Anyone using these tires?
Been out of racing for a while. I noticed that Mickey Thompson is making a drag radial. Is anyone using these? How do they work?
Thanks, I need a set of tires for my TR, but tossed up between these and the ET streets.
Thanks to everyone on this board that's helped me out over the years.
I can only see 2 scenarios for which DOT legal "race" tires, bias ply or radial ply, might apply:
1. When the cop writes you after your street race, you'll only have 10 violations, instead of 11. No matter, they'll still crush your ride. 2. If you drive to the track, but can't be bothered with slicks, and are willing to go slower. None of these pretenders matches slicks. Especially as consistency goes, so if you like or have no choice but to bracket race, well... Besides, TRs are a handful to launch to begin with - a little too much boost and away go those DOTs. The ironic thing about DOTs is that they wear out in a few thousand miles, making them just as illegal as a slick. So, why??? Also, they are useless in bad weather - so if you get caught in the rain - you're dorked. And at the rate they wear out, you'll be reaching into you wallet plenty to keep your ride legal. Oh, I forgot to mention, they pick up every little pebble, every little piece of crap on the road and throw it on your quarter panels - can you say paint job? Those tires are for guys with limitless $$$ who run DOT classes at the strip, in their "street" cars (having parachutes), and that's about it. ![]() Last edited by strikeeagle : October 18th, 2004 at 02:37 PM. |
I think they are better than ET Streets but I don't think they are that street friendly. In Orlando this past weekend Rick Head went 7.66 @ 187(?) on a pair. The word is that they are more like a slick than the BFG's and I just read that FFW will spec BFG DR's for 2005 b/c they are too much like a slick in performance.
ks ![]()
Tech Page,~~Launching a Drag Car,~~BaselineSuspensions.com~ ~Project F150~ Suspension Moderator @ Hardcore50 Diary of a GN 87 GN 12.05 @ 111, 1.60 60', 15psi launch New mods: 12.16 @ 109- Best 60' 1.60 @ 22-23psi Stock Turbo Stock IC w/ stock neck MaxEffort |
The M/T DR is better than the BFG and seems to be better than the ET Street.
they are not slicks, but the MT DR's are the best DOT legal drag tire out there including ET Streets and Hoosiers.....
I haven't gotten mine exactly figured out, but they definitely hook better (and drive 10X better than ET Streets) one local guy, got his all time best 60' (1.53) with 'em (he ran ET Streets before) this on a car he trys to keep to 12.00 (no bar), but his 60's are so much better, he has to turn things down......... they have limited value, but the times I don't feel like changing tires, these will do (have run 10.9's on 'em with 1.6 60's.....lots more in them I feel)
Woody Basic TSM recipe 24 lbs boost |
Used my 275/50 M/T's two times now in the rain and they were fine. Were not squirrly at all. But they are brand new so we will see how it goes when they get some miles on them.
Here's a pic if anyone is curious as to what they look like on a (dirty) GN. The rubber stuck to the tailpipe is NOT from the M/Ts - that thar's Hoosier rubber.
M/T Drag Radial Jim |
curious as to what you have on the front???
87 GN, Walbro 340/Hotwire, Hooker Duals,RJC Plate & Pulleys, Big Mouth Air, T+/ LT1/Extender, THDP, 50's, Big Neck IC, Razor's Alky,8" GN Rears, Air Bags, Stock Turbo |
Jim |
turbojimmy
Do the M/T throw little rocks onto the rear quarter panels like all the other drag radials?
DAN - 87GN 11.52 @ 119mph Pump gas, methanol injection, TE62, 3000 NL Art Carr, 206/210 Roller, THDP, 50#inj, PTE intercooler, SMC Alky, Eric Marshall chip, Hueffman cold air, Nitto drag radials |
I've literally sandblasted the clearcoat and in some cases the paint from my 1/4s by using sticky compound tires as my "drivers". There's not really any way around it (other than not using them). Jim |
It looks like I'm going to be the FIRST on using a set in the 7" T-Type
wheel friendly 235 size. And Next weekend at our Maple Grove Test & Tune whe'll see how THAT size hooks!!! I HATE that Big & Little "Lets Race" look, so if I have to sacrifice a 10th for a Stock apperance, then so be it!!
