Go Back   TurboBuick.Com > Electronics > Car Audio
Old May 15th, 2002, 11:21 AM
1QWIK6's Avatar
Torque wins
2000 Gm Radio... Obdii Only?
I have a 2000 Olds Radio. This is the one with the CD and tape together. I was told I cannot install this in my Regal, because the radio will only work without a PCM signal. I.E. the radio gets it's power(?) from the car computer.
Anyone run into this situation before? Can I make this work?
Old May 15th, 2002, 11:37 AM
TURBOV6's Avatar
"SECRET PARTS"
How many plug is on it? If its a singular plug there is a amp/tuner pack under the dash some place probally under the pass side dash, to locate it it might be a size of a ecm with heat sink fins and also the antenna plug in it. But to be on the shure can you take a pic of the front and the back of radio and e-mail me?
87 Buick Grand National Limit GT6131E, PTE FMIC, 70mm Accufab TB/PTE Plemun, JC power plate and pulleys, RJC boost controller, 65lbs Mototrons, 3.5" Big Mouth cold air kit, ATR 3" downpipe w/ATR external wastegate, ATR 3" dual exhaust, MSD Dis-4HO, Art-Carr #16930 3200 non-lock TC, CAS fuel pressure regulator, Walbro 340 hot wired, Scanmaster 2, QA1's, H&R sway bar, Eibach springs, Air bags. 17" T11's w/315 in the rears! New times 4/1/06 1/4 et 11.38@117.56 mph 1/8 et 7.10@97.57 mph
04 Ford Mustang GT
GNRA Member #47
www.imagestation.com/members/HI87GN
TURBO BUICK MEMBERS ***BEWARE*** OF BUYING OR SELLING TO MEMBER JUSA6!
HID kits for sale http://www.turbobuick.com/forums/par...ml#post1505931
Old May 15th, 2002, 09:13 PM
4PLAYN
thats right
it will probley still work but will say conf error on the screen if you can get it to wire up your best bet is to either sell it or trade it for a cd player from a f bodt or gm product that has the 2 bolt in on either side. i put a tape player (it was free) from a f body in mine but have not wired it up yet .
1987 TURBO T BLUE/GRAY GT6765 DUEL BALL BEARING TURBO 70MM THROTTLEBODY POSTONS 212/206 CAM 60LB MOTORN INJ RJC MEGACOOLER BALANCED & BLUEPRINTED, TURBO TA CRANKSHAFT, TWIN WELBRO 340 PUMP WITH AGJ FUEL PRESSURE REGULATER , PORTED AND POLISHED INTAKE , HEADS , OVER SIZE VALVES INTAKE AND EXHUST, 10.5MM WIRES, THDP, 3' DUMP, DRAG REDAILS, POSI, 3500 STALL , 2004R REPTIOD FROM PATC, NEW BEST 10.86 @ 125.5 1/8 6.98@ 101 OLD COMBO PRESSING TO JOIN THE 9'S CLUB!!
Old May 22nd, 2002, 06:31 AM
FlyinGN's Avatar
all show no go
I have a 2002 Camaro Monsoon cd player in my GN and it works perfect..
http://us.f1.yahoofs.com/users/3ba58...DtxE9AcR_NJFJi
