Go Back   TurboBuick.Com > Tech Arena > Before Black (non-SFI) Tech
Old April 26th, 2008, 08:54 AM
the 1978 to 1987 rear end are them same !
i try to find a rear end 8.5 and i found one from a regal 1978 ! it is the same of a gn 1987 ! ......if not what is the diference ! thay look the same !what kind of car is the same rear end of the tr's (year and model ) thanks
subaru WRX STI ,3"exaust,top mount,780cc inj,alky and more....
gn t-top daily driver stock!
gn t-top 87 whit those modif
109 block,eagle rods,j&e forge piston,rjc heads gascket,arp bolt and stud,rjc gardle,pt70gtq ball bearing turbo,72pound inj,hot wires ,gn1 iron head,inj harness,aeromotive fuel pump,alky kit by julio don,accel dfi,atr 3"down pipe,hoocker exaust,ta headers,comp cam 212/212,roller rocker t&d,presision front mount,70mm t-b and planium,4" ram air ,champion spacer and fuel rail,20"rims back 18 front,BEILTECK nitro drop 2 ",pte 3800 9"stall from Dusty Bradford (is on the way )art carr tranny,energy suspension bushing and all braces kit.....
picks at: http://tybob.monchar.com/
Old April 26th, 2008, 06:20 PM
Naturally Aspirated
All G Body's shared the rearend (7.5" or 8.5"), the only difference was the 8.5 required a different size driveshaft (shorter by 1 inch).
Rearend Swap Tech
Will
1979 Olds Cutlass Supreme, NA BUICK V6 Powered.
Edelbrock intake, Holley 570cfm 4bbl w/ Vac secondaries, Hedman Headers, MSD 6AL, TH-350, 2.41 highway rearend.
Old April 27th, 2008, 06:57 AM
but the 1978 was a A body or a G body ! some guys say is a A ! that why i ask that question ! ....if the 8.5 1978 have the exact same hosing then the 8.5 1987 tr's , and what is the exact size back plate to back plate of a tr's 8.5 rear ! where i can get the spec ! thanks
Old April 27th, 2008, 09:46 AM
Naturally Aspirated
The 78 and 79 "A Bodys" are the first "G Body" cars. GM changed what the platform was called, not how they built it or what parts they used.
Any how, I beleive you're stuck to looking at later 80s GM cars, specifically the GN, T Type, Hurst/Olds and 442. The monte SS had a 7 5/8s" rear ring. and the others were 7.5. I'm not sure if they even had 8.5s in the A Body cars.
G body.org says-
" First, ALL GM 1981 to 1988 G-Bodies used a 7.5" ring gear rear axle EXCEPT: Monte Carlo SS - 7-5/8" 3.73, Olds 442 - 8.5" 3.73, T-Type and Grand National - 8.5" 3.42 or 3.73. "
Differentials - Code Listing
Hopefully someone else will chime in and verify that i'm giving you the right advice.
Will
Old April 27th, 2008, 03:39 PM
I think the 84-87 turbo buicks came with the 8.5. Also the 442 olds had the 8.5 also. Hope this helps
Old April 27th, 2008, 04:53 PM
84-87 hurst and gns used 8.5 78-84 used 7.5's.I have put the 8.5 in a 79 which came out of a 87 gn. There was no difference that I can remember, other then wheels studs were metric on 87 and 79 was not. The only other thing i think was different was the brake lies,not for sure...Reason I know this is because my brother has a stone stock 78 turbo sport coupe which has blown up the 7.5 ,3 times so when we found a 87 gn local we purchased the 8.5 out of it. Hope this helps
87 GN - updated bottom 206/210 roller cam, 61mm p trim bb turbo,adjustable acctuator,60lb injectors,75mm tb ported plenum,Ported stock irons big valves,ported intake,Turbosmart manual boost controler,RJC power plate & pullies,accufab afpr,255+hotwire,maf translator (6.25),4 inch big mouth intake with integrated sensor, Gbody 21 row stock mount intercooler,3.42 gears,2800 stall,shift kit,3inch tt exhaust,3" tig masters down pipe,poston headers,razor single nozzle progressive alky kit,tt alky chip, scanmaster,powerlogger,28" m/t drag radial, was original....
