I'm after the same thing! With the same rims!
For this car... 255-50-16's on it now and I can't fit my fingers between the frame and the tire..
Digital LED Tail lights ![]() Contact me for info 1986 T-Type White W/black out trim, Grey leather int., LED taillights from InjectionX, H&R engine Mounts, 55lb injectors, G-body parts S.L.I.C, 9.5" (Dusty Bradford) PTC N/LU conv, Trans re-worked by Todd Lyle, Walbro 340, Hot wire kit, RJC powerplate, 3" TH down pipe, ATR 3" Stainless Steel dual exhaust, 4-Adjustable drag shocks, Southside uppers & lowers, Carrilo rods, JE forged pistons, Driveshaft loop, powdercoated & polished GTA rims.. 1986 GN - 6.76 @ 103.8 1/8th - SOLD 1987 WE4 - SOLD |
Claude ![]()
1987 Buick Grand National 10.62 e.t. @ 126.76 mph 2002 Ford Thunderbird 2008 Ford F-350 "King Ranch" Crew Cab Dually Pickup 2006 Ford Five Hundred SEL 2001 Saturn SL2 |
Scot W.
Claude ![]()
Thank you!
Thinking of doing the same thing with the GTA wheels on the back of my GN. I was going to use the Hub Centric Wheel Adapter 5 Lug 4.75" Corvette pair. Claude, do you have any pics of your car with the 1.25" spacers? Thanks
Eric
86 GN -under construction- 86 T-Type -finally running 96 Toyota 4 Runner limited MAGNA Member |
Claude ![]()
"turboeric", here are two pics I took yesterday evening.The 4 wheels are GTA "fronts" with the two rear ones installed using a 1.25" thick spacer...
Claude ![]()
One set of four 8" wide "fronts" and another set of custom-made 10" wide for the rear and 5" for the front. I'm only using the spacers at the rear with the stock 8" wide "fronts" as the back spacing on them is a little too much and the look a little "tucked in". The spacers correct this and they look just ok. I'm not using any spacer with the 10" wide wheels though as I've tried before and it looked too much "spaced out" like you said.Claude ![]()
| BAckspacing | allgojoe | Brakes, Suspensions, Tires & Wheels | 3 | March 30th, 2006 03:00 PM |
| 15 * 10 backspacing | Velon | Parts wanted | 1 | April 26th, 2005 07:50 PM |
| rim backspacing | wakebdr2 | General Turbo Buick Tech | 2 | April 10th, 2005 09:00 PM |
| Best backspacing for 9.5 Rim | CopGn | General Turbo Buick Tech | 11 | April 4th, 2003 11:48 AM |
| Rim Backspacing? | Nojug | General Turbo Buick Tech | 9 | March 25th, 2003 09:26 AM |
