What's happening here is that as the rear of the chassis is attempting to twist counter-clockwise, the torsion energy is attacking the weakest point of the rear portion of the body: the area you described, behind the rear wheel.
The problem isn't going to go away; In fact, it's going to tear your car up something aweful. If the front of the car isn't twisting violently, I'm guession that you've upgraded the rear chassis significantly. (Can't tell from your signature) Do you have a roll cage? If not, it's time. |
The car has a six-point roll cage , rear suspension is southside lower control arms and bennett uppers with airbags. Could polyurathane body mounts help , or would that make things worse .
87 GN ,T-tops, stock block, stock heads/intake ported by Champion Racing. Precision GTQ 70 turbo & front mount intercooler. Siemens 72 lb/hr injectors, Red's double in tank pumps and 106 chip. Art Carr 9" converter & valve body, transmission built by Tranny Tech. Plus other cool stuff. |
You said it's a "vertical crease", and it's behind the rear tire...be a little more descriptive about EXACTLY how the crease runs, if it's a straight line, the shape, etc. It'll help pinpoint the problem.
How do the rear bars of the cage come down to the frame? Through the package tray? Where and how to they attach to the frame? |
Since I can't see the car...where in the trunk are these plates...ahead of the rear end, I'm guessing? Last edited by QuickWrench : December 24th, 2004 at 03:05 AM. |
Attach the video to let us see the car launching.
Artie 87 Turbo T WE4 Event photos: Artie's photos (Updated daily) Good to the last drop:Race Fan [IMG]http://www.turbobuicks.com/forums/attachments/waiting |
From the sounds of the description of your cage, it is not NHRA legal for an OEM frame car. It sounds like that the rear end is flexing the rear of the frame enough to wrinkle the quarter panel. Since your cage is only welded to plates in the trunk floor the cage is not stiffening the frame, which is allowing the body to flex.
Here is a link to a NHRA tech page. http://www.nhra.com/contacts/tech_faq.html Note that in both diagrams it states that all cars with an OEM frame must have the cage welded to the frame. I think I'd have a talk with my cage builder. ![]()
6APPEAL 87 GN - street machine 87 GN # 2- TSM wanna be 00 GSE - wife's black, forced induction car 05 Chevy 2500HD Crew- it's black and turboed Looking for another Buick - 70-72 GS/Skylark convertible or 65-72 Sportwagon 85 T-Type - white, the anti-GN - Sold 86 GN - totaled with 88k miles in 2003 86 T-Type - Sold 78 Regal Sport Coupe - The one that started the boost addiction - Sold
Oh thanks a lot for the N.H.R.A tech on my roll cage
and a link to the rules , that really helps me a great deal .
Have noticed this on my car as well as a buddy's. I actually have a wave in my quarter now, almost a good sized dent. I would have thought someone leaned on it or hit it at the track, but it matches my buddies car that did the same thing. Passenger side quarter right behind the wheel, about the 10 or 11 o'clock position of the wheel well. We are both running 10.5 tires, 10 point cages tied to the frame. Rear bars going through the package tray and tying right above the axle. Didn't happen until after we installed the wolfe sway bar setup. Sixty foots are in the 1.35-1.45 range. 3600 lb Buicks running 9.0 in the quarter. I am about to repaint my car, so we will see if it happens again.
Greg Kring 9.05 @ 150 |
Greg, if you did'nt do any suspension changes it will happen again, whatch the car on video it's impressive to see. As of now I dont have permanent damage but thats what im trying to avoid, I was considering welding a solid bar to tie in the frame rails like the wolfe bar does, but if your car still does it with the wolfe setup so much for that idea. Anyone with a solution im all ears.
87 GN ,T-tops, stock block, stock heads/intake ported by Champion Racing. Precision GTQ 70 turbo & front mount intercooler. Siemens 72 lb/hr injectors, Red's double in tank pumps and 106 chip. Art Carr 9" converter & valve body, transmission built by Tranny Tech. Plus other cool stuff. Last edited by GO FAST : January 3rd, 2005 at 04:21 PM. |
[quote]GO FAST Oh thanks a lot for the N.H.R.A tech on my roll cage and a link to the rules , that really helps me a great deal .
Man why be such an ass? The guy was just trying to point out that if the cage was'nt welded to the frame that it might cause the flex your talking about. Geez
85 Gn in Progress (In loving Memory of Allan) 99 SS camaro (Sold, Damn I miss her) 69 RS camaro Allan This one's for you! Pics: http://pg.photos.yahoo.com/ph/paul69camaro/my_photos |
If he was simply trying to make a point about the cage being welded to the frame or not , just say so, not come off right away and state "It is not legal for an oem car". I could build a much better , stronger cage than a "legal" one which may be illegal by NHRA rules.
Anyhow enough of that , this is gradually getting off the topic. |
Not too worried about. Just repeating the NHRA rule.
GOFAST, NHRA makes rules to prevent deaths from accidents at the track. We had a guy locally think the same as you, he could build a stronger cage that was not NHRA legal. I will say the cage looked very impressive, kinda Pro-Mod style. But, he was kicked out of every NHRA/IHRA sanctioned track in the southeast since his cage could not pass Tech. He could only street race or backwoods track race. Well, the guy is 6 feet under now. 3 years ago he rolled his MCSS on top of the guard rail at about 150 on a little track outside Jackson. The body seperated from the frame since his cage was not welded to the frame. He was sliced into 3 pieces as the body came apart. Don't take this as a flame. It's your car and your life. Live it as you may and I hope you don't meet a similar fate.
Does the car have tubs? Wheely bars? Sounds like the frame is flexing between the rear body mounts and the next-to-rear body mounts. Two suggestions:
Box/stiffen the rear section of the frame. If frame rails were notched for bigger tires/tubs, that could be the flexy spot. Run braces from the roll cage back to the frame, as far back in the trunk as you can without getting into the sheet metal.
George W |
Have you notched the frame? I have seen this happen in lots of cars with notched frames. If you don't have a fuel cell then there is no weight on your frame behind the axle. Really all the frame does is hold up your rear bumper. The first problem is your cage is not tied to the frame and when you leave the springs and shocks are pushing upwards on the frame. If your frame is not strong enough then it is also flexing upwards causing the rear section of the body to crease as if you were jacking the car up using the rear bumper. A cage must be tied to the frame for real benifits, it's not just about protecting your head but also about strength and tieing things together. The best location to tie t |