92 TY
Boosting the dark side off things
Old April 27th, 2008, 08:00 PM
ok thanks , so if i found one 1978 whit a 8.5 mayby it come from a diferente car ! or is a special order like the tow pacage !thanks your responce help
Old April 28th, 2008, 12:50 PM
b4black's Avatar
The 1978 8½" may be from a Camaro/Firebird. You don't want that.
Rich
BEFORE BLACK Website
1982 Regal GRAND NATIONAL
1983 Regal T TYPE 14.21 @ 93.75 mph - Have I caught the IC cars yet???
1998 Regal GS (after black?)
Chicagoland Chapter GSCA
Old April 28th, 2008, 02:20 PM
88 CuttyClassic's Avatar
Rocketman
the complete answer
here is the correct answer in total.. in 1982 the A-body designation changed to G-body. most people get confused because of the sheetmetal change in 81 but the 82 is technically the first car to be called a g-body by GM.. there was no major change underneath from 78-88. Again the only changes were the sheetmetal in 81 and the designation change in 82. As far as the olds cars with 8.5's its the 1984 hurst (not the 83) and the 85-87 442. it was rumored the 88 cutlass GT had 8.5's but this has yet to be proven and only 200 or so cars were ever produced so its dont really matter.
R.C. ENTOURAGE
88 Oldsmobile Cutlass Supreme Classic (R.I.P. 3/4/01)
85 Chevrolet Monte Carlo SS "Black SS with the tops blown off"
83 Hurst/Olds
84 Hurst/Olds
70 Buick GS Stage 1
69 Plymouth RoadRunner440 6BBL
Old April 28th, 2008, 08:07 PM
Don't forget that some of the monte carlo ss came with an 8.5" rear end.
Old April 29th, 2008, 09:16 AM
b4black's Avatar
I would disagree with that.
Rich
Old April 29th, 2008, 07:25 PM
rosewood turbo's Avatar
Trader Rating: (6)
Actualy Ive has 3 SS's over the years and they were 8.5 but non posi and 373 gears.
Old April 30th, 2008, 03:31 PM
Than somebody other than the factory stuffed them under there. Really if the 8.5 came in Montes than you wouldn't be seeing the 8.5 going for $1000+ in the parts for sale section.MCSSes are a dime a dozen. Over 100,000 of them built in their six years of production. The 83-84 models with the THM350C came with 3.42s. The 85-88 with the 200-4R came with the 3.73. All 7.50s.
Only the 84-87 turbo Buicks and the 84-87 Cutlass H/O-442 came with the 8.5 from the factory as standard equipment.
I'm beginning to think a lot of people cant tell the difference.
Eric Fisher
OEM Parts Specialist for GM Vehicles
86 Grand National
85 Riviera T-Type
84 Riviera T-Type
82 Regal 455
Old April 30th, 2008, 09:08 PM
Here are some pics I took because I had the parts on hand.The 7.5 is more square than round and the 8.5 is almost perfectly round.
Pic1 7.50 on the left. 8.50 on the right
Pic2 7.50
Pic3 8.50
Eric Fisher
86 Grand National
85 Riviera T-Type
84 Riviera T-Type
82 Regal 455
Old May 1st, 2008, 10:22 AM
b4black's Avatar
Good page:
Dorians Diff page!
Rich
1987 GN rear seat incharge Parts for sale 3 August 7th, 2007 04:05 AM
New 1978-1987 Regal - GM ROOF RAIL SEALS fgordon Parts for sale 3 March 20th, 2007 10:03 AM
1987 t-type 8.5 10 bolt rear XSboost Parts for sale 3 October 19th, 2006 09:23 AM
1978 - 1987 GM G-Body Lower Control Arm Relocation Brackets tbirdv6 Parts for sale 2 April 20th, 2006 08:25 PM
1987 GN POSI 8.5 rear end Quick6'n'-K.C. Parts for sale 1 February 26th, 2006 10:12 PM
