I also have the ATR stainless steel'' Single Shot'' system and I've heard that you add another muffler in place of the catalytic converter...but I've never heard one or even seen such a setup, but I think that it makes some sense!..
Is there someone on this board who has done this and could give us a little info?? Claude
1987 Buick Grand National 10.62 e.t. @ 126.76 mph 2002 Ford Thunderbird 2008 Ford F-350 "King Ranch" Crew Cab Dually Pickup 2006 Ford Five Hundred SEL 2001 Saturn SL2 |
I Got Mine from full throttle, 3inch exhust with the muffler he sells & It is ALOT better than ATRs pit bull.. I also had the aero chamber..The drone was so bad....
Mike Muffler is SO much better... I think it's 79 bucks.. |
you dont have a sound bite of that two muffler setup do you? why not just replace the PB and leave the cat?
-jeff
1987 buick grand national. Mods include....te-44,50# injectors, metco adjustable alluminum control arms, stock block bored .030 over, forged pistons, ported heads, 340 fuel pump hotwired, RJC power plate...12.57@112 2.1 60' with pump gas 19# and street tires(not drag radials) http://community.webshots.com/user/iamjeff171 Gig 'Em |
Bruce did you use the 4-1/2" x 9-3/4" ultraflow race muffler or the 6" X 16" round stainless ultraflow?
Thanks, Don
86 T PT 61 turbo, 60# injectors, big neck I/C Best ET 11.10@122.6, 1.51 60' on 9x28 slicks with a new turbotweak chip |
does anyone have a video or something of this exhaust combo?
-jeff
Sometimes the exhaust tips with the resonator section built in reduce the sound just enough to take the "edge" off without adding any restriction. Cheaper than replacing other components in your system.
mlh
white '87 T, lowered, "B" brakes, GW susp, SP204/214,RJC plate, PT6776RS, 2.75" exhaust w/test pipe, 60's, Gen II trans, extender extreme, SMC Alky, SM2, BstC., FMIC, 3K stall. 4.1L build going together slowly. |
do you think i will see much improvement from simply replacing the pit bull with an ultra flow?
-jeff
You probably won't have as many brain cells jarred loose from the drone!!
I went with the magnaflow duals, and the drone, while still there, is a lot less. I've even threw around the idea of putting the stock crossflow back on the car, and installing an electric cutout just after the cat for when I want to play ![]()
Proud owner of a teeny lil' ol' v-6 that has a nasty tendency to STOMP on V-8s!! But, DAMN, is it fun!!!!!!!! "A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, pitch manure, solve equations, analyze a new problem, program a computer, cook a tasty meal, fight efficiently, and die gallantly. Specialization is for insects" |
I have a single shot that modern muscle used to sell
anyways they put an hooker areo chamber and its quite i have no cat and it ALMOST as quite as my buds hooker set up Johnny
Money pit and to much to list... looking for 10s |
