doesnt matter if its from a 2nd gen F body or a van/truck but to say any 70-81 fbody is wrong
one consideration is 'series' which is based on gear ratio, most second gen Fbodies (birds and TAs) came with 2.56 gears, only the performance optioned TAs got the good ratios (3.08,3.23 and 3.42) to use your 3.42 ring you need a 3 series carrier , you need to find a carrier that had a 2.73 and up gear, if its lower than 2.73 it is a two series carrier and to use it all you would need a ring gear spacer kit (30bucks at summit) , i wouldnt reccomend a spacer for our turbo cars unless all you are doing is driving it . spline count is another thing that varies stock G body is 28 axle spline count on differential units before 1989 were 28,then they went to 30 spline axles. so if you have stock axles (28spline) the newer carriers wont work for you , but they will be great if you racing alot and plan to upgrade to 30 spline axles , if you find a newer 8.5 stay away from gov-loc units aftermarket eaton carriers use the larger journal side bearings so if you find one of those you need the bearings and races for it heres a link to clear things up and help in your search Auburn Positractions Limited-Slip Differentials, don't pay retail! Automotive Parts Guide for GM 8.5 inch Differentials, Ring & Pinions - Save Money .
paul...magnabuick.com NJ rep 86gn bone stock shortblock , ported irons ,LT GT71Q 75#inj , V2 , atr 3" ext ,200-4r, stageright , AC9"NL , TTWB 6.0 alkycontroll dual nozzle ,msbc-1 ,LC-1 1.42 6.57 104.9 10.4 129.8 now trying out lonnie diers th400 w/tbrake 87GN ,prev combo unopened motor TA49, duttneck 50# , dynotech hipro, protorque 10.5", alkycontrol, , TT ..11.45 117 1.57 fresh motor .. stock turbo 55# , TT WB 6.0,msbc-1 ,LC-1 ,cottons 3" ext,turbosaver all runs on quick chek 93 octane alkycontrol.com progressive meth injection tubotweak.com Last edited by pacecarta : May 16th, 2008 at 12:37 PM. |
| need a posi unit | fnsikser | Parts wanted | 4 | March 29th, 2008 09:37 AM |
| Trade: 8.5 posi unit for 7.5 posi unit | camaro75racer | Parts for sale | 2 | February 25th, 2005 08:43 AM |
| Gauging interest. Powermaster unit works fine. Converting to Vacuum | Scott4DMny | Parts for sale | 2 | January 29th, 2005 02:30 PM |
| Posi works sometimes and one wheel peel other times | turbo nasty | General Turbo Buick Tech | 4 | March 21st, 2003 06:32 AM |
| Open rear end - install posi unit vs posi rear end | channer | General Turbo Buick Tech | 6 | March 18th, 2003 11:01 PM |
