Go Back   TurboBuick.Com > Tech Arena > Brakes, Suspensions, Tires & Wheels
Old July 21st, 2008, 03:53 PM
upslp's Avatar
UnDeR PrEsSuRe!!
will they fit?
I have a set of 15x10 prostars with 4inch bs. Will they fit?
87 T-Type, Tin Man air intake, 3inch custom exhaust, green stripe injectors, Turbo Tweak Alky Chip, lt1 Mass Air with Translator, MSD Wires, RJC Powerplate,Built tranny, scanmaster, Kirban F.P.R., 340walbro Hotwired! SMC Alky.(CANT WAIT TO GO TO THE TRACK)
Old July 21st, 2008, 06:17 PM
They'll physically fit, but IMO would stick out too far. Unless you don't mind...
Tony
Victory Trans
87 Regal, BBC w/ blow thru turbo setup on the way!!
Old July 21st, 2008, 06:26 PM
Trader Rating: (8)
I had wheels with the same size and spacing like that before. Yeah they do stick out a good amount. Wasn't AWFUL, I left them on for a full year, but eventually changed back to more reasonable wheels.
Old July 21st, 2008, 06:27 PM
jevans's Avatar
X2...The'll fit but their gonna stick outside the wheelwells by 1" or so.
Yeah "My other car is a Mustang"
Old July 21st, 2008, 08:54 PM
Underboost's Avatar
Put Da Evidence In Da Cah
I run that bs with my slicks 28.5 x 10.5 no notch.
Brent
87 GN
www.turbolou.com
www.rjcracing.com
www.turbotweak.com
Old July 22nd, 2008, 09:55 PM
Squids
BlackMetal, Do not touch the trim!!!!!!
Old July 23rd, 2008, 08:56 PM
toofastforyou's Avatar
2FAST4U
Yeah, they should fit. I have a set of 16"x10"s with a rear spacng of 4.25" which is not identical to yours but close, and I'm not having any rubbing issues with them at all...
Claude
1987 Buick Grand National 10.62 e.t. @ 126.76 mph
2002 Ford Thunderbird
2008 Ford F-350 "King Ranch" Crew Cab Dually Pickup
2006 Ford Five Hundred SEL
2001 Saturn SL2
Old July 23rd, 2008, 09:47 PM
MY T FAST's Avatar
post some pics of that after you mount em. i am considering those wheels and just wanted to get some idea of how wide they are mounted.
thanks alot!
Talon
87 WE4: K&N on maf pipe, rjc boost controller, rjc power plate, 160 tstat, TT chip, scanmaster
she's a work in progress...
Old September 3rd, 2008, 11:22 AM
VandaLL's Avatar
wastegate cleaner
yeah i second that.. does anyone have photos showing 10" wide rear wheels? thanks!
Randy G.
1986 GN
1983 Regal wagon
1972 Skylark
Old September 3rd, 2008, 01:28 PM
CJ's6's Avatar
I have 15x10" centerlines on 275/60/15 on my regal. The backspace on the wheels are around a 5", and i use a 1/4" spacer. no rubbing, but my black trim around the wheel wells was removed. I really want to go back to my 8" wheels with the 275/60/15 tire. (just seems to fit better). 10's look killer though!!!! hope this helps some on your decisions. i would post pics, but not sure how to do it yet. (I agree that the 4" BS will stick out from the wheel wells too much with the 10")
1986 Regal T-Type had since new. white with grey interior. mods are walbro 307 hot wired, afpr, 93 lubrant chip, 3.5 maf & translator,36lb blue tops, rollmaster chain, 980 valve springs, 3" THDP, 9"k&n, and 160 deg therm. everything else is stock. best 1/4 mile time 12.92 @ 110. Newest mods are: TE-44 & Alky control kit (finally) & A Turbo Tweak Alky chip to make it all complete.
Old September 4th, 2008, 08:42 AM
Tag - WUTSA V8
These are 15x10 with 4.5 BS Drag Stars with 275 60 15 Nitto's. And at one time I had 295x50 15 Yoko's. They come right to the edge of wheelwell and WILL hit the edge on a decent whoop whoop in the road without air in the air bags. BUT I drive it all the time with no problems. Have for almost 8 years.
87 GN - 210 billet roller, GN1's, 62mm TB & power plate, 55's, TA-53, SSTHDP, 16 pos TB chip, C4, SMC dual nozzle alky.
best BEFORE all the above - 11.29 @ 120 412hp 548 ftlb @ 19 psi
