Go Back   TurboBuick.Com > Tech Arena > Alcohol, Nitrous and Propane Tech
Old May 6th, 2005, 02:27 PM
The Green BEAST
How big a hole in alky tank?
How big of a hole do I need before it gets too small to keep up with the sureflow? I have a volvo washer tank and the opening is pretty small . The reason I want to stick with this is because its almost a gallon. :P
Any ideas?
Thanks!
R.I.P.
87 Buick GN motor and trans in a 242 Volvo. 12.59 @ 113
Video
Mods
Postons 202 cam ,TE-62, 3" dp and 3 1/2 exhaust all the way back. p plate , 009s,adj billit top fpr,. Pts shift kit and preasure reg. New TRanny! Ford 8.8 (3.27:1) 11" drums and Powertrax no-slip locker ,Lt1 MAF and Translator + & extender chip
Old May 7th, 2005, 07:37 AM
Razor's Avatar
Forum tech Advisor
I use a bulkhead that has a 1/4 npt inside thread. So far no issues.
I do know that a restriction to the input of the pump will create a pressure drop on its output.
Thats if trying to develope lots of flow out of the system at higher pressures.
89 TTA Stock appearing
Always on 93 octane
www.alkycontrol.com
727-570-9999
Old May 7th, 2005, 12:17 PM
The Green BEAST
sounds good
I thought maybe that 1/4 to 3/8 would be better I, think this one is 1/8.
R.I.P.
Video
Mods
Old May 7th, 2005, 07:10 PM
The Green BEAST
What fittilng?
I know some of you guys have drilled holes in they tanks. Is there a fitting that wold seal and hold up to the alky? I am going to have to drill the tank though. So any ideas?
Thanks
R.I.P.
Video
Mods
Old May 8th, 2005, 07:49 AM
Razor's Avatar
Forum tech Advisor
Re: What fittilng?
Thanks
Ya missed the answer,
"I use a bulkhead that has a 1/4 npt inside thread. So far no issues."
There is no off the shelf fitting at a hardware store that will do this. Unless i'm wrong.. i've looked into this and spent a considerable amount of time.
HTH
Always on 93 octane
www.alkycontrol.com
727-570-9999