Mint 6700 Orig, mile 86 T-Type! BEST Eastern PA Classic car Club: http://www.bknightscc.com/ |
Ran the car today for the first time with the Mickey Thomsons on it. I only got 2 runs in so I didn't have a lot of time to experiment.
First run the tires were at about 29 PSI. I just spun 'em a little to get the big stuff off of them. No water, no big burn out. Got a 2.1 60'. The car spun pretty much half the track 'til they hooked. Second run dropped the pressure a couple pounds (to like 26 PSI). I backed it into the water and did a burnout. Not as long or as fast as I would with slicks, but enough to heat them up. Got a 1.80 60' time. They felt great out of the hole. I think with some practice they'd do as well as my 27" Hoosiers. The MTs are trickier to launch, theoretically, because they're stock height (easier to break loose). The street and high-speed track experience on the MTs vs. Hoosiers can't be compared. The Hoosiers have very poor street manners and are a little scary at speed IMO. The MTs, without exaggeration, are like driving on regular radials. So I'm willing to sacrifice some 60 time for the better street manners, but I don't think I'll have to. The car ran decent for not having really made any attempt to tune it since I brought it out of hibernation. Boost was at 20 PSI. Ran 12.5 @ 112 and 12.0 @ 114 (second run turned the boost up to 20 - didn't know it was so low but didn't get another chance to run at higher levels). My brother had the same tires (275/50s) on his Turbo T today, too. Both runs he just rolled up to the line. First run was a 1.9 60, second was a 2.1. His car is a mid/low-13 second car (as of today, actually. It ran really well). He had the tires at 28 PSI. Hope that helps someone. Jim |
I've got a set of the ET street radials, and they are great. Pulled a 1.63 60' with 20psi of pressure in them. I do not use them on the street just because they are really soft, and I think that they would be worn out in no time flat.
1989 TTA #798, A few mods. It still knocks when warm. Soon to become an alcoholic. My Son's Car: 87 Turbo T, 204/214 cam, TE62, MSD 50's Chip by Eric @Turbo Tweak. Best ET 11.55 Best MPH 120.50 with a 2.10 60' with MT ET Streets. We are working on the 60' times. 2002 Dodge 2500 4X4. Yes, it has a Cummins. |
Should of also said that mine are a 275/50-R15 on a stock set of t-type wheels. I do have to use a 1/4" spacer though.
These tires hook great, won't buy anything else in the future. I did my best 60ft with these which is a 1.52 on 9lbs of boost launch, and 16 psi of air in the tires. These are the tires I use for the car all summer long but I only put 1000-1500km a year on the car. I could tell you they seem to use up pretty fast but I can't tell you how fast because it still doesn't make a year I have them. I love using these tires on the street because I want my car to run the same on the street as at the track. I could only compare them to my M/T et streets (26 11.5),and they ride much better than those. My best 60 ft time with the et streets is 1.62 but I didn't have thdp when I did this. I never use the car in the rain so I can't tell you how good they are when the streets are wet, but I have read that they are pretty bad in the rain and dangerous. Hope this helps.
Marco 86 Grand National t-top (59000km) stock long block,stock suspension, red stripe convertor, te44, smc alk injection, 24lbs boost, 94 octane, hooker cat back with dyno max ultra flow muffers, tomco 30lbs injectors, dynotech stage 4 street chip, thdp, mease 24 row IC, MT drag radials (275/50/15) 3800lbs race weight with driver. best ET 60FT=1.52 1/8= 7.38 I/4= 11.74 MPH=113 BEST MPH= 114 |
