Oh yeah, I have one more question but this is turbo related. I don't know much about these cars yet and I have never owned a turbo car but the turbo generates A LOT of heat and I mean A LOT. When I turned it on the other day smoke was coming from the turbo, or at least heat. Is it supposed to do that or do I have a major leak somewhere?
1986 GN T-Top sits in the garage all day while I'm at college. So sad
Re: Having a problem reading TPS voltage with voltmeter
and the idle voltage is .40 - .46 a little less than half a volt
86 GN T66DBB , 60lb injectors Turbotweak chip alkycontrol kit ,PTE Front mount,Translator +,KB 70mm TB, RJC power plate , KB adj fuel reg ,THDP, ATR Headers GNX dash H&R mounts, CK Perf trans 3200 single disc Vig converter 87 Turbo T Stock except for hooker cb, mp 3 Dp ,36lb inj & Dutt neck "Horsepower is how fast you hit the wall, torque is how much of the wall you take with you." www.ckperformance.com www.westcoast6s.com |
when you open the throttle slowly the voltage should go from .41 to.42 .43 .44 etc all the way to (should be 5.00 v but never is) 4.65 v Whats the voltage at WOT ?
86 GN T66DBB , 60lb injectors Turbotweak chip alkycontrol kit ,PTE Front mount,Translator +,KB 70mm TB, RJC power plate , KB adj fuel reg ,THDP, ATR Headers GNX dash H&R mounts, CK Perf trans 3200 single disc Vig converter 87 Turbo T Stock except for hooker cb, mp 3 Dp ,36lb inj & Dutt neck "Horsepower is how fast you hit the wall, torque is how much of the wall you take with you." www.ckperformance.com www.westcoast6s.com Last edited by petesgn : May 22nd, 2005 at 09:44 PM. |
TPS voltage
Is the pin on the butterfly shaft bent or broken? Sounds like the TPS actuator is not moving when you push down on the accelerator.
I would suggest removing the TPS get it on your workbench and put a meter on it see if you can get the resistance to change over the sweep area. If not then the part itself needs replacing. HTH Peter |
Nevermind guys. I figured it out. I didn't have the metal piece in front of the pin. My setting at idle is .411 volts and wide open throttle is 4.35 volts. Does that sound okay or should I keep adjusting it?
sounds good
Have fun.
