General Turbo Buick Tech Technical discussions
Old October 22nd, 2003, 02:12 AM
Belltech for serious drag racing
I have a Belltech kit that I decided not to put on my driver.
I was wandering if anyone has tried one on a race car. Im talking about the 2" fro. spindles and the 1.5" drop rear springs.
Other than changing up the Instant center a little, what other problems would one run in to at the track with it.
It would look sooo sweet on my white car with the Welds.
I am currently running:
CE 90/10's in font
No front sway bar
ATR rear bar
BMR non-adj tubular upper/lower CA's
Stock springs all around
airbags
28/10/15 slick
Anyone tried to go fast with a lowered car? I had spindles on my old SII car, but it was a ladder bar setup w/ adj. coil-overs in back. It worked fine.
TIA,
John
John Cangelosi
White '86 Buick T-type
Sponsored Links
Old October 22nd, 2003, 02:43 AM
geno's Avatar
9sec 17MPG Street Car
I have the 2" dropped spindles and the 1.5 rears by Belltech on my car I had to chop a 1/2 coil out of the rears to make it sit right because i used the old front springs. Then after i got the I/C right and went to a Wolfe bar ive had a best 60ft of 1.36 off the foot brake. I run the 90/10 shocks but the big thing was notching the frame rails for my 12.5 X 28 ET streets and 10.5X28 slicks on 10" rims Also i needed to change my front wheels This maybe only on my car with Wilwood front brakes that push out the front wheels 1/2" Its a bitch to get it real low without rubbing and i also jacked the Q-panels out 1" to clear the wheel opening lips after rolling the lip... I wish it was lower
http://www.turbobuick.com/forums/pac...-update-9.html
Gene Fleury
86 Green GN Off Center Stage 2 (9.7 sec 140MPH street car 17 MPG)
(10.17 pump gas)
POS Buick With Stage 2 on center(Looking for high 7,s) In work
67 Chevelle Convert 283 PG
Old October 22nd, 2003, 07:20 AM
HighPSI's Avatar
Tech Forum Advisor
I used the spindles on my car
Cal Hartline
www.HartlinePerformance.com
(321)722-1563
Official TSM MPH & ET Records
2008 TSM Norwalk and 2007 & 2009 Reynolds Champion- Don Cruz 8.894@152.93
Official TSL MPH & ET Record
2007 TSL Champion- Gary Harmon 8.95@155.64 & 8.50@161 TSL-O
Official TSO MPH & ET Record & Fastest Stock Susp. Buick V6
2009 TSO Top Gun Points Series Champion
2009 Norwalk & Reynolds Champion- Tony Gomes 7.971@175.47
2008 TSM Points Series Champion
GSCA & BPG Champion- Jason White 9.34@147.39
2008 TSL Champion
Willard Brown 8.95@154.14
2007 TSO Top Gun Points Series Champion
2004, 2006, 2008 GSCA TSO Champion- Dave Fiscus 7.979@176.74
XFI, PTE Turbo, AMS 1000 Boost Controller, PTC, on EVERY car listed above
Old October 22nd, 2003, 02:13 PM
Thanks guys.
I think I will give it a whirl.
Old October 22nd, 2003, 05:31 PM
iamjeff's Avatar
next gen buick enthusiast
i put the belltech 2" drop spindles on the front of my project car, but i havent got anything for the back yet. what do ya'll suggest?
-jeff
1987 buick grand national.
Mods include....te-44,50# injectors, metco adjustable alluminum control arms, stock block bored .030 over, forged pistons, ported heads, 340 fuel pump hotwired, RJC power plate, precision converter...12.0@120, sad 1.9 60'
http://community.webshots.com/user/iamjeff171
BB code is On
