Go Back   TurboBuick.Com > Miscellaneous > Drag Racing Techniques
Old May 10th, 2005, 03:47 PM
..it isn't rocket science
11 seconds on street tires?
How many of you guys with 109 blocks can run 11's on street tires ( radials ). I'm just curious because I had my car back at the track this past weekend after replacing broken rocker shafts and the thing ran 12.14@115 first pass on low timing. I proceeded to play with the car all night running 12.19, 12.17, 12.10, etc. I finally broke an 11.98@116 on Yokohama ?? 255/50/16 tires. How many people have done this, or better?
Oh, I was getting 1.92 60' times with a could 1.82 60' times thrown in there.
Old May 10th, 2005, 04:00 PM
You can get the 60s down to 1.45 or better you can get 11.50@118.I have run a best of 11.68@117 with a 1.53/60 on nitto's.
87White turbo T,Stage II,GN1's,Champion Ported stock lower,Hyd Roller,Atr Headers & Down pipe,Delta Race gate, 70 p trim, 72 lbs injectors,Percision upper & 65mm TB,old school KB front mount for now,areomotive fule pump,ADJ Fuel pressure reg,big mouth cold air kit/with KN FILTER,volt booster,progressive alcohol injection, scanmaster, heated o2,GNX dash,Maft Pro,ECM done for the 72lbs injectors,Type II coils&module,accel300+wires,centerline telstars,nitto drag radials/hooker 2 1/2 cat-back W/ aero chambers,metco uppers&lowers,hotchiks trailing arm braces,auto meter EGT gauge,griffin aluminum radiator,3400 9x11, converter Hope it go's 13's now.72 Big Block Nova,83 Firebird 468 BBC.
Old May 10th, 2005, 04:01 PM
I have cut 1.71 at Baytown on fresh Nittos. Thats more Baytown than the tires I am sure as their track prep was great.
Silent but Violent
Old May 10th, 2005, 04:02 PM
I meant street tires, not drag radials or slicks, no racing style sticky tire. Sorry about the confusion.
Old May 10th, 2005, 04:05 PM
That is a street tire.
Silent but Violent
Old May 10th, 2005, 04:07 PM
i know that smart ars!
Old May 10th, 2005, 05:23 PM
11.36@119.77 but that was with my nova with 36$radials from tire kingdom 1.64/60 footer.(p275-60r-15's).
Old June 1st, 2005, 07:03 PM
The Green BEAST
I would like to know too!
I was just thinking why am I not in the 12s. I am at 3k on car weight. I have 225/55/17s which is almost the same as my 26" slicks. I also have 3:27.1 and powertrax locker..
I know I can blow in to the 12s with the slicks but with 225s Daily driver street tires would make it much cooler.
Any Ideas?
R.I.P.
87 Buick GN motor and trans in a 242 Volvo. 12.59 @ 113
Video
Mods
Postons 202 cam ,TE-62, 3" dp and 3 1/2 exhaust all the way back. p plate , 009s,adj billit top fpr,. Pts shift kit and preasure reg. New TRanny! Ford 8.8 (3.27:1) 11" drums and Powertrax no-slip locker ,Lt1 MAF and Translator + & extender chip
Old June 1st, 2005, 07:17 PM
Pronto's Avatar
wagon has run some fantastic times on some skinny white wall radials. Maybe he'll chime in and tell you his secrets.
87 TurboT--GT6131, 60lb injectors, Precision sl intercooler, Hooker cat back exhaust, THDP, home made Big Mouth, pp, 62mm tb, adj fr, Walbro 340/hotwire, AlkyControl kit, Turbo Tweak 93+alky chip, HR lower control arms, air bags, ATR bar, best et 11.79@113.86
http://s64.photobucket.com/albums/h1...secondpass.flv
Old June 10th, 2005, 10:42 AM
The best I have ran with a real street tire is 12.07 with a 1.83 60ft. That's on PepBoys Futura's 255/50's. The track was well prepped for the next days big event.
Old July 12th, 2005, 12:53 PM
I second the Pepboy futuras.... I have run 1/8th times that would put me solidly in the 11s on some 275 futuras.
Old July 12th, 2005, 02:10 PM
2 doors just aint enough
No secrets.
Magic.
See the sig.
Brian
The more doors the better.
New time: 11.3@123 with the whitewalls(195/75/14).
Old July 12th, 2005, 02:28 PM
Red Regal T's Avatar
Trader Rating: (13)
I might be able to hit 11s if they would just prep the track right before I run. Problem with street tires is, as the track prep goes away, so do your 60s. Without good 60s, you're not going 11s unless you have a lot of HP.
JOHN DICARLO
PLEASE CHECK OUT MY ...
