Go Back   TurboBuick.Com > Tech Arena > Brakes, Suspensions, Tires & Wheels
Old March 26th, 2008, 08:13 PM
Am I doing this right? Pinion angle
Checking pinion angle. First pic is of angle finder on the driveshaft, I get a measurement of -1/2 degree.
2nd pic is of angle finder on the pinion coming out of the rear end, I get an angle of -1 and a half degrees.
Making my pinion angle -2, correct??? Pros and cons of more and less angle? Just trying to make my car hook better that's all.
What angle do these cars like? I have solid lowers and adjustable upper control arms.
Thanks for the help guys
87 GN
Old March 26th, 2008, 08:41 PM
Question
-12 subtracted from -1 1/2 = -1 degree, however how much the car squats will affect the angle.
Hopefully Jack Cotton will chime in here, or give him a call - his customer service is the best.
87T, Baer 12", VR4, Hydroboost, KB cold air, HRP & S lowers, Cibie lights, hotwire, Walbro, digitails
Old March 26th, 2008, 09:12 PM
Forgot to mention this is with the front wheels on the ground and the rear end jacked up, weight of the rear end resting on the jack.
87 GN
Old March 27th, 2008, 07:24 AM
So am I at least measuring it correctly?
87 GN
Old March 27th, 2008, 07:29 AM
Dont have any idea as to what this will help. Thinking it will reduce drivetrain stress? Maybe this is why my car will break the trans mount, and rear trans seal leaks sometimes?
87 GN, BB66,3000 westcoast stall,hotwire,walbro,DW,210/215 roller,4340 crank,65lb injt,homemade alky,Scan2.1. ect.
Old March 27th, 2008, 07:49 AM
To do it properly you need to have the car at ride height and race weight if that's what your going for. I usually just put the jack stands under the control arms on the front and the axle tubes on the diff. which has always worked on my ladder bar setups. A drive on hoist would be perfect for doing it.
Then measure the back of the tranny, d/s and diff. Figure out the difference between the three and that's your P/A.
I haven't got to mine yet on the GN but a 4 link likes 1-2 degrees and which is pretty much what our cars have.
The goal is to have no angle once the car is moving.
Old March 27th, 2008, 07:54 AM
turbo nasty's Avatar
BOOST SUX MY WALLET
Need to mimic real world conditions.
Car on a lift that supports all four tires
You in the drivers seat or someone real close to your weight
1/2- 3/4 tank of fuel
Measure the slope of the driveshaft vs. underneath the pinion ?(should be a flat spot to put the protractor) the difference is your pinion angle.
Street car no more than 2 degrees, the pinion should be down in relation to the prop shaft.
USAF POWER PRO
05' Harleys
Wide Glide- Glacier White Pearl w/ EFI, Stage 1 & SE Pro Pipe.
Duece- Sunglo and Chopper Blue w/ EFI, Stage 1 & SE Double Barrel too much to list still has warranty till 2010.FOR SALE
Old March 27th, 2008, 09:03 AM
Still plays with cars!
caution
excess pinion angle (down) can cause vibration on deaccelleration, just a word of caution, ( been there done that)
just a bunch of cars..
Old March 27th, 2008, 11:34 AM
So do I subtract the angle of the driveshaft from the angle of the pinion of the rear end? Or do I calculate the difference between the two? This stuff just makes my head hurt. How do you determine the difference? Given what you see in the pics, is my pinion angle -2 or -1? Or do I need to do it again?
Funny how you read all over the internet it is real easy to find pinion angle but no where can you find an example clearly saying how it is done
Maybe I am reading into it to much, but man does this make me feel like I have the mathematical abilities of a 6 year old. Maybe I do???
Thanks to all who have responded, please clarify.
87 GN
Old March 27th, 2008, 11:57 AM
Here...check this out:
Pinion Angle - Wolfe Race Craft
...in talking to some suspension guys the best way to do it is on level ground with the suspension fully loaded but it can be done by jacking up the rear only as long as the suspension is supported either under the axle or pumpkin...the way you are doing it you are relating driveshaft angle to the pinion angle...has nothing to do with the angle of the car to the ground...
Scott
87 GN - Street/Show Car (orig owner - 41K miles)
87 T - Street/Race Car(10.46 - 131.68 MPH) - TSM setup
Old March 27th, 2008, 12:04 PM
I can't see the reading on the pic for the pinion..is the arrow to the right or left of the 90 degree mark?...it should be to the right which would indicate that the pinion is pointing down...somewhere around 89 degrees...if it's on the left side at around 91.5 degrees then you're at +.5 degrees...not good...
do you have adjustable uppers?
Scott
Old March 27th, 2008, 12:13 PM
My bad...you said the driveshaft was -.5...I'm confusing myself now...just need to know for the pinion what side of 90 degrees the arrow is on...then I can tell you what your pinion angle is...
Scott
Old March 27th, 2008, 03:33 PM
To the right at 1.5 degrees. Pinion is definitely pointing down towards the ground.
87 GN
Old March 27th, 2008, 03:47 PM
You're at -2...that should be fine...
Scott
Old March 28th, 2008, 08:26 AM
Pinion angle is not a tuning "tool".
Setting the pinion angle helps free up HP, as the greater the angle, when under accel, the higher the HP required to turn the pinion...
The trik is to get the angle set static, so that suspension deflection, when under accel, the angle moves as close to zero as possible. = less HP loss.
86 GN
9.98 @ 141.00
www.codymotorsports.com
FUEL INJECTOR SERVICE
706-342-3152
Old March 28th, 2008, 01:33 PM
BOOST SUX MY WALLET
Spoken like a true prodigy... you have been doing this just a few years huh Chuck.... lol
USAF POWER PRO
05' Harleys
Old March 28th, 2008, 01:51 PM
[quote=Chuck Leeper;1827017]Pinion angle is not a tuning "tool".
QUOTE]
Dave Morgan would disagree with you. In his Door Slammers book he says it is a tuning tool. I'm not saying you're wrong but it depends on who you talk to. I do know on my 69 Camaro I went from 2 degrees to 3 degrees and my 60' went from 1.3 to consistant 1.28's.
Maybe I freed up some hp or maybe I got more bite. I don't know which but it did change.
Old March 28th, 2008, 01:59 PM
Talking Whatever..
[quote=craggar;1827261]
QUOTE]
"floats your boat"...
Or better yet, whatever turns your crank!!
Could be that degree got the deflection set to release that extra HP??
86 GN
9.98 @ 141.00
706-342-3152
pinion angle ? TKGN1 General Turbo Buick Tech 11 November 3rd, 2007 09:22 AM
Pinion Angle... TARZAN Brakes, Suspensions, Tires & Wheels 2 May 1st, 2006 11:19 PM
Pinion angle oldtimer Stage II Tech 7 March 29th, 2006 10:20 AM
Pinion Angle Hognose Brakes, Suspensions, Tires & Wheels 14 March 18th, 2005 12:24 AM
pinion angle gn4u2c Drag Racing Techniques 2 September 18th, 2001 08:26 AM
