My 87 Turbo T is having some issues. The pulley directly under the alternator (I do believe it is the a/c compressor pulley) won't spin, so I assume the clutches in the compressor have gone bad. I need to bring the car to a shop to get it fixed, and I was wondering if there is a way to run a shorter belt to bypass this pulley so that the car is temporarily drivable. Any ideas?
-Jon 1987 Turbo T, mostly stock - SOLD (need money for school... hopefully another GN in the future) |
you can go to the GM dealer and get an A/C delete pulley and bracket for a mid 80's s-10 pickup i believe its only about $30 or $35 dollars .it will go in place of your A/C compressor and will use a slightly shorter belt.
nick,
FAST COMPANY PERFORMANCE 732-814-8227 http://www.turbotweak.com ![]() MAGNA club member |
So I will need to remove the compressor to put in the A/C delete pulley and bracket, right? Do you know about how much time would be involved in that project? I'm asking because the mechanic that would do the work is doing the job on the side so that I don't have to pay the ridiculous dealership prices. Just wondering. Thanks.
I just need something temporary. The car needs to be mobile just in case the service shop supervisor comes in and doesn't want my car there (in case it's busy or whatever). If there is a way to reroute the serpentine belt so that my alternator and water pump still work, but everything else is disconnected, that is fine. The car would only be in this disabled condition for about a day. I don't want to just run it without any serpentine belt, because the drive is too far to go with no water pump. Any other ideas?
Also, I have a replacement a/c compressor to use, so I will end up fixing it. Basically I'm just looking for a way to have the car mobile enough to get to the shop and to drive around inside the shop. Thanks.
pull your belt off and if the pulley for the AC won't spin freely, it's bad. The AC has a clutch that is on when you kick the AC on, or at startup for a few seconds. The reason for this is that the piston has a pin that goes in it, this is just pressed in (no pin) If it's left to sit for a winter or a long period of time, the piston will freeze and can pull the pin out. If the pulley spins freely and you unplug the eletrical connector to the compressor it shouldnt ever activate that clutch.
89 Astro CS, "In JB Weld we trust" LC2 powered Astro van, give me a few years. |
If I'm not mistaken,cant you remove the clutch drive plate off the compressor and still run the engine, assuming the bearing is good? The bearing and pulley are held on with a snap ring so it wont come off the compressor snout. I did this on my Roadmaster with the HR6 compressor until I could fix it.
Eric Fisher OEM Parts Specialist at GBodyParts.com 252-332-8787 1997 SCCA Regional Champion. 1986 Grand National #38 ESP 86 Grand National 84 Riviera T-Type 82 Regal engineless |
I ended up just towing it to the dealership, then pushing it where it needed to be moved. The new a/c compressor is now installed, but the serpentine belt that I got from Advance AutoParts won't fit. I had two AC Delco belts in my room, but we recently moved and my dad packed all of my things while I was away at school... now the belts are missing. Does anyone know where else I can get the correct belt for the car? I have called two GM dealerships, but both of them will need a few days to order the belt, and I'm leaving again for school on Sunday, so I would like to have everything fixed by then. Thanks for all your help so far, that's why I love this board.
Since you had the new compressor already.....
...the best bet would have been to go ahead and bolt it on. You may have had to leave the old compressor hooked up to the hoses so as not to lose the Freon. I am assuming that the bearing in the compressor clutch went bad. You should be able to get a a new serpentine belt at just about any parts store.
Rickracer www.rickracers.com I am not a GN/TR, Buick V6, or turbo guru by any means, but I am an ASE certified Master tech with 29 years experience. |
I'm still having belt issues. I went to NAPA, they did not have the belt in stock. I went to two Advance Auto Parts, they all had the belt that was the wrong size. I called a few different GM/Buick/Chevy dealerships, none of them have the belt in stock. Does anyone know the Advance Auto Parts part number for our correct belt? They gave me something like 5060640, and it is definately too long to fit the pulleys. Any ideas?
Dayco 5060640 27/32"W x 64"L 6 rib is the replacement belt for 86/87 TRs and the 89 TTA. You may have a smaller crank, water pump &/or alternator pulley. My Kirban crank reduction pulley uses a 1 1/2" shorter belt so the Dayco # would be 5060625 (62 1/2").
HTH - Jimmy
`87 GN T-tops, TE-44, Bluetops, Dutt neck stock IC, 3" DP w/electric cutout, Hooker exhaust, 206 Comp cam, GSS340M/Racetronix wiring, AFPR, Underdrive pulley, Powerplate, TTA wires, HR motor mount, Transgo shift kit, Trans cooler, Drag shocks, Boxed lowers w/poly, F&R body braces/front swaybar delete, Air bags w/spacers, `Glass bumpers, OfficeMax IC scoop, Autometer/VDO gauges, 145 speedo, LT-4 starter, Prostars, MT DR's, Sunoco 94, TurboTweak/Alkycontrol SAC/methanol topjimmy@bex.net Last edited by Topjimmy : January 8th, 2005 at 02:37 PM. |
With the stock settup, the correct belt size is 635K6 (decodes to 63.5" six rib). If you use a 640K6 (that is how long both belts are that you listed), they are .5" too long and will squeal. Don't settle for any belt other than a 635K6. You may have to go with another brand belt.
87 Grand National - TE-44, Mease 3" DP, Mease stock Big-Neck I/C, HotWired Walbro 340, 160F Thermostat, 9" K&N filter, Accufab Adj. FP Regulator, ATR 2.5" SS Exhaust w/ Pit Bull Muffs, Adj. Wastegate, Custom Chip(Thanks Shawn!), Torque Strap, Airbags, Boxed Lower Control Arms, Eibach Pro-Kit Springs, Bilstein shocks. 3690lbs w/ driver. Best ET 12.64 @ 110mph (with a crappy 2.0 60') 08 G8 GT 06 GTO - sold ![]() 97 GTP - sold ![]() GWTRA |
Thanks guys. I ended up finding my two AC Delco belts that I had packed in my basement. (We just moved a month ago and I'm unpacking slowly each time I go back home from school.) I just threw on the Delco and it worked perfectly. Thanks again for all your help, if not for this board I'd be SOL.
I use NAPA 060637. It's a hair shorter than what their computer calls for - that one stretched and the tensioner hit it's limit after just a few weeks..
Scott Barrett, 1986 T-type, Silver. daily driver Turbo Tweak, TA49, Homemade K&N cold air, Alky, Boost Commander, Xtreme shift kit. Other misc. homemade junk. Loose nut behind wheel. |
