Old October 23rd, 2004, 03:47 PM
DCVING
MT Drag Radials..
I just got a set of 275/50/15 for the Regal. I'm going racing tomorrow and was wondering if anyone else has these and has already been to the track. Just wanted some starting reference points on pressure and heating procedure.
Thanks
Thanks to everyone on this board that's helped me out over the years.
Old October 23rd, 2004, 05:28 PM
Stock crawlin National...
I went 1.55 60' with them but the car just was not making any power. Should go 1.4's once I get it figured out. Anyway I have the 275/60/15's on 10" wide rims though and set the tires at 14psi. I did a pretty good sized burnout but I honestly think it was over kill. I could have probably just done a small burnout and rolled out once I saw smoke. Pulled the tires about a foot and a half off the ground though. I couldnt believe it.
Stock 86 GN, just like the rest of em!
CLICK HERE FOR VIDEO <> CLICK HERE FOR MY FQUICK GARAGE
Old October 23rd, 2004, 06:30 PM
Rob and Steve Crissafulli went 9.38 on them - see the stage II forum. I think Steve told me that he was running 18 psi and that he had gone as low as 12 and they were still ok. He did a pretty mild burnout on that pass.
Regards,
Carl Ijames carl.ijames@verizon.net
Old October 23rd, 2004, 08:52 PM
DCVING
Sounds good guys. Thanks for the input. I'll try the tires around 18-20 psi to start with with a mild burnout.
Fingers are crossed the car will run well. Going for the first time with this car to get some base line numbers. And wouldn't you know the time I get to go, they're having a "street" car race with classes tomorrow.
Man, I hope I don't have the slowest one there. But at least I'll know what I have to work with.
Thanks again
Old October 24th, 2004, 04:28 AM
turbojimmy's Avatar
Supporting Member
I haven't been to the track with mine yet, but on the street I've been runnin 30 lbs. like a "real" radial. Very sticky.
Be sure to let us know how you do - I'm curious as to how the 50s work (I got 50s too).
Jim
1987 GN
1/4: 11.3 @ 117 1/8: 7.2 @ 96
GN Modifications
turbojimmy.com
Old October 24th, 2004, 07:51 AM
TurboJim's Avatar
JCC Racing Member Forum Tech Advisor
Jim, how are these tires on cold ground? I was driving home one night from work on 46, whacked it at 45-50mph cruise and got my car sideways on my nittos. Are the MT's better on cool/cold asphalt?
Jim
Jim Testa
1986 Regal T-Type
www.turbojim.com - its BACK!!
Old October 24th, 2004, 08:38 AM
turbojimmy's Avatar
Supporting Member
Jim,
I've only had them a week or two, but driving around in this 40-degree weather doesn't seem to affect them. They're still sticky. I'm sure at some point the temperature will affect them, but I'm not sure what the magic number is.
Jim
1987 GN
GN Modifications
turbojimmy.com
Old October 24th, 2004, 11:11 PM
anyone have a pick of these on there car?
87 Grand National: 3in THDP to 3in single shot, cold air kit, RJC power plate, Scanmaster2.1, Walbro340, hotwired, Duttweiler neck, MSD 50's, dual airbags, UMI LCA's, ported heads & intake, center main caps, cometics, rocker shaft braces, 208/208 cam and 15 psi.
Thanks Greg and Mitch
Old October 25th, 2004, 04:07 AM
turbojimmy's Avatar
Supporting Member
I only have this one pick:
http://www.turbojimmy.com/MT_radial.jpg
Jim
1987 GN
GN Modifications
turbojimmy.com
Old October 25th, 2004, 07:34 AM
DCVING
Ok guys. Race report.
Ran the tires at 18psi. Mild burnout. Left with 10 psi and they went a 1.77 60ft. I wasn't disappointed with the tires, they seemed to hook the car great. It was my first time out with this car and I think it has a few bugs to work out from it's 13.13 @102
Old October 25th, 2004, 08:21 AM
TURBOV6's Avatar
"SECRET PARTS"
I did the same 1.77 on my 60ft but left at 7 psi. My tire pressure was 18psi. The tires don't like too much boost off the line and too low air pressure. My best time was a 12.3@97 with the 1.77 60ft. Would had probally managed a 11's that night but did not have enough time.
87 Buick Grand National Limit GT6131E, PTE FMIC, 70mm Accufab TB/PTE Plemun, JC power plate and pulleys, RJC boost controller, 65lbs Mototrons, 3.5" Big Mouth cold air kit, ATR 3" downpipe w/ATR external wastegate, ATR 3" dual exhaust, MSD Dis-4HO, Art-Carr #16930 3200 non-lock TC, CAS fuel pressure regulator, Walbro 340 hot wired, Scanmaster 2, QA1's, H&R sway bar, Eibach springs, Air bags. 17" T11's w/315 in the rears! New times 4/1/06 1/4 et 11.38@117.56 mph 1/8 et 7.10@97.57 mph
04 Ford Mustang GT
GNRA Member #47
www.imagestation.com/members/HI87GN
TURBO BUICK MEMBERS ***BEWARE*** OF BUYING OR SELLING TO MEMBER JUSA6!
