ive had them since start of season so i wouldnt call them new
![]() i used them well past when the grooves disappeared and only just found them slipping away as i got close to the cords. i was always lead to beleive based on all i read that i would need a tall 28" tire to run fast and i would need a 15" tire to get a good 60' . right off the bat i was doing 1.6s and got them to low of 1.588 on my 87 , on the 86 w/tbrake at 8psi boost launch they were hitting 1.50s ive tried 28" slicks and usually hit 1.6 mids to 1.7 and mph is usually lower inthe 1/8 and 1/4 , the 16" MT street radials just plain work for me and run lower ET's with them vs slicks , not the greatest tire for daily use due to the fast wear but they work great on the street as i haven't found another tire yet that i can take on the road and even come close to putting the pedal down like i can on the MT's and they feel as good as my eagles . ive seen some cars running the MT's into the low 9s ,
paul...magnabuick.com NJ rep 86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" HKS ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1 1.42 6.57 104.9 10.4 129.8 now trying out lonnie diers th400 w/tbrake 87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, TT ..11.45 117 1.57 fresh motor .. stock turbo 55# ,TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" Tail,turbosaver all runs on quick chek 93 octane alkycontrol.com progressive meth injection turbotweak.com |
Pacecarta...
What suspension mods have you done on your cars....springs,control arms, airbags, etc....Also, what tire pressures were you running in them & what is your burnout procedure? Thanks, The Darkside
Precision 70GTQ BB, RJC Girdle, CAS V4, Mototron 60's, Ported stock heads, 218/218 cam, Total Seal Rings, Kurtz 200r4 Tranny, PTC 3200 stall, Razor alchy Kit, TH 3"DP, ATR 3" single shot, Big Mouth Cold Air Kit, LT1 3"maf,Trans.+ w/Extender, walbro 340,RC dual fans.,etc... |
heat them up a little bit to clean them off , get them too hot and they dont stick as well
87 hit good on both stock bars, airbags (15pass ,7 driver) and southside style(no rubber bushing ) lowers and adjustable heim end uppers . i tried no front bar and did worse , now I have the HR parts HD rear bar and no front bar and bags empty leaving off footbrake with about 3-5 psi , tires at 17 psi was getting 1.6 to 1.65s went to 22lbs and got a 1.588 and top end mph went up on the slicks right now leaving harder Im only getting 1.65-1.75s 86 stock uppers , boxed in stock lowers , OE bushings, HR parts HD sway bar off transbrake at 3750 rpm (7-8 psi) has hit 1.50s pretty consistent , , 17lbs in tire for the 1.50s but i had 22 1/2 psi when i hit the 1.522 and gained at the top due to the added air presssure. this car has 6 point roll bar and with a dfi on slicks was doing 1.40s but with alot more launch boost
paul...magnabuick.com NJ rep 86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" HKS ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1 1.42 6.57 104.9 10.4 129.8 now trying out lonnie diers th400 w/tbrake 87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, TT ..11.45 117 1.57 fresh motor .. stock turbo 55# ,TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" Tail,turbosaver all runs on quick chek 93 octane alkycontrol.com progressive meth injection turbotweak.com Last edited by pacecarta : November 4th, 2005 at 10:52 PM. |
