This may seem like a stupid question...but I just received my ARP headbolts from John's Performance...I am putting my factory stock unported heads back on with the Felpro 9441PT gaskets...I have sanded down the block and heads and have wiped them down with laquer thinner...now the head bolts got me confused...there's 3 different lengths to them...there's long, medium and just a bit smaller than medium sized...i have 8 of the smallest bolts, 4 of the medium and 4 of the long
i forgot where each bolt goes...like where do the long ones go...etc...also where do you buy the ARP thread sealer??? i was expecting to get it with the package of bolts but to no avail...I do NOT want to screw this up! ![]()
![]() -Don 87 GN 11.07 @ 125 mph (old combo w/ PT67 DBB, GN1 heads, 120k mile stock shortblock, ended up splitting block )Now running a 44k original mile stock longblock, stock turbo (for now), PTE FMIC, 60 lb inj, TT chip, TA Perf 3" DP, GNX style VDO dash, Vince Janis built 200-4R w/ 10" 3400 n-l stall (can you say NO turbo lag? LOL) Words of experience: Going fast was nice, but when your car is down every single year because you broke something, it isn't fun anymore and unless money grows on trees at your house, you don't regret going back to stock, and being able to drive and enjoy your car again
Which ARP Bolt Goes Where?
I just went through this drill...
The shortest bolts go at the bottom portion of the head near the exhaust ports (4 per side.) The medium length bolts go in the rocker arm area, 2 per side. Put them in the front and the rear holes. The longest bolts go in the rocker arm area, 2 per side. Install in the 2 middle holes. Don't forget the special washers, lightly oiled. Make sure the bevel is toward the bolt. I won't recommend a torque. 82 ft-lbs works for me, but do a search, there are lots of opinions on this one. The local speed shop should have the thread sealer. HTH Peter PS - Thanks for the response to my Poston header question from last week! |
one more question...the instructions say that you should use ARP thread sealant...do I HAVE to use it? nobody around here has that stuff...it didn't come with my bolts...what can I substitute for the thread sealer? also when they say use oil on the bolt heads and washers, what kind of oil? 10w30???
I personally wouldn't sub. the sealer. Summit, Jegs has the sealer.10w -30 will work.
86 T-Type Best E.T. 11.34 @ 120 MPH with V-6 10.00@133 SBC Single Turbo 87 GN Stock 68 Camaro 96 Chevy 4x4 Extra Cab 6" Pro Comp Lift,35"BFG's Click here for pics |
well here's what I did today...
I bought some Permatex high temp -white- thread sealer (the little tube)...this was after doing vigorous research of many others using this stuff on their headbolt threads... so i applied the thread sealer on ALL threads of the head bolts very well and even on the VERY end of the headbolt...installed washers with the bevel facing the head of the bolt...applied a dab of 10w30 oil under the head and washers... i used an air compressor to blow out all the crap in the holes, i chased each bolt hole with a long head bolt to clean out all the crap that was in the threads as best as i could...there's barely (if any) coolant in the block which still sits in the engine compartment...but oil is drained, in fact i have the oil pan off right now doing a rear main seal...so whatever drops into the motor it really will fall to the floor (including whatever gets in the cylinder walls) i also wiped down the block and head surfaces with paint thinner, also did the cylinder walls and the tops of the pistons...installed headgaskets bone dry (felpro 9441PT gaskets btw) now on to the bolt installation torqued the first sequence just by hand and made each bolt "snug" with a regular socket wrench...then i proceeded to get the torque wrench out and torque all bolts in sequence first to 30 ft lbs...waited 10 minutes...second time around it was 50 ft lbs...waited another 10 minutes...third time went 70 foot lbs...waited 10 minutes...LAST round went 85 foot lbs exactly on each bolt and haven't touched them since did i do everything correctly??? i sure hope so! now when i get all this stuff back on and get ready to fire up the motor...should i just fill my radiator with pure water to flush out the block of all the crap that fell in the holes??? then after i drain the water go with a 50/50? i also planned on driving the car down the highway for a little bit with fresh oil and let the oil flush out the motor of all contaminants...and then drain the oil and change it right away...is this a good idea??? anything else i should know about when starting this thing like valve adjustment and TDC??? sorry this is so long just need help, first time taking apart motor and i don't want to screw this up... this motor will not be even ready to fire for another month so the heads will have plenty of time to seat and cure properly...
GNergy is 100% correct by backing them up 1/4 turn then retorque to ARP's recommendation. This is done to remove any surface imperfections off the washer, head and the bottom of the bolt head. By the way do you have Pro-performance ARP 12 pt 190,000 psi bolts or studs? ARP recommends 90 ft pounds with those bolts with 30w oil. Be sure to follow ARP recommendation on those bolts.. Good luck...
so how long do i have to wait until i need to re-torque those bolts??? i haven't touched them yet...like i said the car won't even be started until the end of this month...do i do it now or after i heat cycle the motor a few times????
i got the ARP 170,000 psi bolts with washers...6 pt...used Permatex #2 high temp white teflon thread sealer...it says on the package that this stuff can be movable after setting...which means i should be ok re-torquing...
You do it now before you start it up 3 times then you don't have to do it later.
Tarey D.
