Go Back   TurboBuick.Com > Tech Arena > E85 Technical Forum
Old March 13th, 2008, 06:09 PM
Lightbulb 600+ rwhp on E85, what would I need for convesion
As an experiment, Dale Cherry of The Injection Connection and Bill Moss did an E85 tune for me as part of my transition to XFI. E85 alone made more than 600 rwhp (more than pump gas and alchy) and I'm toying with the idea of doing an E85 conversion since I have an E85 pump right near my house. Presumably I could spray alchy on top of the E85 and coax even more out of her.
I found one good FAQ from the Scooby guys here, but has anyone carefully thought through what we'd need to convert to E85? Found a stainless steel tank that fits in the stock location? See Rick's for one general source)?
I'm thinking in addition to the tank and fuel lines (teflon would be used), all of the rubber connections (including injector o-rings, no?), and the paper filter that my A1000 uses, would need to be taken care of. Who has done it?
Thanks,
Scott
1987 Buick Grand National
10.22 @ 130mph on E85
Mods: Turbonetics 70GTQ, Bronsonian ported iron heads with stock valves, Comp Cams 214/214 roller, Cotton's FMIC, 95# injectors, A1000, Razor's alchy injection, FAST XFI, Cotton's 3.5" downpipe, ATR 2.5" exhaust, 9.5" Vigilante, Eaton posi, Moser 28 spline axles. Tuning by Dale Cherry and Bill Moss.
Old March 13th, 2008, 06:29 PM
tom j's Avatar
You would have to get a bigger pump, and stainless mesh filter.
I have used earls socketless hose and anodized fittings with no issues.
87' GN, 8-point cage, t-pro, 4.1 production 291, E85, 120lb inj, 2035 weldon, and some homemade products
Old March 13th, 2008, 07:57 PM
GNVYUS 1's Avatar
A.K.A. DR.BOOSTER
The Aeromotive Eliminator and Pro pumps are more up your alley at that power range with the ability to step up. But those pumps have a reputation of being short lived unlike Magnafuels.
I have a Magnafuel 500 but it's on my carbed GTO running E85, but Magnafuel has a couple monster EFI pumps also, call them.
I used a stainless meshed -12 Summit fuel filter and -12 SS Summit lines with anodized fittings.
I also have a Ricks Hot Rod Tank but be prepared to spend some $$ especially if you want it sumped and baffled.
And with the XFI you can run monster injectors but don't bother under the 120's.
Mike
87GN T-Top down 414lbs.
Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, PI 3400 5disc, KB Plenum/70mm TB, Razor's Alky Kit, 60lb Inj, -8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10
Old March 15th, 2008, 08:25 AM
1QWIK6's Avatar
Torque wins
Try contacting Whites Racing in Michigan. He's doing some work on a conversion with BS3 (DFI) and some E85 sensors. I think he has a BS3 plug and play system complete for $2500. I would assume this would include some phone support.
Originally Posted by IEATV8S View Post
What has happened to all our liberal friends?
Originally Posted by BlownZ View Post
I think you have just about annoyed everyone with the 42 Obama posts a day. It's impossible to get any conversation going because before a thread gets to develop, there are 24 more just like it.
My 2 cents.
Old April 5th, 2008, 07:45 PM
Hot Air
FWI, Aeromotive does NOT recommend using their paper filter with E-85.
Conrad Carter
HotAir
Turbonetic 66-S-BB-.63exh w/EVO WG (35mm) #10780, KB 70mm TB/Plenum, Champion port Intake/CI head/Fuel Rail/EGR B/O, Comp Hyd Roller #212/212 w/beehive, Scorpion 1.5 RR, ATR 3-bolt header/dual 3" Cat-Bk/DP301, 72# inj, RJC Pl, PTE TurboSaver, 12" B-Car frt/11" Baer rr disk, Hotchkis tubular up frt ctrl arms/frt sway bar, Metco rear ctrl arms & HNR sway bar, Eaton posi w/Moser 30 axle, GTA wheels, CAS V-1/St. Al. radiator, 4" cold air, XFI, GNX Dash, Autometer Dual Channel In. Air Temp, Billet Optima Battery Mnt, 9.5" ArtCarr LU 3k stall, DRW C. Al Tran. Pan w/700R filter. 11.6 @ 118 mph. Antifreeze in the Oil! Metal fines in Oil Filter. LOL.
