Old March 8th, 2006, 02:59 PM
Unhappy hydro/power boost
I am confused. I have an 85 GN and I think it is equiped with the power boost system for the brakes. Is the hygro braking system just on the 84's. How do I tell the difference? I am having some problems with the brakes at this time and want to know if parts are available for the factory system or should I look into a vacuum system? Big problems like this always come up before a show. 24th 25th Pleasenton Fairgrounds The Goodguys show.
Turbo85 Thanks
Old March 8th, 2006, 03:57 PM
Your 85 could have either the hydroboost or the Powermaster. The HB has two power steering hoses attached to it and the PM has two wire connectors and has an electric motor with no PS hoses attached. Parts are non-existant for the HB and there is almost nothing left but accumulators for the PM. If you are having problems the most cost effective way is to convert it to vacuum.
Eric Fisher
OEM Parts Specialist for GM Vehicles e-mail me at efisher@billheard.com
1997 SCCA Regional Champion. 1986 Grand National #38 ESP
86 Grand National
84 Riviera T-Type
82 Regal engineless
Old March 8th, 2006, 04:32 PM
Post hydro/power brakes
Thanks for the info. It checks out that I have a powerboost system. If any other problems that I cannot fix I will check out the vacuum system. Turbo85
Old March 8th, 2006, 06:31 PM
84GNGary's Avatar
Long Time Owner
I just replaced my hydrobooster last summer due to it leaking power steering fluid. Got a remanufactured one at Advanced Auto for about $150 with a lifetime warranty. Here is a pic of a hydroboost system.
Have been a proud original Grand National owner since September 6, 1984. It's still original inside & out and only 43k miles. And that's no HOT AIR!!!
Walbro 340, hot wire kit, custom modified stock air filter box w/ 9" K&N Filter, gutted cat, adj fpr, 87 ECM & TT 93 Street Chip, 87 MAF, Razor's PAC, 160 Stat w/ RMI 25 & water, 30lbs Tomco Green Stripes, Caspers Audible Knock Indicator, Grainger Valve Boost Control, Direct Scan, Delco CR43TS @ 0.032, MSD 8.5mm Wires, Royal Purple 10w30.
MAGNA Member
84 Window Sticker Template, Sending Unit Repair Guide & Pics of My GN
Old March 8th, 2006, 11:42 PM
alec296's Avatar
<-- TURBOCHARGE THIS
i recently got a new master cyl for my 84 with hydroboost,had to wait a few days but got one.i like the hydroboost better than my 87s powermaster.
just my preference
andy
84 gn,hotwire kit,87 coilpack
still working on it,87 kb exhaust,ANS 3000 converter
82regal 455 12.56 on pump gas and q-jet
65 buick special could be getting hot air fi motor
Old March 9th, 2006, 12:21 PM
Brakes
Thanks so much for the effort you have put in to make my life easier. Wow I sure like this foum. Turbo 85
Old March 9th, 2006, 12:23 PM
Brakes
just my preference
andy
Thanks Andy I appriciate the feedback. Turbo85
Old March 9th, 2006, 12:29 PM
Brakes
Thanks GARY IT IS GOOD THAT YOU HAVE HAD YOUR SINCE NEW
Old March 9th, 2006, 01:02 PM
a powerboost system
I guess that is a hybrid, of the hydroboost and the powermaster? Does it use an electric motor for the power steering pump, or use power steering fluid to charge the accumulator? Kind of leads into hydrovac, which will at least dig a hole....
George W
Old March 9th, 2006, 01:36 PM
Brakes
Thanks for the reply: I found out that it is a powermaster (electric motor powering the accumiculator. I never delt with this kind of unit; very different than vacuum. Turbo85
