Go Back   TurboBuick.Com > Tech Arena > Alcohol, Nitrous and Propane Tech
Old June 18th, 2007, 09:14 PM
Signal 1 J-12
Pump runs on its own...Julio please look inside.
One of my customers brought his GN to me yesterday and says that he's driving down the road and the car started to run like crap and bog down. He continues on to a safe place to stop on the highway and the next thing he notices is his low alky level light came on. Shortly after the low level light came on he notices that the car cleaned up and ran great. He stops, pops the hood and notices that the once full alky is now empty. I'm thinking the MAP sensor went bad and triggered the pump...any other ideas Julio (it's one of your kits)??? What would cause this? BTW, when he turns off the controller the alky pump stops running.
Joe Reif Jr. Paola, Kansas
2008 Can-Am Renegade 800
2007 Harley Davidson Road King FLHPI
2005 Chevy Silverado 3500...Oil Burner
1987 Turbo-T...light blue metalic/dark blue interior 83k miles
Best 1/4 mile time: 10.91
Best 1/4 mile speed: 121.07 mph
Best 1/8 mile time: 6.87
Best 1/8 mile speed: 99.32 mph
Best 60' time: 1.42
All runs on 91 octane, methanol injection & MT drag radials.
Chip programming by: Eric Marshall @ www.turbotweak.com
Meth injection by: www.alkycontrol.com
My email:pdq6cyl@midwest-connections.com
Old June 19th, 2007, 09:22 AM
Razor's Avatar
Forum tech Advisor
Joe, have him unplug the 3 bar MAP and see if the system appears to be running normal. If so, then the problem points to the MAP sensor.
At that point, next move is to confirm 5 volts on the MAP sensor gray wire, and confirm Ground on the black wire.. if so.. the green wire key ON should be ~1.6volts. If the green wire is 1.6 then my system should not be running.
My thoughts.. dirty or bad contacts on the MAP plug black ground terminal.
Hit me back,
Julio
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old June 19th, 2007, 08:25 PM
87natl's Avatar
Fade 2 Black
Julio, you kick ass.
And people wonder why your system is so highly recommended......
'87 GN, STROKED n ROLLED.
First dyno results on a 95 degree day, 21psi and a TE60.....556 rwhp. Pump gas and alky.
*New 6776 BB installed, dunno the new HP #'s, but.....does it matter???????
99 Regal GS Sold
70 GS- Sold
Old June 19th, 2007, 11:03 PM
I had a similar issue, The main harness fell down onto the hot downpipe and melted a few of the wires. Apparently on of the ones that melted grounded out and fooled the system into thinking the car was at full boost causing a lot of alky to flow when it wasn't needed.
Big Dreams, No Cash, but a whole lot of Creativity mixed with a little bit of Stupidity!
87 Grand National - TE-61,Big Mouth Cold Air, LS-1 MAF, RJC Power Plate, 72lb Inj,Ported Irons, Comp 212 Roller, ATR Double Pumper, Big neck IC, Progressive Alky, Mease 3" Downpipe, Test pipe w/dump, ATR 3" Crossflow exhaust, Trans+ and Extender Extreme, Pro-torque 3200 converter, Nitto DRs On the injured list .....Be back in the spring with a new 109 stroker.
06 TrailBlazer SS - Stock.....................For now.
So far she's gone 12.56 at 110.3 mph @17psi in Street Trim, 2.04 60 Ft.
Julio, pump amps?? scot w. Alcohol, Nitrous and Propane Tech 2 January 21st, 2007 11:19 AM
GN barely runs! ScanMaster #'s inside. themodfather General Turbo Buick Tech 11 March 16th, 2006 01:15 PM
Curiosity!!! Why are fuel pump electrical connections inside the tank!??? Scott4DMny General Turbo Buick Tech 18 May 26th, 2005 10:26 PM
Key-on fuel pump always runs on double setup? tim87tr General Turbo Buick Tech 2 August 9th, 2004 12:29 PM
Fuel pump runs continuously Sagecoach General Turbo Buick Tech 6 April 22nd, 2004 05:08 PM
