79# Injector limits and E85
Hey guys lately I've been looking into upgrading my GN and I was thinking alky/TT chip or something like a Extender/translator/maf. Well now I'm wondering if I should go with these 79# hi-Z injectors/TT chip and switch to E85. I still have the stock Maf but the larger K&N cone filter.
My question is with my combo (in the sig) will I have enough injector and will there be enough room for growth i.e. bigger turbo down the line? My guess is the 79#er's would be good for the 44 and but I'm not sure if I were to go with a bigger turbo say a TE62 or TE63? I'm just using those as a size example because that would be as big as I think I could safely go before I have to start upgrading everything else in the drive line. My car is fast enough for me for now but everyone knows that the speed bug bites at some point. Here are the injectors I'm looking at... Racetronix 01D129xFM Injector I'm not opposed to adding an alky kit either, I just like the idea of running E85. I still might just go the alky kit/TT Chip route but I want to make sure I cover my bases and think things through. My goals for the car are pretty much to have a nice street driver that I take to the track once or twice a year. There probably still plenty of info you guys will want but I'm a bit hungover right now and just wanted to get this out there to start the conversation. Thanks
Chuck 86 GN 44 Turbo, Precision FMIC, 3" Houston downpipe, Walbro pump, 50# injectors, Power Plate, ATR Headers, 2.5 inch exhaust, ANS Boost controller, Jimmy's ss trans w/3200 LU vigilante, adjustable FPR, TT Alky Chip, Razors Alky Kit, Russ Merritt wires and a Scanmaster. jump bounce pogo pogo pogo pogo pogo pogo pogo pogo pogo pogo http://www.youtube.com/watch?v=bf6r65_iHL4 Last edited by BlackoutDrunk : February 16th, 2008 at 03:14 PM. |
Guys like wordy1 and bsdlinux I'm talking to you. Anyone with some experience please chime in.
Thanks in advance.
Chuck 86 GN 44 Turbo, Precision FMIC, 3" Houston downpipe, Walbro pump, 50# injectors, Power Plate, ATR Headers, 2.5 inch exhaust, ANS Boost controller, Jimmy's ss trans w/3200 LU vigilante, adjustable FPR, TT Alky Chip, Razors Alky Kit, Russ Merritt wires and a Scanmaster. jump bounce pogo pogo pogo pogo pogo pogo pogo pogo pogo pogo http://www.youtube.com/watch?v=bf6r65_iHL4 |
so you don't think something like this http://fullthrottlespeed.com/customk...eq~.htmhttp:// would be enough or is it just too close to the edge of being enough?
I'm not familiar with double pumpers would I need to modify my tank to get a double pumper to fit?
Yes thats a good pump. With the 79# injectors you should be able to get around 500 hp before you start running out of fuel. With alky ( 100% Meth ) your adding an extra 10-15% or so of fuel. Plenty of HP for most and enough to blow it up After that I would definitely upgrade the fuel system, the line sizes, fuel rail upgrades, badass pumps, etc HTH
************************** 1987 ME-R , 83#, TA-61 ,24 Row Mease Stock Location, Hurst Lightining Rods and some other stuff, Sleeping right now 1987 White Turbo-T E85Daily Driver Who says the stock turbo can't make power Need chips, go here: Http://www.turbotweak.com ************************** It is what you learn after "You know Everything" that is the most important. |
I thought I heard that the stock lines should be good up to 1000hp but it was the fittings on the fuel rails that bottle necked the system. You guys know better than I do.
I think this will be as far as I go with speed upgrades that's why I was looking into just getting away with changing the fuel pump. How hard is it to upgrade the fuel rails? I'm not too keen on changing the fuel lines as I heard it's a pain in the butt job. or is it? As usual thanks for the input. Anyone else got something to add?
Oh ya forget about that, the stock rail at the feed fitting is narrowed down and IMO sucks for anyone concerned with tuning high HP GN's or running HP with E85.
You probably saw guys running twin pumps with the stock lines, they have made big power, but the stock lines add back pressure. That is why I chose to go -8 SS and the Champion Rail with the 340 vs the possibility of having to go double pumper on gas in the high 9 area ( someday ). The Champion rail is a straight shot, though I think someone posted measurements saying the stocker and the Champion are actually the same size internally. But that narrowing at the feed in the stock rail really blows IMO.
Mike 87GN T-Top down 423lbs. Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, Billet Drum/Input, PI 3400 5disc, T Brake, Inland 3.5" DS, KB Plenum/70mm TB, Razor's Post Turbo Alky Kit, Devils Preturbo Alky Kit, TT Chip, 60lb Inj, Denso 280 Pump,-8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, ATR SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, QA1 Shocks, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10, 275/60 Nitto 555Rs |
BlackOut - If I upgrade fuel lines , I will install braided lines on the GN all the way from the tank. Have the fitting cut off the rail and re-done and call it good or like Booster get a Champion rail.I believe a few people on this board have done excatly what I'm mentioning here with great results. I must add though, at the point all of this would have to be done you'd be past the 95# injector mark which is the limit for the stock ECM. ![]() Its just money right ?? LOL.... ![]()
I think all of that is way further than I wanted to take it.
I just want to run E85 and make sure my fuel system can handle it. I've heard some not-so-good things about the 79# Hi-Z injectors. Anyone have any experience with them? I might just go with a modded ECM and be done with it.
| limits of a ta-60 | jamier | General Turbo Buick Tech | 17 | February 24th, 2007 10:30 PM |
| Injector limits | Googs | General Turbo Buick Tech | 8 | November 12th, 2006 01:06 PM |
| what are the limits? | TURBOELKY | General Turbo Buick Tech | 2 | May 12th, 2006 11:06 AM |
| What are the PSI limits of C16 | V8KILLR | General Turbo Buick Tech | 17 | March 21st, 2004 10:17 AM |
| limits of 200r4 | chevyII | Transmission Talk | 1 | September 18th, 2003 08:48 PM |
