Go Back   TurboBuick.Com > Electronics > Car Audio
Old July 9th, 2008, 03:26 AM
wile87's Avatar
BEEP BEEP MY ASS
3 1/2 dash speakers
can anyone tell me what brand of speakers will fit into dash w/no mods and still sound good
Old July 9th, 2008, 11:02 AM
87 Bagged Regal's Avatar
onlinecarstereo.com
87 Regal Air Bagged currently doing a 350 Rocket swap
Old July 9th, 2008, 12:43 PM
Polk Audio db351
I just put a set of these in a few weeks ago. Like someone on here suggested, I put the clips on the speaker and then hung them under the dash. Fit just fine. The speaker grill would've set flat if it wasn't warped from the speakers a previous owner put in.
db351 Car Audio Speaker from Polk Audio
87 GN-39k T-Top's
98 ZR2 Blazer-Daily Beater
Old July 9th, 2008, 12:46 PM
i am subscribed to this as well
I would like to know what is recommended for a moderate upgrade of speakers in our Buicks.
I have heard that the components that include a 5.25 door speaker and a 1.0 dash tweeter wired with a crossover and amplified are the choice.
Also, has anyone found quality 4x10's for the rear deck?
What are the masses listening through these days?
thanks
Jim
Old July 10th, 2008, 06:56 AM
87Regal3.8SFI's Avatar
V6 on steroids
I used a pair of Alpine 3.5's with a pair of Polk 6X9's in the rear on 4X10 adapters. Sounds pretty good, but then again how often do I listen to the radio?
Old July 10th, 2008, 07:15 AM
I got a pair of pioneers up in the dash, Sony's in the door, and Sony 6x9"s in the rear deck.
1987 GN 3" ATR downpipe,PTE TA 49 turbo, adj. wastegate,adj. fpr. Art Carr shift kit 2 1/2" Hooker ex. 3" Hi flow gutted cat, aero chamber muffs. 9"K&N filter, 60/65lb. mototron injectors,heads pocket ported, 3 angle valve job, LT1 valve springs, 340 walbro fp.hot wired, plenum spacer, 160 therm. cross drilled slotted rotors, vacuum brake conv. Kirban GNX style rims,48k on car, 93 Turbo Tweak chip, 2.1 scanmaster,knock guage, 3" LT1 Maf w/translator, VDO guages,manual boost controller.
Old July 11th, 2008, 10:47 AM
Clarion makes an inexpensive speaker that will fit your dash no problem.
They sound better than a lot of the competitors in their price range.
1986 Cutlass Supreme - For Sale, PM me.
Old July 19th, 2008, 02:44 AM
ive used kenwood, alpine, infinity, kicker, in most of my cars. they all sound great
Old July 21st, 2008, 01:36 AM
My personal opinion is that 6x9's or 4x10's or any oval type of speaker sound crappy compared to any round midrange speaker. A good 6.5" component setup will blow any 6x9 out of the water anyday in sound quality. 6x9's give an 80's kinda feel, reminds me of someone driving in an Iroc blasting Winger or something I mean, it IS an 80's car, and if thats your style, go for it. For simplicity sake its the best option. In my old car, i used Kicker 3.5's in the front, 1 6.5" component setup in a custom homemade pod in each door, and 2-way 6x9's in the rear....and I know that contradicts what I said, but already had em Sounded great, all the high range frequencies were crystal clear, and even though 6x9's suck, gave pretty good fill. And also had 2 CVR 12's in the back
Tony
Victory Trans
87 Regal, BBC w/ blow thru turbo setup on the way!!
Old July 21st, 2008, 05:39 PM
T-CHRGD's Avatar
I agree on the oval speakers. I made custom aluminum plates and mounted a Polk 5 1/4" coax to the outside and a 5 1/4" woofer to the inside in each 4 x 10 (expanded) opening. Four channel amp and the sound is outstanding.
'87 TURBO "T" - Since New.
'79 CENTURY TURBO COUPE / GNX Project
'79 CENTURY TURBO COUPE / Resto. Project
Old July 30th, 2008, 12:51 AM
wile87's Avatar
BEEP BEEP MY ASS
i have 4 4 way 350 watt 6x9 pioneers mounted on the rear deck and they sound pretty damn good with the old fosgate punch 75 on them
Old July 30th, 2008, 02:51 AM
Banned
just get a sick set of component speakers, put the mid in the stock concert sound speaker location and put the tweeter in the 3.5" dash speaker spot. It will be worth it to invest in 1 nice set of components rather then buy 4 separate speakers imho. just mho though.
ds
plastic upper dash trim (covers dash speakers) ngc414 Parts wanted 1 October 12th, 2007 09:59 AM
dash speakers Ryan's87 Car Audio 2 October 6th, 2004 02:08 AM
Dash speakers //what to use to x-over AsphaltAnihil8r Car Audio 2 August 3rd, 2004 02:08 AM
how do you get dash speakers out? Steves87 Car Audio 4 April 2nd, 2004 04:07 PM
Speakers in the dash LTNG KLLR Car Audio 5 September 10th, 2002 11:05 PM
