most pumps will look brand new (gasoline bath keeps them really clean ) ,the filter is what gets filthy and black , the stock pump would have the metal isolator can between pump and hanger output pipe , and will also have a black foam insul wrap around it(racetronix now supplies the foam sleeve like the OE had)
, if it was an aftermarket pump from racetronix i beleive it would be dated with a engraving pen , and those aftermarket pumps cant be used with the OE isolator and require a peice of fuel line and clamps to connect the pumps output. dont forget to do the gas filter while your at it , when i dropped my filter and dumped it out it was full of aluminum particles from the pump that wore out . are there any stampings on the pump ? im sure jack from racetronix will chime in , he seems to have radar when you mention his products . thats A+ customer support like none ive ever seen before .
paul...magnabuick.com NJ rep 86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" HKS ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1 1.42 6.57 104.9 10.4 129.8 now trying out lonnie diers th400 w/tbrake 87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, TT ..11.45 117 1.57 fresh motor .. stock turbo 55# ,TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" Tail,turbosaver all runs on quick chek 93 octane alkycontrol.com progressive meth injection turbotweak.com Last edited by pacecarta : August 29th, 2004 at 10:10 PM. |
Re: differnce from regular fuel pump and high flow
Racetronix sales@racetronix.com Fuel Pump System, Hotwire Harness, Injector Harness w/Hotwire, Dual Fan Harness, NEW E-VAC Harness, High-Z Injectors 79# 63# 57# 50# 48# 42# 37# 32# (STOCK), Low-Z Injectors Siemens 55# 72# 83# Delphi 55# 65# 75# 85# 95# NEW 120's |
on the side of the pump under the black sleve i looks like someone engraved it with a pen and it says2699
9134 Also on the injectors it says in really small letters 280 150 218 and above that it says 022 i was just wondering if that meny they where bigger than stock or stock. because i am gonna change my turbo to a ta-49 and i was gonna get 42lbs injectors and a whole slew of other parts. thanks
87 GN, THDP, ATR 3" exhaust,test pipe,55lb injectors, turbonetics TE-44, metco control arms, walbro fuel pump, razors alky,auburn posi,2800 stall,russ merrit tranny, TA heades best et 12.41@110 1985 cutlass supreme mini tubbed,8pt cage,spool,400 turbo tranny,455ci big block olds, 100 shot( FOR SALE) 99 camaro SS ls1 6spd borla exhaust, cme tips,kooks long tubes,fast 90 mm intake and 90 mm throttle body,13.30@108 |
the pump is the OE , found the one i pulled out of mine and it has the same 2699 engraved on it
those injectors are the stockers - 28#
paul...magnabuick.com NJ rep 86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" HKS ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1 1.42 6.57 104.9 10.4 129.8 now trying out lonnie diers th400 w/tbrake 87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, TT ..11.45 117 1.57 fresh motor .. stock turbo 55# ,TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" Tail,turbosaver all runs on quick chek 93 octane alkycontrol.com progressive meth injection turbotweak.com Last edited by pacecarta : August 31st, 2004 at 12:09 PM. |
If you wish to upgrade here are two items to consider:
http://www.racetronix.com/Racetronix..._Sale-42s.html http://www.racetronix.com/RX-G7-FPKG.html
The fuel pressure will track manifold pressure.
The pressure will not stay put.
