Blown HG or ??? HELP!
Running car around tonight and during a really nice run, i went to let off the gas and heard a funny noise almost like a backfire but not really loud at all. Well, the car started running really weird at that point and had a bad idle to it and was running really rich it seemed. sitting at idle it had what sounded like a miss to it. searching for idle as well.
well, i started home and started seeing some smoke coming into the car so i pulled over......popped hood and heard what sounded like a ticking noise coming from the drivers side breather. i start to head home as best i could becuase the car is running not so great at this point. Got home popped the hood...and definetly a ticking from the driver breather. Pulled plugs on drivers side.....rear plug.....looks nice...little white....nothing rare......middle plug......oil on it......first plug, normal as well. So, i do a compression check, rear cylinder....155, middle 0, front 152. So, with the signs of NO compression at all...and oil on the plug....could this possibly be just a blown HG still....or am i looking at something worse than just a HG you think? Is it possible a blown HG can cause no comression for the cylinder at all?
Never Enough |
Id think that even with a blown HG, you would still get a reading, just a really low reading. As for the oil on the plug...could be the HG blew in such an area where it entered into an oil galley...oil getting past rings...oil getting past valve stem seal or guide...could be anything. Id open it up and see what I find if it were me. Though, Im no expert on Buicks so dont take it from me. Im sure someone more knowlegable will chime in. Good luck!
84 Ranger Diesel 2.2 4spd 88 Ranger GT 2.9 5spd 88 Ranger GT 2.9 5spd 88 Thunderbird Turbocoupe 2.3T 5spd 88 Mustang GT 5.0 5spd |
Pull the valve cover first, you may have bent/broken an intake pushrod or broken a valvespring. If the valve isn't opening to allow the a/f mixture in, it has nothing to compress, and if a valve is hanging open the compression will go right out the valve. There is also the possibility of a wiped cam, and a remote possibility that you detonated the car for a long time and destroyed a piston. Look at the valvetrain first, then dig deeper if necessary.
Artie Putting the wrench to the bolts at Dynotech Performance '86 GN 6pt rollbar, etc. BPG #1632 Dynos don't win races...see you at the track. |
The only signs i had last night was some oil coming out of the drivers side breather, and a ticking noise from that breather area as well.
When i first got the car, we were dealing with tuning and alot of knock upon first getting it. I am wondering if that knock at that time weaken'd it and now while under high boost, it finally let go. Hopefully the piston and such are good....that is worst case scenario for me. i don't want to have to pull the motor. Hopefully HG or something valvetrain. I plan to dig in this weekend. Was looking to hear some suggestions to what it might possibly be though.
Never Enough |
Similar thing happened to me at the track. Heard a pop and oil blew out of both breathers. Compression test run and #4 had a reading of 5. It turned out the head gasket blew into the valley and pressurized the crankcase whivh caused the oil to spew. It's possible you have a broken valve spring but I'm betting on the head gasket especially if it makes a pfhut pfhut pfhut type of noise.
Royal Foster Littleton, CO. Orig owner '86GN. TE-44, THDP, MSD 50's, Thunder Fab I/C 11.47 @ 117.7 At 5800' |
beleive me, i am praying it is only a HG. i can do that no problem at all. i am jsut worried about something worse....hopefully not though.
Car has JE pistons and such...shoudl be good i woudl think?
Never Enough |
I agree on pulling the VC first! Let us know what you find!
Squid
85 GN, converted to 87 IC'ed stuff. TE-44, 60lb Mototrons, Ron Anderson ported big valve heads, DIY ported stock intake, modded upper plenum, 204/214 cam, 3" THDP, test pipe w/dump, 3.5" to 3" single shot with bullet, HUH? Neal Chance 3,000 converter, wired 340, DIY turbo saver, DIY stock boxed uppers and lowers, poly bushings EVERYWHERE, TLink 4.0, Tach, boost, knock, oil PSI, H20 temp gauges, F body rad, Intrepid dual fans, Turbo Tweak chips!!! DAILY DRIVER: made it from Kansas to Florida, back to Kansas, then to San Diego, CA.
Upon pulling the intake i saw my problem. and pulling off head showed it all.
even though the passenger side showed good compression...thinking i better replace it as well to be safe now. here are a few pics.....
Never Enough |
I can't see 'em either. Who'd you pi$$ off?
Squid
guess i dont' know! they show on the screen for me to open them up just fine...for me anyway.......weird.
anyway, the HG blew completely open into the intake area on the middle cylinder. obviously just the HG. piston is fine as is the cylinder walls and the rings. going to go ahead and replace both sides though while i am in there...just makes sense. doing this makes me wanna get rid of the AC box though, man does that make this a pain on the passenger side!!
Never Enough |
