Go Back   TurboBuick.Com > Electronics > Car Audio
Old February 3rd, 2002, 12:06 AM
WFO's Avatar
WFO WFO is offline
Hotair Tech-erator
5-1/4"'s in the rear deck?
is there an adapter or a secret to putting a 5.25" speaker in the rear deck of my gn?in my limited experience 5.25"s always seem to sound better than 6x9's,and way better than 4x10's.
am i on crack?
or is there another combination that i'm not taking into consideration?
fyi,not a high end system,basically replacing the stock crap with decent stuff and adding a sub(i have a 10 and a 15,both older punch)to fill in the bottom end a bit.
and i listen to a lot of SLAYER
thanx fellas.
later,sean
Old February 3rd, 2002, 09:32 AM
Audiowizard's Avatar
CARE FOR A SMOKE ANYONE?
Lightbulb
You can make the 5.25s work but you will have to make an adapter plate. I would recomend 3/4" MDF plate that will secure to the rear deck to hold 5.25s. I installed my a/d/s 3.5s this way in mine for a little bit of rear fill.
1986 Buick Grandnational
MODS: 17" x 8" Billit Centerline "Champ 800's" wrapped in 225/45 Nitto 450s, Bell Tech 2" dropped front spindles, High flow cat/dual 2.5" diameter mandrel bent pipes and Flowmaster Delta Flows with dumps in front of rear axle, '87 GN grille, Polished aluminum mass air flow pipe with K&N on a 150,000 plus mile stock unopened motor.
Old February 4th, 2002, 06:53 PM
All Throttle... No Bottle
A few questions
Looking to put a component kit in, the tweeters would go in the front deck, and the 5.25's in the door. I know these kits can get expensive, and I'm looking for some clean sound. Also.......
Who's 6x9's should I go with or should I get something else???
TIA.
87 Regal Turbo T
Home of Simple Man Racing
10.16@131.11 1.44 60' still going....
2001 K2500 Suburban (Tow Vehicle)
Old February 4th, 2002, 07:13 PM
Re: A few questions
TIA.
Here is a link to 1 of the previous threads on 6 x 9s called "6 x 9 speakers" Here is the link:
http://www.turbobuick.com/forums/sho...ghlight=6+x+9s
