hold more boost?
i was wondering how i could hold more boost at the line? i dont want a line lock but with my street tires i can only hold about 3#s. also i drive the car every day even in the rain and i dont want the back brakes to lock up on me. thanks
jerrad
87 turbo t: TE44, razors alky kit at 24#s, k&n 9 inch filter, 009 injectors, rjc power plate, exhaust with test pipe, 3 inch DP, turbo tweak chip, new valve springs, fuel pump, and hot wire kit. |
Cheap method.....
....Try locking the E-brake, then step on the brake. You should be able to get a few more pounds. The S-10 cylinders will work, but may make the rear brakes a bit more touchy while street driving. The Trans Brake is the ultimate setup, but can be harder on the drivetrain.
Rickracer www.rickracers.com I am not a GN/TR, Buick V6, or turbo guru by any means, but I am an ASE certified Master tech with 29 years experience. |
Do a search for Jumper Valve..
ks ![]()
Tech Page,~~Launching a Drag Car,~~BaselineSuspensions.com~ ~Project F150~ Suspension Moderator @ Hardcore50 Diary of a GN 87 GN 12.05 @ 111, 1.60 60', 15psi launch New mods: 12.16 @ 109- Best 60' 1.60 @ 22-23psi Stock Turbo Stock IC w/ stock neck MaxEffort |
