Go Back   TurboBuick.Com > Tech Arena > Engine Tech
Old July 21st, 2008, 08:34 PM
Just another kinky six
4.1 pistons for 4" bore??
Does anyone have a part # or manufacturer that makes a 4 inch bore piston for the 4.1 block?
Old July 21st, 2008, 09:13 PM
summit H471C
87 GN, BB66,3000 westcoast stall,hotwire,walbro,DW,210/215 roller,4340 crank,65lb injt,homemade alky,Scan2.1. ect.
Old July 21st, 2008, 09:40 PM
the 471s are hyper cast pistons-can be brittle , I have a forged set of Ross 4.00" pistons for a striker combo for $300. Shipped that I'm not going to be using
87 Stage2 in the works!
Old July 22nd, 2008, 10:32 AM
Nick Micale's Avatar
Originally Posted by 49-blues View Post
the 471s are hyper cast pistons-can be brittle , I have a forged set of Ross 4.00" pistons for a stroker combo for $300. Shipped that I'm not going to be using
If they are new, as in never installed, send me the complete spec sheet on them. If they are like what we need, can use them, thanks.
Nick Micale
3334 W. Marconi Ave
Phoenix, AZ 85053
602-866-9908
Home of the world's fastest stock block Buick!
www.arizonaGN.net
arizonagn@qwest.net
Old July 22nd, 2008, 10:40 AM
Nick- they are new-i know the comp height is 1.200"-i can get the rest of the specs on thursday-they re up at my garage. i also have a brand new set of Diamonds 4.00" bore with a 1.640" comp height- not sure what combination of stroke and rod length you would need for these and there are 8 diamonds in total. also looking for $300. shipped for these also. The original post should have read "stroker combo" not striker.
Old July 22nd, 2008, 10:56 AM
OK no rush, thanks, just get me the spec sheet on the Ross pistons as we do use them as well as CP.
Nick Micale
3334 W. Marconi Ave
Phoenix, AZ 85053
602-866-9908
www.arizonaGN.net
arizonagn@qwest.net
Old July 22nd, 2008, 03:59 PM
Forged J E pistons
Piston P/N 271718.
Pins 940-2750-16-51S
Rings J100F1-4000-5
Old July 22nd, 2008, 07:57 PM
Let's try this again. What's a striker combo? And what I've been thinking is there a simple replacement piston that's for an engine with a 4" bore that would be able to go into the 4.1 bored to 4"? I was thinking that I would use a 3.0 rod (6.33") instead of the stock rod. Kinda like using a 6" rod in a 350 chevy. Increasing power levels and allowing a different rotating mass.
Old July 22nd, 2008, 08:03 PM
MISSING 2 CYLINDERS???
Charlie, Webber has an off the shelf Wiseco for the 4.1, I'm thinking it's .035 over which would give you a 4" bore. I wish other vendors carried something off the shelf in a J&E....there is a demand.
Scott Lambert
87 GN 32k Original Owner
GT6131e, Crane Billet Roller 212/210, 3" SS THDP, 9" Art Carr, 57lb inj, 22 Row Thunder Fab, Hooker Cat Back, Hot wired Fuel pump, Adj fuel reg, Bell Mouthed TB, Stock location K+N w/ Postons base lid, Scanmaster, Ported Big Valve Heads- All Studed
86 T-Type Now a Parts Car
87 Turbo T Astro-Roof Chrome Trim
87 Turbo T Solid Roof White w/ Blk Trim-Mama's New Toy
Old July 23rd, 2008, 11:09 AM
Thanks getchasum. I've been doing some homework on my idea. The stock piston compression height is 1.825.(3.8 or 4.1) A .125 over 283 piston has the same height which is a 302 chevy. The 300 ford inline is the same as well. If you substitute the 3.0L rod your pch changes to 1.53 which is the same as a sbc 350. You can check out the findings here.
United Engine and Machine Co.
They have some interesting calculators you can use to see what you want as far as a piston. Since I'm not planning to do a 10 sec or faster car I'm thinking about the 3.0 rods for better power. After all changing to a 6" rod in a sbc does give better power due to the change in the rotating mass and rod to stroke ratio change. My biggest question is whether the 3.0 rod is strong enough to hold up to a turbo. Does anyone know anything about them? I'm not planning a whole lot of boost in this thing but cam, ported heads and adjustable boost is a must. I'm looking for a fun car that sees the track once in a while, not a trailer queen.
