My PAC control box sure clicks a lot..
even at idle. Is something wrong? I have not used it yet. Everything is istalled except for the pump being grounded and filling it up with alky. Let me know thanks!
EPH 2:8-9 “For by grace are ye saved through faith; and that not of yourselves: it is the gift of God: Not of works, lest any man should boast.” 85 WH1 T-type converted to intercooled. Champion ported intake and doghouse, pplate, Accufab 65mm, ported GN1s , 55s, 212-212 Comp roller, .040 TRW, RJC pulleys, girdle, Precision stock location, Precision 67 H cover turbo , Precision 3000 stall, Eaton, LS1 brakes, Bilsteins, Belltechs, Lonnie Diers tranny, Beehive springs of Hendricks Racing prepped by Scott Schumacher. Best time 15.33 @ 88mph in reverse! Finally building a Stage II... goal is to finish it and still be happily married to the same wife
the pump grounds at the controller......hook it up.
1 OF 5 METHANOL TEST CAR LOTS OF BOLT-ONS TO MAKE IT GO SLOWER SOME INFO ON MY CAR;http://www.turbobuick.com/forums/gen...l-t-types.html |
So just we're talking about the same ground...
The white wire that has the crimped eye on it coming out of the pump, right?
Your condition sounds like bad ground or connections with the pump cable bare wire.
89 TTA Stock appearing 10.550 at 132.22 1.539 60ft 3850 race weight w/driver Always on 93 octane www.alkycontrol.com 727-570-9999 |
I'll double check things. Thanks!
| Blower motor spped control (Climate Control) | CS99 | Parts wanted | 0 | April 13th, 2008 02:29 PM |
| How many clicks on the emergency pedal? | copo | Brakes, Suspensions, Tires & Wheels | 2 | September 30th, 2007 07:29 AM |
| TV adjustment..how many clicks?? | streetknight | Transmission Talk | 2 | May 31st, 2005 09:41 PM |
| 8.5" Posi Rear / Metco Rear Control Arms / Stock front control arms | streetwavesauto | Parts for sale | 0 | May 9th, 2005 06:32 PM |
| How to add fatrory cruise control to an 86 T-type with cruise control delete? | 87 WE2 | General Turbo Buick Tech | 5 | May 17th, 2003 10:01 AM |
