Not sure if I recall right, but I think that is where mines sits 13.5-.8 and I have a new coil.
Jason
"If everything seems under control, you're just not going fast enough." - Mario Andretti •55 lbs. injectors •Holly fuel pump (255 LPH) •Kenne Bell adjustable fuel regulator •Ext. chip •4" induction •Cotton’s front-mount intercooler •Ramchargers translator+ w/ 3.5" LS1 MAF sensor •Scanmaster II •Turbonetics BB T72 Q-Trim w/ PTE exhaust housing •Full Art Carr Transmission (Rebuild, Summer 03) •Art Carr 9” Non-lockup 2800 Stall •Accufab plenum (70 mm) w/ throttle body (70 mm) •RJC powerplate •ATR duel 2 ˝ inch exhaust •3" DP w/ Turbonetics Racegate •Be Cool radiator •Hotchkis passenger side air bag •Front & rear Bilstein shock •Ported and polished stock heads & lower intake (all port matched) •212/212 Cam Best Time: 11.918 @ 118.66 (3 lbs Launch suck 2.02 60' on 2800 stall, going to 3600 soon) |
Your alt output is sufficient. 13.5 - 13.8 is lots, the more the merrier of course. Your popping problem lies somewhere else. Do a search on the subject as there have been many a thread, and many ideas on solving posted on this board...you are not alone in this problem.
Good Luck, Jim |
poping as in a cylinder isnt lighting off? if this is what you mean then i would try droping down the gap on the plugs so that youll be assured that each and every cylinder lights off when its supposed to...even under extreme ammounts of pressure.just a thought.
oh and if that doesnt help, then change over to solid core plug wires.
i have a motor and trans ...YESS and now a 87 GN that'll get a 8 point and an engine, somtime....i hope |
I am not sure what the popping was exactly. At the time I thought possible knock and wasn't about to keep my foot in it. Since then, I have changed the plugs and wires. I gapped them at 032" just for the heck of it. I had Reds wires on the car but they didn't last. They tore apart when I took them off. I put a new set of MSD 8.5mm wires on. As I said. I only got to run at Norwalk in early May this year and that was it. It has been since then that I have changed the Wires and Plugs, so the problem may not exist any more. I was just searchng for options or similar experiences.
86 GN, TE44,Champion Iron Heads, 3"SS DP, Lucas 40lb injectors, 206/206 Comp Cam, Red's XP pump hotwired, cold air intake, 9x11 2800-3200 Stall Converter, Scanmaster, Direct Scan, RJC Power Plate, Air Bag. Hooker Cat back 11.86@112mph - 18lbs of boost 2006 Grand Prix GT, 3800 Supercharged - 15.13@89mph |
Way back when, up through maybe the early '90s, alternator regulators were set to give 13.8 V. Battery chemistry has changed a little since then, and nowadays most alternators are set to give more like 14.2 V. Depending on when and if your alternator has been replaced or rebuilt, you could have either one. And then, depending on where you are checking the voltage, you will have the wiring losses as well. With every thing on the car powered up there will be 0.1-0.3 V drop just across the charging wire that runs from alternator to battery, and then another 0.2-0.5 V getting through the fusebox and out to a high draw accessory such as the radiator fan or headlights.
Regards, Carl Ijames carl.ijames@verizon.net |
huh...well if your running 8.5's on a .32" gap then your car shouldnt have any problem firing. what boost are you running at the track,if its super high then that could be a potential cause of a cylinder not lighting,but as you may well know every car is different.on mine i was running 19 lbs on a gap of .65 with 8.5 wires and i never had any backfire/misfire problems.keep us informed
if you go to te track again and it still does it then i would drop the gap down to .25" just to rule out an ignition problem.. yes a smaller gap will result in slower et's, but if a super small gap stops your problem then that will give you a direction to go in..