87 RED REGAL T, or my 87 DARK RED T and don't forget my 87 GRAND NATIONAL
Old July 12th, 2005, 02:44 PM
jasjamz's Avatar
"Hot Air"
I think Patrick Rubio (used to be with PTE) went 11.35 i forgot the mph. This was on a real street tire not a drag radial. But this was a 9.70-9.80 car on slicks. It was a charcoal grey TR!
85 T-Top GN 235 HP!!
Old July 13th, 2005, 12:52 AM
1BADDAM's Avatar
Venomous Snake Handler
Time in sig. Nitto's though. Stock longblock and downpipe. If the track has some cooler temps and no headwind sometime close to winter, should go 11.4-5 @ 119+
Frank
TTA#1416
11.78 @ 117 1.86 60'
Old July 13th, 2005, 10:26 AM
Now , if we are talking Drag Radials I have done 6.77 @ 102.7mph
does that count?? hey it's a radial!!!
Old July 31st, 2005, 11:27 PM
GNVYUS 1's Avatar
A.K.A. DR.BOOSTER
Peterkin great times. What turbo, psi and any head work?
I hope to get high 11's with 295/50/15's, alky and my TA49 pushing around 23psi.
I am sure you can fit a 305 to 285 tire back there but the 16 inch rim is probably killing your 60ft a tad due to the smaller sidewall. There is someone with 305's on 16 inch rims on the OTHER board http://www.turbobuicks.com/forums/sh...2&page=1&pp=15
All you need to do is roll the fender lip and find a good street radial to slap in there.
Mike
87GN T-Top down 421lbs.
Rebuild #2, BLK/BL Paint w/Custom Metal Flares, VPE Stg 3 Heads, 210/215 Roller Cam, TA49, V2 w/Blitz Blow Off, Stageright, PI 3400 5disc, KB Plenum/70mm TB, Razor's Alky Kit, 60lb Inj, -8/-6 SS Fuel Lines, MBC, Pwr Plt, PTE Oil Relocator, Preluber, Z06 Maf, Translator, Volt Master, Poston Headers, THSS 3.5" DP/Test Pipe, SS 2.5" Y Pipe w/No Muffs, PST 2" Drop, Poly Bushings, Boxed Upper/Lower Arms, Vacuum Converted, Aerospace 11" Brakes w/SS lines, Alum Drums, Polished Autodrags 15x8/15x10, 275/60 Nitto 555Rs
Old August 2nd, 2005, 12:20 AM
It took some practice but I managed some mid 1.6 short times on a true 275/60 bfg ta. The car ran 7.30's 1/8 mile at those 60's so it would be well into the 11's. I couldn't put any more power in it or it would spin badly when the boost came all the way in. An electronic boost controller would be a good thing to have if you race on true radials so that you can set the ramp speed on the boost.
  #19 (permalink)
Old August 4th, 2005, 12:47 AM
bird's Avatar
Thumbs up
1.6 shorts on a regular radials, thats unreal, whats your secret? who needs slicks or drag radials with those numbers. very impressive
9.68 @ 139.93, 1.43 60'
Real street car, t-roof, 3600lb race weight, all working options. 200r4,
stock block, crank, rods, driveshaft, posi... no cage yet
New toy, bone stock t-top all original 87 g/n 27,000 original km
  #20 (permalink)
Old August 6th, 2005, 07:56 AM
I wish I new what the secret was. The car was a 6.6 @103 car on 33# and C16. I just got bored and started playing on real radials to see what I could do. I could only run 22 psi or it would kill the tires when the boost came in. I just kept trying different boost launches and finally got it figured out. With 30psi in the tires I could leave on 2# of boost and I guess the combination just worked well together. It took the q trim 66 with .85 housing a little while to spool so it was perfect for true radials. I had good rear control arms with adjustable uppers and 90/10's in the front with moroso drag springs. It would 60' in the 1.49-1.52 range on 275/50 dr's.
A freind of mine always ran on real radials. It was a 6.90 car on good gas and slicks but with the boost turned down he could go low-mid 1.7's on true radials. His car had all stock suspension with nothing but a pass. airbag.
We did notice a difference in track nights also. These times only happened on good nights when a lot of slick tired cars were running. If you have a track where you have a lot of imports or radial tire cars tearing the track up then it's harder to get the good 60's. Most of my times were in the high 1.7 range with a handful of 1.6's.
  #21 (permalink)
Old August 7th, 2005, 10:49 AM
Powered by Murphy's Law
I just hit the 11's last night on Cooper Cobras. my 60ft was 2.00 and it ran 11.95 at 119.9mph.
86 TR
Leather,column,astroroof
T-netics 66BB S-trim, ME-R
Razor dual nozzle alky, 75lbrs, Powerstroke IC
210/215 roller, Forged stroker, TA headers, HR Bar
Lonnie Diers Stage 2, PTC 9.5 N/L
10.71 at 129mph 6.8 at 102mph
3700lbs w/driver
