LinkBack (1) | Thread Tools | Display Modes |
radio replacement
what yall recomend? will one of these cd/cassette radios work out of a newer cad.? dont need nothing fancy.
mike Baldwin 65 GS 69 GS 84 T-Type digital dash, t-tops, full power--added : home made hot wire kit, hooker exhaust system-no cat, adjustable FPR, adjustable wastegate, digital boost gauge, ext. fuel pressure gauge, 160 thermostat, blocked T/B coolant lines 86 T-Type-frankenstein 2005 dodge ram 2500 4x4 w/19.5 rims Southaven Ms. |
there was a post a few months ago with pictures where someone used a deck from a Electra fit real nice a looked good had a cd player.. I think it was from a 93 model
My Buick... http://s139.photobucket.com/albums/q295/jcawley3/Buick/ 120K stock block, stock intercooler, 4" big mouth CAI, 60lbs inj TT Alky chip to match, 340 walbro hotwired, translater, 3.5 MAF, SMC alky, 3" DP with cut out, GT6162 BB Turbo, Red Stripe converter , powerlogger, RJC powerplate and boost controller, ATR exhaust no cat
I just got me a alpine cda-d852 off e-bay. got a wiring adapter from walmart. I think alpine and pioneer are the only ones that make a direct fit radio.
Any 1.5 or 1-1/2 DIN radio will be a direct fit, question is, why? The only reason for a 1.5 DIN (one and a half sizes taller than a standard radio) is to fill that big nasty factory hole in the dash. An install kit and any standard single DIN cd player can fill it and make it look factory. Since the death of the cassette tape, there has never really been a reason to make a CD/cassette deck since, but pioneer, Aiwa, Jensen and alpine keep hammering them out for people that want a $300 radio to play cassettes. Some people however like the look of a huge radio in the dash, whenever a customer was stuck on the idea of a cassette/CD deck, there was NO changing their mind, no matter how hard i tried.
*87 GN, 130k on stock motor, heads, and internals. Custom Greddy FMIC, Stock turbo, Blue tops, THDP, street tires and pump gas, 12.9 @ 115 Mph, Speedworld Motorplex, Witman Arizona *92 Typhoon #371, black on black with mostly bone stock everything. SOLD! *98 VW Beetle TDi.....it gots a turbo AND a spoiler! |
ok got a install kit from walmart but i think this is for a din radio. how do I install this 1.5 din radio?
Well the kit is for installing a single din into that big hole in the dash. If you do in fact have a 1.5 din radio to put in, then you shouldn't need any kit at all, just a wiring harness. The only reason I could see you needing a kit is if you don't have the brackets for the radio, then sometimes the ones that come with the universal GM kits (scoshe or metra, not sure which one walmart carries) can be made to work with a factory or aftermarket radio. Luckily the regal is the easiest dash in my opinion to manage a radio into, there is a football field inside the opening of that thing compared to most imports and smaller domestics. I've pulled mine in and out so many times I could do it blindfolded. Not all GMs were created equal though, some of the G body dashes line up perfect, others no so perfect without a little persuasion.
yea I've got the factory brackets but they want bolt up to this Alpine stereo. unless I drill some holes into the side of it. So with the 1.5 din aftermarket radio I dont need a kit?
nevermind I got radio in, sits alittle higher than factory but cant tell. and it sounds great.
LinkBacks (?)
LinkBack to this Thread: http://www.turbobuick.com/forums/car-audio/234996-radio-replacement.html
| TurboBuick.Com | This thread | Refback | December 22nd, 2007 11:40 AM | |
| 84-85 Radio and Radio/AC Plate | Boost231 | Parts wanted | 5 | October 2nd, 2007 11:18 PM |
| Cadillac Radio knobs - $10 shipped - add class to your stock radio | channer | Parts for sale | 0 | July 10th, 2006 11:35 PM |
| How do I convert 87 GM radio to 90's Radio? ** PICTURES! ** | 1QWIK6 | Car Audio | 2 | June 13th, 2006 05:18 PM |
| Replacement radio not working | ibroussard | Car Audio | 1 | May 26th, 2006 08:37 PM |
| Anyone using XM Radio? | WakkoSS | Turbo Lounge | 23 | June 2nd, 2004 05:56 PM |
