Old January 23rd, 2005, 01:28 AM
Got hotair?
Anyone with a 4.1 or higher than stock compression, I've got a question.
Is it normal for these things to rev extremely fast? By fast, I mean this motor revs as fast as my old one with the torque convertor disconnected. Normally I would be happy but I'm a little worried I might have too much compression. It's a long story but I had some trouble with the guy that ordered my pistons. Combo is in my sig. I haven't gotten to drive it yet so I have no idea at what boost level it will detonate at. Thanks for any replies.
84 GN. 4.1L girdled with 8.5:1 JEs, 212-212 Comp Cam, GN1s, Ported stock intake, Ford FM IC, 6765DBB, KB headers, Cotton's 3" DP, Innovative Turbo Systems external gate, 60lb injectors, Turbo tweak chip, and a few misc things. No times with new combo yet.
06 Acura TL daily driver.
Old January 23rd, 2005, 07:14 AM
bruce's Avatar
Rest In Peace
The difference from a 3.8 to 4.1L is incredible.
BRC Pistons?, they screwed up my piston order. <sigh>
Old January 23rd, 2005, 11:57 AM
boostingbuick's Avatar
i put a 4.1 in with je pistons. i wouldn't say it revs faster, but keep in mind that the 4.1 has a larger bore and will pump more air than the 3.8, so the turbo wil push more air as well when reving the motor. unless you have an un-none piston i would not worry, sounds like you bought the parts and have the right piston. have fun with 4.1, love mine.
1984 GN Frame off resto. Full wieght with spare tire and jack. All opitions are in working order.
87 Harness and ECM, "484" block 4.1 J&E Pistons, Full floating stock rods, stock crank, Girdle, CHAMPION GNr heads fully ported, T&D shaft mounted, Comp 218-212 roller, 70mm tb, sheet metal upper, 4 inch inlet pipe, Turbonectics 72mm BB q-trim 4 bolt turbo, P.S. intercooler, atr headers, 3.5 dp, custom dual 2.5 stainless exhaust with utralflows
BRF 200r4 built with alto reds, Billet servo, Transgo shift kit, Forward drum, CK's 3600 9 inch nlu, custom pan with rear sump.
GTA fronts with LS1 front brakes and Baer rears. Chrome moly custom upper and lowers with 3.42 gears and moser axles.
