Bouncing boost needle at heavy part throttle?
I was curious, what would cause this, or if it is normal. If I am light throttle, up to about 10 lbs of boost, the needle is real steady. If I go up above 10 it bounces back and fourth 2-3 psi. WOT, it spikes, and then settles at about 17 where I have it set, but then slowly falls down to 16. I was just curious what would cause this, and if I should be looking for some kind of problem.
Thanks Ben
86 GN - GT67, B&M Trans Cooler, Built Trans w/ many upgraded parts, 3200 Vigilate Stall, CAI, RJC Power Plate, 3.5" THDP, DMH electric cutout, home built 3" mandrel bent exhaust w/ spintech muffler, Translator Plus, 3.5" MAF, q-boost controller, Walbro GSS340M, hotwire kit, 60#injectors, and 275 60 15 ET Street Radials out back. On the way- Powerstroke(mounted, but needs plumbing ran), and Alky. (hopefully ported heads before too long) 13.035 @ 102.28 on stock turbo and ic on pump gas w/ 1.77 60 ft. |
Believe it or not, on my car it was a header leak. The leak was on the passenger side header, right at the flange on the first tube. I had the headers welded up, put them back on and had a ticking sound that was a leak. I thought it may have been a lifter first, but saw where it was turning black on the header where the leak was.
86 GN Hardtop - THDP 3" single catback. 12.96 @ 104, 17 psi, no tune |
If your WG rod is not very tight it can do this also. Needs to at least have some tension on it when at rest.
Rob Rob's HP & PARTY page! '87 Grand National Owned 17 years. 65#inj,HW 307, THDP,V4 IC, GT6131E, alky, no cat, Cold Air kit, Del-alum fronts, Gen2 T+ w/LS1 & LM1/LMA3 WBO2, JJ TB mod, 3000 PTS 9x11conv, Direct Scan, best 1/8th 7.23@96, best 1/4 11.61@119, 1.66 60' '79 10th Anniv. T/A 6.6 all original 4-spd '89 20th Anniv. TTA #426 stock, 15k miles. '99 30th Anniv TA #707 Conv 1 of 535 conv..rarer than a GNX. '95 Trans Am Conv LT1 w/LPE 211/219, LE2 ported heads/intake, and LTs/true duals '94 Silverado LT4 w/LPE 211/219.
Ben
I think I might try doing a top end clean soon and see if I can find smoke coming out anywhere it shouldnt. Mine spikes at wot, but doenst bounce like it does at higher boost in part throttle.
Ben
I plan on doing some nosing around under there over the
weekend. New motor was just installed over the last few months. Are symptoms sound alike. I may swap out the guage. In the process of elimination.
87 T BAL.B.P. 109 RJC Girdled,J.E's Alum.GN1,BGC Intake,70mmT.B.,83lb inj.T72 Q B.B. PTE F.M. Alum. Rad.,MSD-DIS-4.DFI Gen7. 200 Amp. alt. Aeromotive fueled. |
I started mine up and listened, and it sounds like I may have an exhuast leak up front. I know I had a pretty bad one on the crossover pipe, when I first got the car, but I thought I had that fixed. I may see about pulling it down and resealing it while when I put the new stall in tomorrow. If that doesnt help, I will use the top end clean like I mentioned to try to find it.
Ben
I had a simalar problem where my boost needle would shake back and forth. Would never read steady. Tried replacing all the lines thinking it was a vacum leak. Even replaced my actuator thinking that was shot, turned out to be the boost gauge itself. Put a new one on and rock steady needle.
Matthew
87 Grand National --"DCVING" SOLD..... Thanks Chris! 08 Impalla LT--"MD N USA" (Daily Driver) 08 Avalanche LT-- "LUV PITS"(wife's Daily Driver) 89 Formula WS6-- "4GDABDT" 305 3:73's, Hooker exhaust (Wife's Toy!) |
Do you guys have your wastegate holes in exhaust housing ported out? I had this problem but went away after I ported the WG hole.
sounds to me like the seat spring pressure setting on the qboost controller that hold the check ball is doing its job .
i get the same bounce (surge ) with the rjc controller , the spring holds back the pressure signal (to help spool up) with a check ball then once the initial spring pressure is overcome the ball lifts off its seat and it surges the boost (read RJCs controller discription on his site) if im just cruising around and build boost gradually once I hit 10psi it surges and bucks the needle (would make you think theres something wrong) , the controller smoothes out at high boost and works like its not there below 10 psi , is it broke? no, thats the way the grainger valves work if you take the qboost out of the loop you should see the boost surging at part throttle go away.
paul...magnabuick.com NJ rep 86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" HKS ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1 1.42 6.57 104.9 10.4 129.8 now trying out lonnie diers th400 w/tbrake 87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, TT ..11.45 117 1.57 fresh motor .. stock turbo 55# ,TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" Tail,turbosaver all runs on quick chek 93 octane alkycontrol.com progressive meth injection turbotweak.com |
I thought about that, I just didnt know why I would see it before wot, but at wot. I guess that makes since. I still want to check for exhaust leaks though.
Ben
Ben , not sure of the top end clean process, (sorry) but what
exactly is this? how do you perform this type of check. thanks, GUS
Ben
Ben
The grease will leave a nice imprint of its contact patch to the housing. Mark with a permanent marker the outline, then when opening up, making certain you don't carve too close to the line you drew. Remove the turbo and the exhaust housing if possible to open it up to prevent any metal shaving from getting into the turbine housing. Usually opening the WG hole up to 15/16" is sufficient, don't go bigger than what is needed..too big will cause slower spoolup. I used a dremmel and a tungston carbide bit which carved it out pretty quick and easy.
