I wouldn't see any problem with doing that but are you sure you have to? I run 24-25lbs. with 94 octane with alky and am 100% knock free. I'm somewhat conservative with my tune and, judging by my Scanmaster numbers, I'm sure another psi or two wouldn't be much of an issue.
'87 GN (20,XXX miles) GTB6131E, PT&E SLIC, TurboTweak 93-94 chip, Razor's Alky, G-Body Downpipe, Hooker 2.5" testpipe back exhaust, 60lb Mototrons, 9" K&N, 160 t-stat, RJC Powerplate, Scanmaster, Walbro 340 hotwired, Adj. FPR, Eaton Posi, GNX-style dash, Hydroboost, Janis "Stage 1" Transmission, Baer 13" front/12" rear disc brakes, Vintage Wheel Works 45's 17x8 4.5"BS (Nitto NT555 245/45) and 17x9 4.75"BS (Nitto NT555R 275/40). ![]() Best ET - 12.45 at 115.26.....true street radials (2.06 60ft.), 24lbs of boost, 23/21 timing.
Digital LED Tail lights ![]() 1986 T-Type GNXRay (X-ray clone) White W/black out trim, Grey leather int., LED taillights from InjectionX, H&R engine Mounts, 55lb injectors, G-body parts S.L.I.C, 9.5" (Dusty Bradford) PTC N/LU conv, Trans re-worked by Todd Lyle, Walbro 340, Hot wire kit, RJC powerplate, 3" TH down pipe, ATR 3" Stainless Steel dual exhaust, 4-Adjustable drag shocks, Southside uppers & lowers, Carrilo rods, JE forged pistons, Driveshaft loop, powdercoated & polished GTA rims.. 1986 GN - 6.76 @ 103.8 1/8th - SOLD 1987 WE4 - SOLD |
Listen, if you feel it gives you an added amount of detonation protection.. you cant ever have enough octane. Dont go too crazy, just use some turbo blue or 110 oct equivalent.
I know some say that they can hit 35 PSI on 93 octane, and I know I have.. but when your figuring out your tune-up.. it is cheap insurance. Richie runs turbo blue and meth on his 109. Car has run 9.5 at 142. So at what point is it needed.. guess that always settles on a personal decision. No downfall except money.
89 TTA Stock appearing 10.550 at 132.22 1.539 60ft 3850 race weight w/driver Always on 93 octane www.alkycontrol.com 727-570-9999 |
| Alky and Race Gas | Boost231 | Alcohol, Nitrous and Propane Tech | 0 | May 22nd, 2007 11:31 AM |
| Alky or race gas? | 87NAT | Alcohol, Nitrous and Propane Tech | 8 | November 17th, 2006 06:16 PM |
| race gas and alky? | chevyII | Stage II Tech | 2 | August 21st, 2005 12:12 PM |
| Race gas and Alky??? | BuickMike | Alcohol, Nitrous and Propane Tech | 2 | April 5th, 2005 09:53 AM |
| alky with race gas and race chip | turbot2112 | Alcohol, Nitrous and Propane Tech | 3 | January 17th, 2005 09:44 PM |
