Old August 2nd, 2006, 03:08 AM
Mad_Trbo's Avatar
Fuse Block _ Horn Fuse
Anyone got a schematic of the fuse block? The lettering was worn away on mine and I need to find the fuse for the horn.
Mods : WE4 87 T-type : Walbro Fuel Pump / Hot wire / 83 lb injectors / 3" ATR down pipe external Turbonetics Racegate / magnaflow exhaust / T66 ball bearing turbo / PTE stock stretch mount intercooler / Tial Blow Off Valve / F.A.S.T. XFI installed / Art Carr TC stall 3400 / ck performance stage II 2004r Transmission installed/ 218/212 Hydraulic Roller Cam, Weber Racing Ported Heads and Ported intake
Old August 2nd, 2006, 05:46 AM
Is it in the owners manual?
May be GNT-Type Org?
Old August 2nd, 2006, 08:34 AM
salvageV6's Avatar
Lightbulb
There is no fuse in the horn circuit.
Power to the horn relay, located in the convenience center black box, is from fusible link A, that link also powers the horns themselves through the relays contact switch closure.
Horn ring grounds out when pushed, and gives the ground to the horn relay coil to activate it.
