06:44 AM
Pronto's Avatar
What is the best location for the A/F and EGT probes? Does the A/F one go where the O2 sensor goes? What if your using the stock ECM? Over winter I would like to get some more tools to help tune better. I feel like I'm just shooting in the dark with a Scanmaster.
87 TurboT--GT6131, 60lb injectors, Precision sl intercooler, Hooker cat back exhaust, THDP, home made Big Mouth, pp, 62mm tb, adj fr, Walbro 340/hotwire, AlkyControl kit, Turbo Tweak 93+alky chip, HR lower control arms, air bags, ATR bar, best et 11.79@113.86
http://s64.photobucket.com/albums/h1...secondpass.flv
Old September 3rd, 2006, 12:02 PM
RUQWKNF27's Avatar
I do not have a Broad Band yet. I am thinking of the Innovative LM1 Kit for the car.. I already have a EGT. I was just wondering a starting point when I get one..
  #19 (permalink)
Old September 3rd, 2006, 06:32 PM
Egt usually goes in the header right before the flange for the turbo.
The Wide Band needs to be at least 12 inches from the turbo in the downpipe, we normally shoot for around 18. That put's it close to the a/c box on the T/R's. You also want to mount it on the top side of the pipe so moisture won't settle out in the sensor.
Twisted 6 Racing
94mm and 325's
Best 1/4 pass
7.77 @ 181
  #20 (permalink)
Old September 3rd, 2006, 06:50 PM
turbo2nr's Avatar
