Old February 20th, 2006, 12:02 PM
Help picking cam ?
TE-67 (John Craig)
65 inj.
Ported stock heads (stage 3) 1.77/1.50 valves (VPE racing)
Ported intake( VPE racing)
3400-3500 stall 9" cutom billet( Century by Mike Kurtz)
Stock long block (96000 miles)
Looking for something that Idles smooth, pulls good vaccum, quiet, and pulls hard. Roller or flat tappet
Any suggestions ?
87 GN
TE-67 ,60#inj, thunderfab I\C 21 row
218-218 roller
10.60@127 on a rich tune and 90 degrees(new motor)
91 GMC Syclone (all stock) 13.6 @ 97 mph (SOLD)
Old February 20th, 2006, 05:43 PM
jasjamz's Avatar
"Hot Air"
I'm going roller no more flats for me!! Motor should be done in about a week and a half. Billet Comp Cam. 212/212. I'll let you know what happens.
85 T-Top GN
A little bit faster than stock.
Old February 20th, 2006, 09:40 PM
The stall you picked would be a poor match for a cam with good idle characteristics. You could go with a higher duration cam to match the stall, but make sure it has a wide lobe separation to keep overlap to a minimum. Your mph may be down cause of that converter. When you get to about 210 degrees duration, you start losing the smooth idle and high vacuum...well thats about the starting point. But overlap has the most to do with that. Bad thing about reducing overlap by going with wider lobe separation, is that the duration has to go somewhere. Now the intake closes too late after BDC and you bleed off cylinder pressure. Now you have crappy bottom end torque.
You can get some effects of a bigger cam, yet retain a smoother idle by going roller.....since rollers have more radical ramps. The valves spend more time at higher lifts. I would go with a smaller stall (2800-3000) if I were you and go with a roller in the neighborhood of 210 @ .050.
Old February 20th, 2006, 09:51 PM
stock, 204/214, 224/224, 218/212 all idled about the same - don't worry about it. The bigger cams just take a bit longer to clear up as in very low rpm light throttle cruise conditions.
That said, the roller spends more time at higher lifts and you do not have that #3e wipe threat
Old February 20th, 2006, 10:10 PM
Cams
Hi,
Yeah, I keep hearing about flat tappet problems with aftermarket cams, like wiped out no.3 exhaust lobes. I guess I would have to defer to those with more experience, and say to go roller. I understand a stock cam will take you into the low 11s or better with the right setup.You have head work, a big turbo and lots of injector, try mild. Isn't that converter a hassle, or do you run it on the street much? My Kurtz red stripe is 12", only 2800 stall. TCC is messed up, and I miss the lockup. I'm totally street, the car never sees the strip. It's agravating to see all that slip in 4th. I guess emissions are not a factor for you, huh?
***83 Buick Regal TType***
'87 drivetrain and all associated stuff.
Fresh rebuild with Stock block,ARP studs installed with stock caps,align bored to ensure proper fit.Sealed Power forged pistons,stock rods,resized for ARP bolts,stock heads with low cost stainless valves,206/206 Comp flat tappet cam, TA49 turbo,009 injectors,hotwired Walbro 340, Hooker cat back exhaust,K&N filter in stock airbox,Spearco water injection, pretty stock otherwise.
***89 Pontiac Turbo TA***
Walbro 340, Flowmaster muffler, otherwise stock.
***96 Buick Riviera***
3.6" blower pulley,otherwise stock.Runs 15s on a hot day at 4000 plus pounds weight, with the A/C on.
***84 Jeep Cherokee 2door 4x4***
87 Turbo Regal motor,thm700R4,rusty wild child,definitely a restoration awaiting progress.
Old February 20th, 2006, 10:32 PM
Originally Posted by 83ttypecooled
Hi,
I'm leaning towards a roller (212-212) , I just don't want any problems with the swap
The converter I use works good on the street , at the track it flashes to around 4000 rpm at 8 #of boost and drops about 600 rpm between shifts i guess that's in line as far as slippage. I run mostly 1\8 mile (no rollbar)
I have had several people tell me the stock cam is holding down my mph ? As far as emmisons I have been lucky the last couple of years
87 GN
218-218 roller
Old February 20th, 2006, 11:03 PM
Hi insane,
I'm out of my element here,but what goes in, must go out, and I could see where a stock cam would hamper you at the level you have reached. Talk to a cam grinder. How about Comp? They know their stuff.Deer Park, huh? Do you own a TTA as well?
Old February 21st, 2006, 12:11 AM
Quick6'n'-K.C.'s Avatar
wana steal it? meet mr9mm
Trader Rating: (8)
I would go roller...but if there isnt anything wrong with the cam you have now, then id almost leave it.
Your talking 800 for the cam,lifters,valve springs plus a double roller timing set, and then opt for the Roller Rockers.
I found something out tonight, my heads that are ALREADY on my motor need to come off to fit the T&D roller 1.65 rockers...grrrr
How well was the intake ported?
Is there anything else other than the cam that you can upgrade?
The loose non lockup convertor is eating 3 mph of your top end.
I have a 3500 convertor in my daily driver, its a lockup so i dont have any hassles with it, just keeping tires on the back of it!
BW
Old February 21st, 2006, 12:49 AM
I spoke to Jack Cotton a few days ago and I'm going that route as well. I have a good setup and I'm determined to clean up all of the weak spots this year. I'm going with the 212/212 and roller rockers from him.
87 GN bought 6/10/04
Grooms Lvl 3 Short .040, H210/205, PT6152E, VPE Stage 3 Heads/I, 3K 9/12 TC, Extender(19/17), THDP, 65lb Inj, FMIC, ATR 3" Dual Crossflow, Kirban front/seat braces, Bilsteins, UMI UCA/LCA, Trans/LT1, Big Mouth CAI, RJC Boost Cont., Custom Servo, PTS shift kit, RJC DSOP, DS poly Mount.
SOLD - 1/26/2007
Old February 21st, 2006, 06:43 AM
Hi insane,
No but, maybe you know Frank he has one in Deer Park.
87 GN
218-218 roller
Old February 21st, 2006, 06:48 AM
BW
Well, not a expert but the intake sure looked good to me
VPE racing did a good job in my opinion
I have a lockup convertor too , I did not make that real clear.
87 GN
218-218 roller
Old February 21st, 2006, 07:40 AM
Go with a roller! I just wiped out a 6,000 mile motor with a flat tappet.
87 GN GN1s/Intake, 1.55T&Ds, 3200 lockup, Cottons Front Mount, Cold Air Kit, TE 44, 60lb inj., 12.9 &111mph on pump gas and radial tires.
Old February 21st, 2006, 10:33 AM
Thanks, talstar. My motor is out, been trying to decide what to do. I think I will go forged pistons with a stock bore. Your thoughts?
Old February 21st, 2006, 02:29 PM
I think I better go roller
87 GN
218-218 roller
