Old June 20th, 2006, 07:19 AM
Aluminum Vac. Block
I've got one with the fitting for vac. brakes (it's capped)
Should that tube fitting turn/spin in the block, or should it be tight?
Mine can move.
Thanks
Old June 20th, 2006, 08:27 AM
87geeinn's Avatar
enormous member
All of the fittings should be removable (unscrew like a bolt). Just tighten it up and hopefully it isn't stripped although I can't see how it could be.
'87-88k, stock block, Alkycontrol, TA49, 9" Art Carr n/l, G-Bodyprts IC, BFG drag rads., 009s, lots of other misc. upgrades.
Old June 20th, 2006, 08:56 AM
Pronto's Avatar
The vacuum line cap shouldn't spin. Try a small hose clamp on it.
87 TurboT--GT6131, 60lb injectors, Precision sl intercooler, Hooker cat back exhaust, THDP, home made Big Mouth, pp, 62mm tb, adj fr, Walbro 340/hotwire, AlkyControl kit, Turbo Tweak 93+alky chip, HR lower control arms, air bags, ATR bar, best et 11.79@113.86
http://s64.photobucket.com/albums/h1...secondpass.flv
Old June 20th, 2006, 04:15 PM
If the tube is loose in the block, that will give you a vacuum leak. I would pull it/unscrew it, and put some sealer on it, or some loctite.
George W
Old June 20th, 2006, 04:54 PM
Pronto's Avatar
Ah the nipple is spinning in the block. Yes that's a vacuum leak. Seal it as Ormand says.
Old June 20th, 2006, 05:20 PM
Man, I sure hope so, 'cause I'm running out of things to do to get rid of the knock.
Took the block off, tightened and sealed the nipple, used a new rubber cap with 2 zip-ties, put on a new gasket and used sealant on the 2 bolts.
I'll give it a try after the new fuel filter goes on - which will take either 3 minutes or 30+ to do, depending upon how lucky I am at the moment.
Thanks.
