ATI had a sale on them a few months back. Check the history in the merchant ad section. I installed ine with the ATR sway bar and had to buy new GR8 bolts to fit, but it sure does look good under there
Best run 11.621 at 121MPH 86 T Top GN, TA49, 60's, Champion ported iron heads, Champion ported stock intake, Vigilante 3200 5 disc "O" pump lock up converter. Brian Hofer trans. T&D roller rocker and Comp roller cam Alky Control. http://community.webshots.com/user/jpratt725 http://www.fquick.com/8uwav6 |
box the factory ones and use poly bushings
84 gn/ 87 engine .030 109 ballanced, msd 50# inj, all billet mains, bms rods, 8445 champion ported heads, comp cams .459 lift, champion intake, precision fm, accufb 70mm tb, 340 fp hotwired, tt 93 chip, 3 in mcale dp, hooker cat back, northern alum rad, b&m tranny cooler. all on 93 octane... |
