Danny I have done it and it is awesome.That 49 will spool yesterday if you get what I'm saying.The 3200 also leaves lots of room for upgrading later.I went from a 49 to a 52 and now I have the 63 and they all worked great with mine.No complaints here.The only problem you might have is keeping radials from breaking loose at just about anytime you go WOT,even in street trim.
Patrick
TA perf. Motor built by ArizonaGN (Thanks Nick) PT76GTS,RJC intercooler,F.A.S.T XFI,Champion GN1 intake,83#,TA block and heads,224/224 solid roller,T&D 1.65 rockers,CP pistons,Total seal rings,ATR rods,Eagle crank,MSD billet dist.,7AL-2 ignition,PTC converter,TH400 w/T-Brake,ATR headers & exhaust |
well i don't quite fit your criteria but im running a pte44 .63 housing with a 3200 stall 9/11 and wow its instantly spooled and its a blast on the street. Radials were useless so i run on 275/60 nittos and they actually hook well on the street. Like stated you can always upgrade turbos later as well.
11.255 at 121.5 (best mph:124.1) 87 GN, PT61, mototron 60#s .030 over, TRW pistons, ported and polished iron heads, with Manley 1.77, 1.50 valves, ported intake, 204/214, ATR headers, 2.5" exhaust, 3" ATR DP ,ebay fmic, moser axles, LT1 MAF, fuel mods, home built billet tranny and a 3400 CK 10.5. air bags and umi lowers CAs ATR rear sway bar, PAC alky kit, 1LE 36mm front sway bar, QA1 economy coil overs, Howe longer ball joints,bilsteins, Richmond 3.23s, eaton posi, ls1 brakes. Dads 86 GN-ported heads, 204/214, ATR headers/exhaust, PT61, 60s, alky, 3400 9/11, ebay front mount (supporting mods...) 11.5 at 124.1 mph 24 psi. modded 85 GN and now a new 87 T. |
Patrick any problems with traction at the drag strip with using the 3200? I currently use the ET streets.
It might be scary if I get caught in the rain though, huh? Dannyo
87 Turbo T - TA49, Walbro 340, adj fpr, RJC Power Plate, ScanMaster2, MSD 50's, Trans +, LT1 MAF, extender chip, RJC FM Intercooler, 3" THDP & Big Mouth cold air kit, 3200 Stall Precision Converter. Fastest ET 1/4 mile - 11.50 at 114 MPH |
I just installed a 10"/3,200 Pat's converter last weekend and it works great with my TA-49. No track experience with the converter yet.
Jim: 87 GN with: TE-61/PTE .63 housing - ported stock heads - Erson 208 cam - Speed Pro forged pistons - PTS trans. & 9/11 converter - MSD 60# - CAS V-4 - 3" DP - ATR 2.5" exhaust - 62 JJ TB/stock plenum - RJC power plate - Gen II w/LS-1 MAF/PL - SMC progressive alcohol - Walbro 340 - and Extender G chip with 26*/22* timing. Best 1/8 mile run: 6.904 @ 100.04 with 1.535 60'. |
Not really any problems at the strip with the right tires.I went to Kennedale one time on radials and leaving from idle I spun past half track before it hooked.ET streets are all I ran after that and they are ok on dry streets.I have been caught in the rain with them and anything past 10mph is way scary.I don't have any experience with drag radials,so i do not know how they act in the rain.You will have no driveability problems at part throttle.You would just have to be very selective of where,when,and under what conditions you go WOT.
BTW I did the 3200 vigilante back when my car was set up just like yours and dropped more than a few tenths in the 1/8.
