I'm 99% sure you only put one on the outside of the pipe, but maybe I'm remembering wrong. Even after the nozzle is tight, it will still "swivel" on the pipe if you try to move it.
Per the instructions:
![]() 1987 Regal LC2, hot-wired, Walbro 255 lph fuel pump, blue top injectors, Accufab adjustable fuel pressure regulator, Turbo Tweak chip, GN110T cam, TE-44 turbo, Alkycontrol, 3 inch mandrel bent Dynomax exhaust, Scanmaster, OD lockout detent plate, RJC power plate and RJC boost controller Quote:
Take off the 1/8 npt to -4 adapter.. look inside the hole with a light.. and make sure the tip of the nozzle with the screen is not bottoming out. If it is.. then add the external washer. The washer is used to make up for variances in thickness in the pipes. Aluminum pipes always need it. Steel pipes.. some do.. some dont,
You cannot tell with the little adapter you have on as pictured. HTH
89 TTA Stock appearing 10.550 at 132.22 1.539 60ft 3850 race weight w/driver Always on 93 octane www.alkycontrol.com 727-570-9999 |
Thanks I think I figured it out.
| FS. valve cover 6 black acorn nuts & rubber washers ,steel washers | JKessler | Turbo Trans Am Tech | 2 | March 19th, 2007 01:51 PM |
| FS: SMC Dual Nozzle Alky kit for TTA w/ chrome up pipe | Sy1680 | Parts for sale | 0 | November 7th, 2005 01:18 AM |
| Best location in up-pipe for alky nozzle? | 2QUIK6 | Alcohol, Nitrous and Propane Tech | 1 | June 26th, 2005 12:12 PM |
| MAF in the up-pipe...Where do I mount the nozzle? | Sleeper | Alcohol, Nitrous and Propane Tech | 16 | December 4th, 2003 01:00 AM |
| slight leak on up pipe at nozzle | JeffW | Alcohol, Nitrous and Propane Tech | 5 | April 20th, 2003 01:00 PM |