HID kits for sale http://www.turbobuick.com/forums/par...ml#post1505931
Old October 25th, 2004, 11:15 AM
Jim
TurboJimmy-----that's the look i want---if you happen to remember--can you post the wheel size and backspacing?and tire size-thanks a bunch.
Geoff
1987 GN
Old October 25th, 2004, 11:59 AM
turbojimmy's Avatar
Supporting Member
Geoff
They're 15x8" Draglites with 3.5" BS. Tires are 275/50. Visually they're a lot more appealing than the 275/60 BFGs I had on it and they're stickier.
Jim
1987 GN
GN Modifications
turbojimmy.com
Old October 25th, 2004, 01:01 PM
HighPSI's Avatar
Tech Forum Advisor
The new M/T radials work almost like a slick. At the World Street Finals this weekend, guy were wrunning in the 1.2's with them.
Cal Hartline
HartlinePerformance.com (321)722-1563
Official TSM MPH and ET Record
2008 TSM Norwalk & Cecil Champion- Don Cruz 9.10@149.31
Official TSL MPH and ET Record
2007 TSL & 1998 TSE Champion- Gary Harmon 8.95@155.64
Official TSO MPH and ET Record
2007 TSO Top Gun Points Series Champion & 2004, 2006, 2008 GSCA TSO Champion- Dave Fiscus 8.45@164.59 & 8.31@167.85 TSO Legal (Unofficial)
2006 & 2007 TSM Points Series Champion & 2007 GSCA Champion- Dick Kereny 9.14@148.89 and 8.92@156 TSM Outlaw
2008 TSM GSCA & BPG Champion- Jason White 9.38@147.39
2008 TSL & 2003 TSE Champion- Willard Brown 8.95@154.14
XFI, PTE Turbo, AMS Boost Controller, PTC, on EVERY car listed above
Old October 25th, 2004, 01:08 PM
Trader Rating: (14)
My ET Radials worked as good as my ET Drags. First pass launched at 3lbs netted 1.72 60'. Launched at 5lb next two runs and got a 1.63 and a 1.63. Tires had 18lbs in them with a mild burnout. As a matter of fact I just sold my extra set of drag lites and slicks. No more slicks for me. All three runs were 11.70s. Can't wait to lean on the car.
87 GN T63E, PTE FM, MSD 50's, Atr DP w/ext gate, ATR 2 1/2 duals, 5 disc Vigilante Jimmys trans HR sway bar 11.09@124.01 1.64 60' on Alkycontrol and 275/50/15 MT DRs TT chip
TTA#259 GT3255e, 50lb inj, RJC boost controller, THDP,MT DRs. 11.53@119.2. 1.64 60' Best MPH 121.04 Alky control TT SD chip. PLX SM-AFR WB, Power Logger,Jimmy's trans. 3200 Vigilante 5 disc LU
Old October 25th, 2004, 03:29 PM
Anyone drive in the rain with them yet?
86 WH-1, 30psi/24deg on pump gas Spraying with Razor's PAC www.alkycontrol.com, the only way to go fast on pump gas!!!
Full ATR exh, PTE FM, PTE 70mm Plenum / RJC plate, 70mm TB, TE-60, 50s, BigMouth cold air, LS-1 maf. Best run 11.8/116 on a Stock 99k mile long block, pump gas and Nittos (street trim). Once the mods start, they never end!
Old October 25th, 2004, 03:31 PM
On Lucky #7
Streetknight, I didn't know that was you at Steele. I got to meet the guy in the other blue regal but didn't get a chance to meet you. I was doing my best to help out in the staging lanes with all the classes and was pretty busy.
Nice car and nice runs btw..
Old October 25th, 2004, 04:54 PM
mr_nate's Avatar
Chemically Engineered
I drove in the rain a few times on 'em, before I hydroplanned and wrecked my LS1 F-bod.. lol. If you drive safe, and keep the revs down, they actually handle pretty well in the rain.
1987 GN
  #19 (permalink)
Old October 25th, 2004, 07:18 PM
DCVING
1ARUNEM,
Well it was busy over there. I was disappointed with the car, but it was it's first time out. The other guy's was moving. I'll get there eventually.
  #20 (permalink)
Old October 25th, 2004, 08:06 PM
Jim
Thanks for the info--i noticed you had longer wheel studs---that is not because of this wheel/tire set-up is it?
Geoff
1987 GN
  #21 (permalink)
Old October 25th, 2004, 08:12 PM
PSI FED 6
Anybody using the 16" tires? Will the extra sidewall on the 15" make much of a difference on 11/12 second cars?
-87 Rosewood Turbo T
12.74 @ 104, 1.80 60'