Jack Cotton (www.cottonsperformance.com) (413-789-0531) The Greatest!
Cal Hartline (www.hartlineperformance.com) (321-722-1563) is next.
Old April 6th, 2008, 09:03 PM
Hot Air
Scott,
You might want to use the stock tank (with sump) for now. Several members have posted that they have been running E85 for several years with stock tank with no trouble. You will need the sump to be sure the pump has a full load of fuel without having to lift it out of the tank.
If you are making serious power, you need to be thinking about a serious fuel system. Fuel lines...look at -10 supply and -8 return lines! Just remember that at any given HP level, E85 will require 15% MORE fuel flow. I would be looking at ~100 lb/hr fuel injectors and Aeromotive Eliminator fuel pump and accompanying FPR and a FP Electronic Controller (keeps the FP from killing itself by cutting back the voltage at idle or other low flow conditions). That is were I'm headed....I like to do something once and be done with it! Remember, you never want to go lean!
Food for thought.
Conrad
Old April 7th, 2008, 05:34 AM
Buick "RICER"
Trader Rating: (12)
Thanks,
Scott
are you sure?? "I" don't think so Congrats on your times though
Dan
Old April 12th, 2008, 08:46 AM
96 NMCA L/S World Champ
Dan
I,m sure with back to back E85 vs pump gas tests we get 8% power gains on turbo cars.
Dale Cherry 86 GN, 272 cu in Stage II, Big Ass Turbo
10.5 Tires 8.30 @ 167
Old April 12th, 2008, 08:54 AM
Buick "RICER"
Trader Rating: (12)
Originally Posted by Quick86GN View Post
Dan
Hey Dale !!! your alive and well ?? maybe catch up with ya this summer. Doesn't look like we are making BG so we will hit Atco or CC in Oct. Very impressive E85 stuff!! BUT Alky is .... never mind
Dan
Old April 12th, 2008, 09:23 AM
E85 is cool but hard to find plus you fuel system needs to be changed to handle it , 30% more needed at WOT, better pump & filters, larger injectors, etc. It's not for everyone. Alky will get the job done.
Old April 12th, 2008, 11:03 AM
Buick "RICER"
Trader Rating: (12)
Don't you have some work to do
Dan
Old April 13th, 2008, 12:58 PM
bsdlinux's Avatar
Just Another BLACK Car
Well I've changed the injectors and the chip... lets see that was over a year ago What else was I supposed to change??
1987 ME-R , 83#, TA-61 ,24 Row Mease Stock Location, Hurst Lightining Rods and some other stuff, Sleeping right now
1987 White Turbo-T E85Daily Driver Who says the stock turbo can't make power
Need chips, go here: Http://www.turbotweak.com
It is what you learn after "You know Everything" that is the most important.
Old April 13th, 2008, 01:00 PM
bsdlinux's Avatar
Dan
Same timing , etc, etc..???
The cooling of E-85 eclispes that of ALKY kit, now would someone please use both
Old April 14th, 2008, 04:46 PM
Hot Air
bsdlinux,
So, you have been running E85 for a year now? Are you using the stock fuel pump, fuel lines, and fuel filter?
Conrad
Old April 14th, 2008, 07:12 PM
bsdlinux's Avatar
Originally Posted by alphaenvirmgt View Post
bsdlinux,
Conrad
Yes....actually over a year and over 10,000 miles
The pump is a Kirban replacement that the previous owner put in, everthing else is stock except injectors of course
I drive the White car everyday with E-85.
Old April 14th, 2008, 10:08 PM
On a stock setup I see no problems with it working with just an injector & chip change, You do not have to change anything if you don't want to its's your car. We were working with a higher HP so more pump demand and fuel line size, bigger injectors etc. were needed.
Old April 14th, 2008, 10:18 PM
You have bin running E-85 for a year so I'm sure you have some good data with it ( HP & TQ, how much more or less timing , how much more boost with out knock, fuel consumption, etc.) How about you trying it and share some info. I would like to know if their is power to be found.
Old April 21st, 2008, 10:26 AM
bsdlinux's Avatar
I don't have an alky kit right now. When I convert my black car over I will use 100% E-85 and Meth injection. And try it
