81 Turbo Monte won't run on computer
Hello all
I am reviving an 81 Monte Carlo T-Top Turbo with automatic tranny. It didn't run when I got it (barn find), opened up top of engine and everything looked great, turbo is tight and spins freely, only bad parts I found were the EGR solenoid (anyone have one?) and the knock sensor (connection was broken off sensor, replaced it with a shiny new $104 replacement). New gaskets, wires, plugs, caps, rotors, rebuild on carb. Now the problem: If I disconnect the 4 wire connecter from the distributor, it starts great, timing is right on 15 degrees, and it runs weak but it runs down the road. Plumbed a test vacuum/pressure guage into the passenger compartment and its getting up to around 0psi but no real boost - attributed that to the lack of computer control and spark advance. But if I hook up the 4 wire connector it immediately retards the timing fully (off the scale, can't even see the mark) and it bucks, snorts, even backfires through carb occasionally. Takes a lot of nursing of throttle to even keep it running. Scared to try to even get it into drive with it running this bad! ECM is not throwing any codes - repeats "12" over and over as long as test connector is jumpered. I started another thread looking for where the ESC is so I can ohm out the connection to the knock sensor and run through the diagnostic procedure in the shop manual. I don't know if the car ran when parked, but its in great shape - the interior cleaned up great and the paint even took a shine. Any ideas? Anyone see this before? thanks Dave |
It almost sounds like you've got the distributor in the wrong place. Check the timing with the esc and remember you have to short out the aldl to time it properly. Just plug into the diagnostic plug and time it.
Just a another twisted kinky six. |
The computer sets the timing but the esc retards the system in the event of knock. I may have the wrong procedure but I think that is the right way to set the timing. Either way you have to short the esc to set the timing and set it first then the esc and computer take over.
ok what i would do is try unplugging the knock sensor and see how it runs witht he 4 pin harness connected to the dist.
if that don't yeild and good results try locating the ESC module (should be located on the pass inner fender) unplug it and see how it starts running. The esc module is what commands the ign timing to retard when it get a knock signal for the knock sensor. The ecm may be apart of that too i i don't think on the early models. HTH pat broughton
http://www.turbomalibu.com/1SloGN.htm best time slip 1.55 60ft 7.20 / 95 mph @ 22 psi |
| Turbo Monte | DOUBLE-O | HYBRIDS | 110 | October 1st, 2008 04:53 PM |
| Where is ESC on 81 Turbo Monte? | dhattey | Before Black (non-SFI) Tech | 1 | September 4th, 2008 11:54 PM |
| Turbo Monte Help | burnout | Hot Air (non-intercooled) Tech | 9 | June 10th, 2008 12:44 PM |
| Turbo 6 Monte????? | 87gninpa | Turbo Lounge | 23 | May 1st, 2008 05:07 PM |
| turbo from a monte, what is it? | loddi | General Turbo Buick Tech | 3 | March 29th, 2003 05:32 PM |
