Old August 30th, 2004, 12:47 PM
the wrath's Avatar
charcoal canister
i am smelling fumes it seems like from the charcoal canister i have it mounted on the frame where the stock air box was can i remove this thing and cap off the line without problems
Old August 30th, 2004, 12:58 PM
I took mine off and blocked off the vacuum lines going to it, works no different..
Old August 30th, 2004, 01:29 PM
, the vehicle should draw out the fuel that accumulates in the canister , while you could disconnect and plug the canisters purge solenoid vac line you shouldnt block the other line , thats your tank vent , without vent your tank could pop when it expands (odds are the spring clmp rubber hose line connections down by the tank would seperate and leak out first ) also you are trying to pull fuel out of the tank , you need air to come in to replace the fuel going out (no air in no fuel out ) except what leaks past the rubber hose connections on the vent line and seeps past the gas cap seal.
change the filter at the bottom of the canister and make sure the solenoid is plugged in and the inline vac check valve is installed properly
paul...magnabuick.com NJ rep
86gn bone stock shortblock ,ported irons ,71Q 75# , V2,ATR 3" HKS, ATR dual340m , 200-4r stageright, AC9"NL , TTWB 6.0, razor dual,msbc-1 ,LC-1..1.42 6.57 104.9 10.4 129.8
now w/ lonnie diers th400 w/brake, vig conv ,cometics 1.48,6.62,103.4,10.46, 126.9
87GN , duttneck, hipro, PTE65+ PP, 62TB, protorque 10.5", hooker duals, razor alky (dual), TTchip.
prev combo stock unopened w/TA49, 50#..1.57, 11.45, 117
now 030, steel mains, dutt cam ,msbc-1 ,LC-1 ,Cottons 3"DP Tial gate ,ported irons/intake ,turbosaver ,TE44,75#inj, 4" zo6 maf , bad 60' ..93.78 ,117.88 11.54 21psi
no race fuel ! no NOS !
all times on 93 octane
big thanks to
julio at alkycontrol.com
eric at turbotweak.com
the wrath's Avatar
charcoal canister
were you getting fumes too i just dont want to block it off and the pressure builds up inside the tank and has no where to go
Old August 30th, 2004, 01:59 PM
the wrath's Avatar
charcoal canister
do these canisters go bad sometimes and how often are you supposed to change the filters under it
