| General Turbo Buick Tech Technical discussions |
| Sponsored Links |
if you are looking at torx its not an eaton its an auburn , throw it away as i understand they arent rebuildable ,, besides its probably a 30spline (88 up cars and trucks) and youll need to change your axles to use it since you should have 28spline axles
paul -NJ rep MAGNAbuick.com NJ,PA,MD DE -GN/TTA club 86 & 87 GN's A little fun with the GNs at Atco video my 86 10.4 on 93 with a 2004r on radials through the mufflers |
I always thought that the Albrun units had the z clip thing in it and the Eaton has the two springs in theirs.
Mine has the two springs
87 G.N 34,000 miles Rare astro roof, power seats, power windows, rear defogger, aluminum drums KenneBell duel full front ram air spoiler and cannister w/ K&N filter, KB fp/r,KB boost-a-pump,Racetronix fuel pump & hotwire, TPS/TEC, RJC Power Plate, K/M 3" stainless downpipe, duel nozzle SMC alky kit. console switches KenneBell Hi/Lo Pro chip 22#'s of boost on 107 octane AV gas and running duel nozzle SMC alky kit Coming soon custom Ford I/C!!!! 272.2 H.P. & 453.8 lbs at the rear wheels on the third run (lost at least 40 horse from the first to third run, had problems with the dyno) |
mine looks similar to the one on the right but it is flat on the non ring gear side that is where the torx bolts are'
It did have the#'s 14E2J cast in it wish I had a camera I would take a PIC of it
eatons come stock from gm with the s spring , aftermarket eatons have 4 springs and HD eatons have 4 springs but they are heavier springs .
neither have torx holding the case top
ill bet yours looks like this
if so its an auburn heres a link to one on ebay http://cgi.ebay.com/ebaymotors/AUBUR...41387366QQrdZ1
Yep that is it CRAP, CRAP, CRAP, CRAP, here all this time I thought it was an Eaton.
I guess I cant do anything with that. I thought the police cars had Eatons in them CRAP, CRAP, CRAP, CRAP. TIA
ive heard they can be shimmed up ,
Improve Your 10- And 12-Bolt Positraction http://www.hotrod.com/techarticles/42584/ you could always try stiffer springs
is this one any good and can it be rebuilt I could put it in my truck if it is good
they work , the upside to the rebuild problem is they can usually be bought really cheap , so if you need a posi and the splines fit your axles , run with it
also unlike aftermarket eatons your bearings from your current unit will fit also be aware there are two series and three series cariers , if it came from a 256 rear than you cant install the 3.42 ring on it without a spacer and thats not a good thing to do
paul -NJ rep MAGNAbuick.com NJ,PA,MD DE -GN/TTA club 86 & 87 GN's A little fun with the GNs at Atco video my 86 10.4 on 93 with a 2004r on radials through the mufflers Last edited by pacecarta; March 2nd, 2006 at 02:46 PM. |
Can you tell me how many teeth are on a 3,42 gear, if not how can I tell if it is a three series carrier