Old July 23rd, 2008, 11:25 AM
Dave Williams proposed this as a possibility (the 3.0 rod/chevy piston) at least 12 years ago on the old gnttype mailing list. Someone posted a picture of a 3.0 rod somewhere several years ago and it looked a lot thinner and weaker to the eye than the 3.8 turbo rod. I don't know anyone who has actually built a 4.1 this way.
Regards,
Carl Ijames carl.ijames@verizon.net
Old July 23rd, 2008, 04:43 PM
wickett- whats the horsepower rating on those je pins?
Old July 23rd, 2008, 06:36 PM
I have no idea on HP rating but their Forged J E'S so I would think they could take a real good beating
I all for $699.00 + shipping
Forged J E pistons
Piston P/N 271718.
Rings J100F1-4000-5
Old July 27th, 2008, 09:19 AM
I too have been hoarding a set of 3.0 rods and a 4.1 block for years. I keep thinking about it and have never got to building it yet. I guess I am waiting for someone else to do it first!
I dont think the 3.0 rods are much different than the 3.8 rods as far as a visual check of the "beefiness" goes. I thought a good set of rod bolts and see what happens. I don't want to make huge power either. so I thought about hypers. but I guess I never thought about small block pistons in the sense of cost (i.e. cheap forged) before either. Hummmm......
83 T with all of the 87 goodies! but still not much faster than original!!
Last edited by ATEURV8 : July 27th, 2008 at 09:20 AM. Reason: I need to learn to spell one of these days!
Old July 27th, 2008, 09:30 AM
Nick the specs on the Ross pistons are: 4.00" bore , 1.205 comp height , .927 pin dia , 2.500" pin length , 100M # 67045A .The pin does not go into the bottom ringland. Just pistons- no pins or locks.
Old July 27th, 2008, 11:37 AM
If the "#67045A" is the job number, we can check with Ross and see if these have the same specs we use as the ring land thickness and other items need to be within our requirements, thanks.
Nick Micale
3334 W. Marconi Ave
Phoenix, AZ 85053
602-866-9908
www.arizonaGN.net
arizonagn@qwest.net
Old July 27th, 2008, 12:09 PM
I just want to comment on pistons for 4.1's. Since there never was a production 4.1 built for a turbo application, the replacement pistons were never available from the factory or aftermarket.
We have done many 4.1 turbo engines, and only use a custom piston with the proper ring lands, dish CC, pin location and other specs.
Having rebuilt some customer's engines, we have found the off-the-shelf pistons do "work", but performance is compromised especially if other machining is not done to compensate.
For a street build, the pistons available probably will do fine. For a performance build, they may not perform to expectation, or may not be as durable.
Most all of our engines have custom pistons, built to our specs by both CP and Ross. Explaining to the customer that when spending thousands of $$$$ on an engine build, getting the extra few $$ to get the best piston available is usually easy.
Just to verify our turbo Buick engine experience, we have 12 builds currently in process [most from out of state] including 2 TA blocks, 2 stage II, 1 stage I and the rest 109 blocks. At this rate, we will reach our grand total of 500 Buick engines built by the end of the year.
Oh, turn around time is usually 6-8 weeks depending on parts and special needs since we do ALL machining in-house. Our best time was 5 days for a GNX re-build!
Nick Micale
3334 W. Marconi Ave
Phoenix, AZ 85053
602-866-9908
www.arizonaGN.net
arizonagn@qwest.net
Old July 27th, 2008, 04:41 PM
Ateurv8, if you have a camera and a set of calipers post a pic and some differences in size at locations on the rod. I'd be interested in seeing the diff myself.
  #19 (permalink)
Old July 27th, 2008, 06:31 PM
Nick that 500 milestone is very impressive.
  #20 (permalink)
Old July 28th, 2008, 12:38 AM
I will but I won't be back home till Sunday the 3rd. If I don't post it soon after that, stay on me! I tend to have a short memory!!
What were we talkin about???
  #21 (permalink)
Old July 28th, 2008, 06:39 PM
Nick-that number should be the job number its scatched into each piston.
________
