I went with the dominator because of the built in transmission controller and the extra I/O.Why a Dominator? Is this a race car?
Depends on exactly what you would want to do with the car.what about would it cost to do a complete install of a holly dominator system in a Running GN with a stock computer? I need the allky hooked up as well as the wide band. Everything works now. With the Holly dash.
It's a valid question though. On the HP vs Dominator the main things to know are the limited I/O and the trans control. If you can fit in the I/O of the HP you can save $1000; if you don't plan on using the NTK o2 or low impedance injectors you might also be able to go to a Terminator-X setup and save even more.My ? was directed at the OP.
Sorry, I should have made that clear in my post.
You might want to look at the ecuGN too. There seems to be a nice digital dash (dd-efi?) out for it now and it can do what you are looking for. The plus for it is it will plug in to your stock wiring harness.It doesnt have to be the dominator. I just want to be able to tune the car and have the holley dash instead of the digital dash I have now. I would like to have traction control as well as boost, alky, and wide band. This is not a race car all though it could be.
As far as sensors I would make it a priority to use the better/faster o2 sensor.It's a valid question though. On the HP vs Dominator the main things to know are the limited I/O and the trans control. If you can fit in the I/O of the HP you can save $1000; if you don't plan on using the NTK o2 or low impedance injectors you might also be able to go to a Terminator-X setup and save even more.you can limit running out of inputs be running things separate like the boost controller.
I think the Terminator-X Max is the one with the trans control.Isn’t there a Holley Terminator that has trans control? Megasquirt has a trans controller that has can bud connection to Megasquirt ecm. Since Ecugn is MS based…???