87GN Stock Motor 56Kmi. TE-60, #50msds,62mmTB by J Jackson.3.5"MAF,Powerplate,Chip by "BRUCE". Hotwired XP. PTE-FM. SMC-Alky BGC.Elbow&3in.DP.& 2 3/4in.Duals Boxed Uprs&Lwrs Urethane bush. Mike Kurtz Racing Trans. 2800stall.KB.adj FP.reg.GNX braces. Global West Control arms, 12in. Discs. Kirbans chrome M&A valve covers, tranny pan,diff.cover.Cyberdyne Digital dash.BE-Kool rad.Spal dual fans.Spectre Braided Stainless hoses&Aluminum fittings, Translator. Scanmaster 2, Westech EGT Simmons Wheels, Urethane body bushings, ATR bar. |
Actually, I'd remove the bolts and mark which hole each came out of. For three reasons, first the holes weren't properly tap-cleaned, second the sealer shouldn't have been applied to all the threads, and third the threads have already began to mate. Remove the heads. This time tap-clean the holes pushing down on the tap going in and pulling up coming out, cleaning (brushing) the tap, and repeating until the holes are shiny clean. Reclean the bottom of the head, if even a finger touched them, with brake cleaner sprayed on a clean rag. Apply the sealer to only the bottom 2 or three threads and oil to the rest (same for the washers and bottom of bolt heads). Torque in sequence to the 85#. Let sit OVERNIGHT to compress the gasket. The next day, one-by-one, loosen 30 degrees and retorque to 85, i.e., DON'T loosen all at once and retorque all at once. Now you can refill with coolant. Drive it easy for a few hundred miles to allow the gasket to bond. Do it once and do it right. Good Luck, Joel
87 GN, Tomka cold air, translator, 50's with Tweak alky/93 chip, PTA49, V4, Razor's alky, Precision plenum w/PP, ported intake w/o EGR tower, Champion irons, TH downpipe, ATR 2 1/2 w/pittbulls, gutted cat, BFG Drag 275/50/15's on Cragar Streetlite II's, Blaupunkt Casa Blanca with amp/subwoofer, Joe Newmann paint job. "When the turbo spins the bull**** ends!!!" Last edited by TurboGN : April 2nd, 2004 at 11:47 AM. |
I sure hope you cleaned all the trash from the area between the piston top and the first ring groove. You would need to clean it by blowng it out and rotating the engine a litlte to uncover the hiden trash. If you did not get all the trash from the sanding your cylinder walls are not going to be happy.
87GN 35K miles, Blueprinted Block with Steel Main Caps, ARP Main Studs, TRW Forged Pistons, JE Pins, Blueprinted Rods with ARP 2000 Rod bolts, Turbo Crank Indexed and Corrected , FM Main and Rod bearings, All Parts Balanced within 1/4 gram. BHJ SFI Damper and JW SFI "The Wheel" Flexplate, Comp 212/212 Camshaft and Lifters, Rollmaster Timing Set .002 Undersize, TA Perf Cam Bearings, Oil System Mods, PTE Oil System, Champion CNC Iron Heads, T&D Roller Rockers,Champion CNC Intake, 70mm Acufab T-B, 70mm PTE Plenum,RJC Power plate, PT-67 Turbo, PTE Front Mount, SMC Dual Nozzle Alky, 75# Injectors ,Extender Extreme Chip, LS-1 Mass Air w/ 4 " ends,Translator+ , Custom CPT ( The Real Art Carr) 3600 stall Billet front cover, trick internals non lock up Converter, PTS Bat Brake , PTS Deep Pan, HR Parts N' Stuff Upper and lower control arms, ATR rear sway bar |
11.255 at 121.5 (best mph:124.1) 87 GN, PT61, mototron 60#s .030 over, TRW pistons, ported and polished iron heads, with Manley 1.77, 1.50 valves, ported intake, 204/214, ATR headers, 2.5" exhaust, 3" ATR DP ,ebay fmic, moser axles, LT1 MAF, fuel mods, home built billet tranny and a 3400 CK 10.5. air bags and umi lowers CAs ATR rear sway bar, PAC alky kit, 1LE 36mm front sway bar, QA1 economy coil overs, Howe longer ball joints,bilsteins, Richmond 3.23s, eaton posi, ls1 brakes. Dads 86 GN-ported heads, 204/214, ATR headers/exhaust, PT61, 60s, alky, 3400 9/11, ebay front mount (supporting mods...) 11.5 at 124.1 mph 24 psi. modded 85 GN and now a new 87 T. |
as for the bolt holes...first i connected an air compressor to the holes and blew everything out...then i ran a long bolt through all the threads (same as using a tap i would think) to get anything that didn't come clean...then i hooked up the air compressor once more and blew out the holes...should be clean in there, i am not removing the head again because i have already torqued it down, then i would have to throw away a perfectly new gasket... what's wrong with putting sealer on ALL the threads? according to everything i searched and read everyone does this...i think i did everything correctly...it's not like i am running at the dragstrip every single day with this car pushing it to the max...it's a 99% street car that will see occasional 23-25 psi blasts on a bone stock motor
don_3d,
You are fine putting thread sealer on all the threads, no harm done. However using a bottom tap to clean the holes out is important before you do so. Using an old head bolt to clean out the threads is not a good way to do it. If you run a bottom tap down and up the blind hole you will see what I mean. I am not saying you MUST do this but it is just good practice. HTH.. Mike Banas 87GN |
well this bolt that i used is not an old head bolt...rather it's threaded all the way and i guess i was "tapping" and didn't know it...needless to say the threads were mostly clean anyways...i just finished installing the driver side head...all the bolts went in smoothly with no problems...tightened then again the same way i did before, just snug with a socket wrench, 30 lbs, 50 lbs, 70 lbs, and finally 85 lbs exactly...
now the passenger side head has been sitting for 24 hours now and i haven't touched the bolts...should i back them up and do them all at 85 again? how many times should i do this and what is the waiting period inbetween them? man i tell you what, 85 lbs of torque is ALOT of torque! there's no way those heads have a chance of lifting... |
Don't back them off after 24 hours. You will destroy the seal you made with the thread sealant. When you torque the head initially that is when you should do the 3 cycles.
