Go Back   TurboBuick.Com > Tech Arena > Brakes, Suspensions, Tires & Wheels
Old December 7th, 2007, 10:04 PM
wheel adapter... safe?
Are they safe? A pair of Foose wheels I'm interested in are only made in the Mustank bolt pattern.
Trans-Dapt Performance Universal 5-Lug Wheel Adapters: TRD-7069 - summitracing.com
Insights?
go fast and turn hard parts
share.ovi.com/knero (see *mycar* channel for pix)
Old December 7th, 2007, 10:53 PM
Trader Rating: (8)
I used adapters when I had my old 18" wheels for months with no problems. I see no reason that they would be unsafe if they are installed correctly. Much safer than a regular "spacer" that doesn't have it's own set of wheel studs.
Old December 7th, 2007, 11:47 PM
I have them on my car. I view them as safe for everyday driving but I wouldnt ever launch it hard with them on. An image of my rear tire and wheel passing me as I skid to a halt keeps running through my head.
Old December 8th, 2007, 12:04 AM
chopped39's Avatar
Insights?
If you have the money Foose will make you any rim and bolt pattern you want. not cheap. or get the pattern and call billet they make any rim you want. you design it and they cnc it. plus they have a boatload of patterns already saved
87 LIMITED COLUMN SHIFT GOING TOGETHER
1990 ZR1 VETTE.
1939 CHEVY SEDAN DELUXE CHOPPED . 331 HEMI COMING SOON
1989 FORMULA GETTING TURBO TRANSPLANT SOON
1989 Camaro ragtop hybrid?
Old December 8th, 2007, 12:39 AM
TURBOELKY's Avatar
broken cars save gas.
I too think they are safe for daily driving, but would'nt go doing donuts or drag racing with them
1979 turboelky.
Old December 8th, 2007, 09:18 AM
Louie L.'s Avatar
Habitual Line Stepper
Adapters are safe for daily driving. But I just dont know about those. They look to be a cheap casting like a regular spacer. A billet aluminum spacer-adapter is the way to go.The billets are considerably more, but much safer.
http://community.webshots.com/user/10secv6
1987 Buick Grand National
Dart 400ci SBC, PTE106, PTE 2000 liquid IC, PTC Powerglide and converter
FAST XFI Dyno Tune by Cal Hartline
1989 Pontiac TTA
Old December 8th, 2007, 10:01 AM
kenny why 2 rims ???, you gunna run them on the driver or passengerside so nobody realizes they dont match the other two??
adapters like you show arent rated for much , definitiely dont use them on the rear
also consider
that youll need to cut down the stock lugs , (no going back without installing new lugs)
will the new rims work with the additional 1" BS that thew spacer will add?
other options ,
have your axles and drums drilled for 5 x 4.50, but again you cant go back to 5x 4.75 without replacing lugs
if you dont need to have the additional BS a better fix is drill the rim out for 5x 4.75 , if you go to shank style you wont need to do anything but drill it out
paul...magnabuick.com NJ rep
86gn bone stock shortblock ,ported irons ,71Q 75# , V2,ATR 3" HKS, ATR dual340m , 200-4r stageright, AC9"NL , TTWB 6.0, razor dual,msbc-1 ,LC-1..1.42 6.57 104.9 10.4 129.8
now w/ lonnie diers th400 w/brake, vig conv ,cometics 1.48,6.62,103.4,10.46, 126.9
87GN , duttneck, hipro, PTE65+ PP, 62TB, protorque 10.5", hooker duals, razor alky (dual), TTchip.
prev combo stock unopened w/TA49, 50#..1.57, 11.45, 117
now 030, steel mains, dutt cam ,msbc-1 ,LC-1 ,Cottons 3"DP Tial gate ,ported irons/intake ,turbosaver ,TE44,75#inj, 4" zo6 maf , bad 60' ..93.78 ,117.88 11.54 21psi
no race fuel ! no NOS !
all times on 93 octane
big thanks to
julio at alkycontrol.com
eric at turbotweak.com
Old December 8th, 2007, 01:15 PM
Thumbs up
Hey, Paul!!! Whoops, I meant 4 rims... the general consensus is that it isn't too safe, so I'll keep the wheel search going.
Old December 10th, 2007, 05:17 PM
PsYcHo GN's Avatar
Member Extraordinaire
I run wheel adapters on my GN with my 19" wheels. Never had no problems. I abuse the car and no problems.
I wouldn't go with those cheapy adapters. I would be afraid I would lose a wheel. You need to go with newer technology. I had mine custom made through Motorsport-Technology. They're hub centric. Probably the best adapters you can buy.
MotorSport-Technology
1987 Grand National - T-Tops, GNX Style Dash, Precision GT6152E, 23-Row Intercooler, TT Alcohol Chip (23-25 psi), Mototron 60# Injectors, AlkyControl, Kenne Bell Adjustable FPR, Port/Polished Heads, LS1 MAF/Translator, THDP, ATR Headers, ATR Pitbull S/S Exhaust, 3500 Stall, DRW Built Trans, Line-Loc, Brake Jumper Valve, Big Mouth Air Kit w/ K&N, Bilstein Shocks, Intrax Springs, Air Bags, Hotchkis Suspension, Scan Master, ANS Boost Controller, HKS Turbo Timer... 15" Weld Draglites w/ MT Drag Radials and 19" Axis Penta Wheels... Daily Driver!!!
1969 Camaro Z/28 - Restored
1965 El Camino - 408 SBC (Currently at the paint shop)
2002 Suburban Z71 - SUV for my daughter's sporting activities and road trips
1993 Toyota P/U - Parts Runner
Old December 17th, 2007, 03:42 PM
GNXwannabe's Avatar
Spacers
If you use a billet adapter/spacers you shouldnt have any problems. I have seen adapter/spacers used in dirt track racing with NO issues (tremendous stress) and have actually seen "steel" center wheels break and the spacers ramain intact! Make sure you use the specified torque (usually provided by manufacturer) I used adapter/spacers because of more selection in 18" wheels in the 4.5 bolt pattern and the spacing works out also with the different offset. Quality adapters are just like bolting on a wheel, if installed correctly you should have no issues. Good luck!
1980 taillight lense & a MOMO steering wheel adapter Jonuk Parts wanted 0 November 30th, 2005 05:46 AM
FS-Momo wheel and adapter Xplicit Parts for sale 0 October 18th, 2005 01:24 AM
Billit wheel adapter/spacers....... Gn-ing General Turbo Buick Tech 0 March 23rd, 2004 09:10 PM
Billet Wheel Spacer Adapter Websites 49-blues General Turbo Buick Tech 13 March 23rd, 2003 07:04 AM
